Question about Yard Machines Garden
Yard machines riding mower model number 13AM672G352
Looling for a starter mower.
SOURCE: mower will barely turn over. new starter and batt.
not 100% but i have a JD 345 that i just went through the same scenario with, turns out the pto cluch was froze up, take the clutch off (can be a pain, medium size gear puller a plus) and see if it turns over. new clutches are a lot less expensive than a new mower!
Posted on May 06, 2009
  • 73 Answers
SOURCE: mower won't start
im sure the switch is bad, trying to jump is a good way to find out if the starter is bad but of course wont start cause of no spark, alot of these have electronic magnetos
Posted on May 28, 2009
  • 143 Answers
SOURCE: mtd yard bug model - 198707 riding lawn mower blade belt size?
I dont know the belt size but if you go to mtd belts in Jackssmallengines.com you should find it. Stephen.
Posted on Aug 23, 2009
  • 61 Answers
SOURCE: Yard Machine 18.5 HP riding mower,drive belt keeps
ck belt for wear ck between deck and frame
for so thing around clutch shaft or shaft out place.
Posted on Sep 07, 2009
  • 124 Answers
SOURCE: Tighten belts on my Yard machine ride on lawn
There is rarely any adjustment to tighten the belts on a riding mower. The belts are tensioned by an idler pulley which is controlled by a idler pulley spring. Almost all riding mower belts must be accurate to the hundredth of an inch or no less than accurate to 1/8th inch. It is very rare for a belt to be in full inch increments. This is why automotive or general purpose belts will not work on a riding mower. I know it is tempting to try to get by with a $10 belt rather than spending $35 or more for the correct belt. Trust me, you will only waste your money trying to get by with the inferior belts. Riding mower belts and extra heavy duty and generally will not stretch at all. Generally they will have 5 or more strands of a Kevlar type material so that stretching is virtually non existent. If the belt will not tighten then it is most likely not the correct belt. If the belt is in fact the proper belt and still is too loose, then you should look for pulley wear or weak tension springs. Metal pulleys do wear and tension spring do loose tension.
Posted on Sep 14, 2009
Manual for a briggs and straton riding lawnmower model #13ac762f755
Do you need the manual for the machine or for the engine? Your model number comes back to a MTD Yard Man mower.
You can go to Briggs' website after you get the serial and model of the engine, for a manual on the engine.
If you need particulars for the mower - follow the link. Yard Man Riding Mower 13AC762F755
Apr 14, 2017 | Briggs Garden
Whats wrong with my yard machine riding mower motor is just spinning want start ?
You may have a stuck starter gear ,and or a worn out starter gear !
May 22, 2014 | Yard Machines Garden
How do i change starter pulley for yard machines lawn mower
do you need to replace the rope or just replace the starter clutch? check this link for those parts,, http://www.jackssmallengines.com/starter.cfm if you reply to this answer, I will assist you in whatever it is you need,
Sep 10, 2011 | Yard Machines Garden
Need a manual for a Model 13AF608G062, Serial #1E292H10446 MTD Yardly Riding Mower
If you go to the MTD website you can enter your model and serial number and you will be able to download your manual.
here's the link - http://www.mtdparts.com/webapp/wcs/stores/servlet/OperatorManualView?storeId=10101&catalogId=19502&langId=-1
Jul 18, 2011 | Yard Machines Garden
I NEED TO LOCATE A DECK FOR A 46" YARD MACHINE
You probably have in your area a number of small engine repair shops. You will have to get on the phone and start calling around for a used mower deck. They usually have many old mowers in there yards. If you decide you only want new it could be very costly. GOOD LUCK.
Jun 30, 2011 | Yard Machines 155 Torque Briggs Stratton...
I have a 2005 yard machine 20hp v twin riding lawnmower that turns over real slow.I've put a new 350 cranking amp battery in it and tried a used starter and still no luck.Is there anything else that would...
Yes if you have an OHV engine you need to adjust the lifters or at least check ten every season. It is a very simple task just go to smalleng.com and watch the video for this process. The hardest part for you will be finding the correct gap for your model. Call your local equipment repair shop and they will give you numbers. Try you can't go wrong. Good Luck.....
Mar 09, 2011 | Yard Machines Garden
3.5 horse power rideing lawn mower 638 R L yard machine by M T D
There is no such thing as a 3,5 hp riding mower,a serial number or a model number would help,along with an actual question.
May 17, 2010 | Mtd Garden
Where is the solenoid on yard machine 12.5 hp riding mower?
hello....usually the solonid is behind the housing surrounding the steering wheel, if it's a front engine riding mower. Just follow the large red cable from your starter, this is connected to your solenoid....hope this helps...
Jun 07, 2009 | Mtd 22" Yard Machine Push Mower
Yard machine riding mower will not start
check all of your known safety switches!
Clutch has to be pushed in
seat switch (sit on mower)
blade disengage switch
Finally check your starter soleniod between the battery and the starter and look for fuses and check them out in the process
May 18, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
65 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
