Question about Vacuums
I need to know what style replacement belts and bags to use, as well as an owner's manual. Thanks.kenmore progressive 116 38612790
  • 10 Answers
SOURCE: Need Manual for Kenmore Progressive with Direct Drive vacuum clea
You can check for the manual at:
www.managemyhome.com
I would suggest checking the hoses for clogs. Especially the hose right after the carpet brushes. Don't forget to clean off your brush. Hope this helps.
Posted on Jan 14, 2009
SOURCE: Kenmore Vacuum cleaner #175.3866180 bags and belt
I logged into the Kenmore website, entered the vacuum model no. and found that the bag has been superceeded by 20-50004, which appears to be available only from Kenmore. The belt required is #5270.
Posted on Aug 03, 2009
  • 85 Answers
SOURCE: Belt is broken
there is no belt on your model there is a reset button on the side by the brush
Posted on Dec 15, 2009
oldmanewtoys
  • 414 Answers
SOURCE: my vaccuum has no more suction
There is no drive belt on a progressive drive vacuum. It is direct drive meaning it is attached via the motor. No vacuum means no air flow somewhere in the unit. Torn bag,Wrong bag, pluged filter under bag.Make sure the opening in the bag is the correct size,too big and it will not seal. Make sure when you close the housing it seals also. No housing seal no vacuum. Kenmore vacuums tend to be plastic housings. Cracks are comon in the wheel housing area. Check there first. Plastic expoxy will work with this fix if so needed.
Posted on Feb 25, 2010
  • 20 Answers
SOURCE: 25512/ 25513 Progressive Canister Vacuum: HI, we have a kenmore progressive canister vacuum ...
cord bad at male prongs, or fuse near motor blown.
Posted on May 06, 2010
Need owners manual for kenmore 116 31913103
Try to check in THIS LINK under Kenmore Upright Vacuum or contact us is need additional details.
If you don't have luck, we could try HERE.
Hope this helps.
Oct 07, 2011 | Kenmore 31913 Progressive Direct Drive...
It's 5 years old and I vacuum twice a week about 900 sq ft. It is starting to smoke and the belt sounds like it's working overtime. The hose is fine. The bag is continuing to fill up. The floor...
Make sure that the dirt bag is empty and that the motor bearings are good. Also check for any debris that may be gumming up motor bearings and forcing it to run slow.
You also can check out the motor brushes and replace them.
Mar 22, 2017 | Kenmore 25512/ 25513 Progressive Canister...
My vaccuum has no more suction
Feb 22, 2010 | Kenmore 31913 Progressive Direct Drive...
Jan 12, 2009 | Kenmore 31913 Progressive Direct Drive...
Need owners manuel kenmore progressive direct drive model 116.35923500
You can get the manual at:
Just do a search on the right side.
Dec 30, 2008 | Kenmore 31913 Progressive Direct Drive...
Kenmore Progressive 100
Check the brush roll ends, make sure they turn freely, if not then replace it. The belt may look ok, but they stretch after a short time and should be replaced.
Mar 24, 2008 | Kenmore 31912 Progressive Direct Drive...
Owners manual
remove bottom plate, remove brush roll. slip new belt over motor shaft then onto brush roll. refit brush roll and bottom plate. its just meccano
Mar 17, 2007 | Kenmore 31913 Progressive Direct Drive...
Vacuums Logo
32 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
