Question about Troy Garden
Replace troy built (tb90bc) throttle cable
Cable is broke on the carborator end.
4 Suggested Answers
  • 2418 Answers
SOURCE: I have a troy built 4 cycle weed eater, when you
If you still have your instruction book look for for the location of the idle adjustment screw. If you find that and adjusting does not help. try some Seafoam this is a carb cleaner. put a little in the tank with some fresh gas. start it and run this thru then readjust your idle.
Don't forget to ck the air filter and clean or replace it, replace it if you can't see day light thru it.
Posted on Jul 04, 2009
  • 14 Answers
SOURCE: troy built weedeater sounds like stuck in medium
Check and make sure the spark arrestor on the muffler isn't clogged with carbon.
Posted on Oct 08, 2009
dave_gold
  • 37 Answers
SOURCE: i need troy-bilt trimmer TB90BC engine schematic
you should be able to find the manual for the trimmer from their web site... you need both the model number and serial number to get the manual. i'll put the address you need below
Canada
http://www.troybilt.ca/troybilt/troybilt_manual_search.asp
US
Hope that helps
Posted on Aug 27, 2011
Troy bilt weed eater
I have a troy built 2 cycle pro-line tb90bc spring assist trimer.
its getting fuel and it wouldn't start I took out the spark plug and it was wet with fuel. pls fwd any info to ss.beepat@hotmail.com
May 06, 2013 | Troy-Bilt Tb90bc 17-inch 31cc 2-cycle Gas...
I have a 2 cycle Troy-Bilt TB90BC line trimmer. Won't idle. I've had the carburetor dipped, installed a new carb kit, replace the gas lines, but will only run at full speeds. Dies out easily....
One of three things is occuring here. The IDLE SPEED SCREW (Phillips head) on the throttle plate is screwed in way too far. The L and H mixture screws are open way too much allowing the carb to use excessive fuel, even on startup. Those 2 screws may need adjusting. The metering lever in your carb is not adjusted flush with the carb body flange and is holding the gas needle open constantly. Check these things and post back.
Sep 09, 2011 | Troy Garden
The head will not spin on Troy Built weed eatter
sounds like your flex cable has taken a trip south. Pull the shaft off the head and take a look at the flex cable. If flex cable is ok, they your clutch is defective.
May 29, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy-Bilt weed eater, Model TB90BC, had rotten fuel lines and primer bulb, I replaced but may have hooked them up wrong. How do I hook them up?
Prime and watch the fuel move up to the carb. This is the fuel line and it should be long. Make sure it goes to the bottom of the fuel tank.
Apr 04, 2010 | Troy -Bilt String Trimmer/Blower...
How does the gear box come apart on a six horse troy built tiller?
  1. Remove belt guard on left side
  2. Remove belt, large pulley on gearbox.
  3. Remove throttle cable, idler pulley cable and shift handle.
  4. Remove engine, handle, wheels, tines cover and tines.
  5. Lay gearbox on side on two sawhorses, left side facing up
  6. Remove all the nuts on that side. If the three shafts have corrosion, use sandpaper to remove.
  7. Pry the two halves apart, then hammer the ends of the three shafts to push through their bushings. Use brass or wood to avoid blossoming the shaft ends. When shafts are through their bushings, the right side will fall away.
Jan 15, 2010 | Troy-Bilt Pony Garden Tiller
I have a Troy Built lawn tractor, after removing
Clearly the cable either broke, came loose.
Aug 22, 2009 | Garden
How do i remove the carborator ttr250
Disconnect fuel line from the tank, careful not to tear it. Their will be a rubber boot on each end, (to the cylinder and to the air box) loosen the clamp around these. The cables to the throttle need to be removed at the carburator end or the hand throttle end. You may need to remove the seat and gas tank for this to make it easier. The vent lines can stay with the carb, just note where they go! The carb should slide out from between the rubber boots. Just take care with it.
Jul 02, 2009 | 2002 Yamaha TT-R 250
Garden Logo
48 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
