Hp 4500 making a loud clicking noise
Makes aloud clicking noise
CoachTim
  • 202 Answers
SOURCE: Printer makes extremely loud clicking noise
http://printer.konicaminolta.com/support/current_printers/mc2430dl_sup.htm#Printer_Specific_Documentation The user guide should be helpful to you to pinpoint what is causing the noise. Sounds like the belt drive or gears may be having a problem. Let me know what happens. Tim
Posted on Mar 06, 2007
Soulvisitor
  • 1113 Answers
SOURCE: Loud clicking noise
Power the machine on with drum and toner removed, check for noise....
It will be either the Fuser, Toner or the drum.
If it is non gen. or refill toner, fault found.
The drum is a normal consumable that you change every 3 to 4 toner cartridges, so if any of you have used more than 4 toners and havent changed the drum, I'd say that we have found your problem.
......now to the hangers on .....
Fuser, thats the hot bit at the back, these have a gear that cracks because the whole fuser assemble is old, brittle and stiff, you can pull it all apart and change the gear and be off, but soon it will more than likely break again, I know cause if I do that as the fix they come back within 6mnts.
Replace fuser, or have it replaced
f9d929d.jpg LINK to P/n and price
the gear that breaks/cracks
9b32a46.jpg LINK to gear info
Fuser is a HiVolt, HiTemp part. Caution!!!!
Posted on Dec 30, 2007
SOURCE: Makes a loud clicking noise and reads scanner error.
I had this exact problem. This printer was given to me, so I didn't have the instructions. I'm pretty sure I damaged it when I tried to open it to change the ink. I didn't realize there was a lever. After I got it open, I had trouble closing it, but eventually I got it to sit down flat. It was after this that the scanning function ceased to work as described by others.
I searched online to find a solution, but was hesitant to buy a repair manual. I read about someone else who took the unit apart. His experience was really a help as he knew just what part to take off. You need to remove the gray panel on the right side of the unit (as you are facing the front). This is the side with the USB port.
There are only three screws to remove. I used a flat head screw driver to gently pry the pieces apart. There are two places it snaps together on the bottom of the unit. I was able to get it apart without damaging anything. Once it's open, you will be able to see there are a few ribbons that connect the top of the unit to the circuit board in the base. For me, two of these had come loose. I simply slid them back in the slots where they seemed to belong and put the thing back together.
It was easier than I imagined and it worked! Good luck.
Posted on Mar 16, 2008
komguy
  • 2306 Answers
SOURCE: clicking noise with MFC-8640D
Make sure that the paper guides in your paper tray are not holding the paper too tight against the front of the tray, there should be about 1/16 inch play so that the paper can be lifted to the roller easily. Also take out your toner and drum and turn it on, if the grinding noise is gone you may need a new toner, some refilled toners are too tight to turn properly.
Posted on Jun 24, 2009
SOURCE: keeps saying no paper Makes loud clicking noise
The clicking sounds seems to be made by the small gears on the side of the tray. When you move the gears, it should push a plate beneath the paper upwards, and the paper with it, allowing the paper to be feed.
I'm not sure what I did to fix it. I removed the paper and cleaned both feeding rectangles (to the front of the tray -- nearest you). One is underneath the paper and the other is in the front, center.
I then made sure that, when I move the biggest gear (the one that isn't round) that the paper moves upwards.
Posted on Sep 01, 2009
My HP PSC 4500 printer makes a loud knocking noise when first turned on which goes off after a few seconds and printer woorks okay
OfficeJet Printers have a "spittoon" in which a rubber pad is used to wipe the bottoms of the cartridges to maintain a clean jet nozzle area. To find this, the unit will go to it's home position, "bump" that side where the spittoon resides, to confirm it's home position, then wipe the cartridges before its ready for use. In other words: "That's a normal noise for this model of printer". It will happen every time you power it up or wake it from hibernation mode with a print job.
Nov 24, 2014 | HP Office Equipment & Supplies
My HP PSC 4500 printer makes a loud clicking sound when turned on but goes off after a few seconds
Mechanical failure : it's either the belt that drags the print head or the cogs powering the belt that are skipping due to wear.
It can be repaired, but unless you can find a local service that will do it on the cheap, you're better off buying a new one
My sym symply 2 125 broke down this morning.it was making aloud ticking noise and then completely shut down.the electric start just makes a click now when pressed and the kick start is jammed. Only the...
That loud clicking was most likely a rod bearing going out. The bike quit and locked up as a result. This is serious and expansive. Sorry
May 07, 2014 | Cars & Trucks
Loud clicking noise on my hp printer 4500
hi, your priner complaint i 2 chance 1 is the carrage cable is damaged or 2 is printer mechanism complaint please verifing
Mar 26, 2014 | HP Officejet 4500 All-in-One -...
Hp laptop hp 430
Maybe the cpu fan is fubar - check that out.
Mar 18, 2017 | Computers & Internet
My refrigerator makes aloud noise
Is it a loud bang noise when the comp shuts off after running?
Aug 05, 2013 | Refrigerators
HP photosmart C3180 makes a loud clicking noise when printing first page.
After inserting new cartridges in the photosmart C3180 and closing the door it makes loud clicking sound coming from the cartridge area and won't print.
Nov 05, 2009 | HP Photosmart C3180 All-In-One InkJet...
Won't print. makes loud clicking noise from right side front of unit (ink cartridge parking area)
Please have a look at the noise troubleshooter available for your printer at the HP online support site. Click here
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 29, 2009 | Office Equipment & Supplies
Makes noise
Click HERE for HP troubleshooting for your printer.
Jun 06, 2008 | HP Officejet 5610 All-In-One InkJet...
Janome mb4
Loud chirping noises indicate a need for lubrication or something is rubbing against your carriage.
sewman7
May 18, 2008 | Sewing Machines
160 people viewed this question
k24674
jasbo
jasbo
