Question about VeriFone Omni 3700
Verifone VX510 Terminal
Earlier the POS machine was working fine and one day our company has decided to have Cisco Digital lines and that was the end of it after that when we plug the terminals to the VOIP system (digital lines) the terminal is no more working
Please help , how to solve this issue and as per company policy we cannot have analog lines
Regards
  • 3 Answers
If you cant use analog lines then you have a problem..What you need to do it replace the comm equip. to a DUAL COMM with IP services.. That should fix your issue
Posted on Jan 19, 2009
Why is screen indicating download is needed?
PDF]Verifone VX510 User Guide - Moneris Solutions
www.monerisusa.com/support/~/media/Files/.../Vx510_qrg.ashx
VeriFone Vx510 with SoftPay. Quick Reference ... their PIN, and encourage them to protect their PIN. ERROR ... the terminal screen. ... PINpad display is blank: See "PIN Pad Error" ... the ALPHA key (repeatedly if necessary until the desired.
[PDF]Vx 520 - User Guide - Verifone Support Portal
Dec 19, 2015 | VeriFone VX510
No dial tone
you need to use a telephone line that is working and has a dial tone in order for your terminal to work, check all connection and test the line the terminal is using.
Apr 29, 2014 | VeriFone VX510
What does TAMPER
"TAMPER" displays on Vx510, Vx610, or Vx670 terminal Problem/Task "TAMPER" shows on Vx510, Vx610, or Vx670 terminal Environment VeriFone Connect Any Verifone manufactured device that has the capability to contain it's own internal encryption (including Vx510, Vx610, or Vx670 terminal) Cause The message: "Tamper" will appear on the Vx510, Vx610, or Vx670 terminal if it is physically opened, damaged, or if it is jarred enough to flip and enable the internal tamper 'switch'. The reason for this is to ensure any sensitive data that passes through the terminal during a credit card transaction is not intercepted or compromised. Customer Solution/Action 1.
Contact repair facility for repair/replacement of the affected device
If you still needs help call us at (775)358-2922 ask for Randy http://freshpoint.org
Sep 29, 2012 | VeriFone Omni 3700
How do i reboot
To Reboot the Verifone VX510 or VX570 terminal you will press the "F2" and "F4" buttons at the same time. When it prompts you for the password, you will enter it (this depends on which credit card provider you use) and it will bring you to a "sys mode menu 1" screen. The "F4" option should give you a "RESTART" option, which is the same as rebooting the machine.
Aug 31, 2012 | VeriFone VX510
How can we resolve bad rtc chip error in verifone vx510?
bad RTC can be repaired. the machine is equipped with multiple sensors inside. if one of them goes bad, or the Battery is dead tampering or bad RTC will show this can be fix by replacing the sensor and or the battery if you need this to be done call me @ (775) 358-2922 hope this help : - )
Sep 13, 2011 | VeriFone VX510
Can verifone vx510 (Omni 3730 work on a digital line?
It's really hit or miss. Some days they will work, some days they will not. You will only really run into a problem when your doing downloads or batching the terminal out. You will sometimes have problems running cards, but make sure you hit the reports key if you get a disconnect to make sure the transaction didn't go through already before running the card again.
Sep 18, 2010 | VeriFone VX510
Verifone 3730 brand new . they say ready to work right out of box. this a replacement for one that did not work . it says no line ending call please help thank you
it needs reprogram or double check it has 9 or 8 dial out in front of main#.
there are so many reasons for that.
call your processing company and let them fix it.
Thanks
http://www.gorillapaper.com/verifone-vx510-le.html
May 01, 2010 | VeriFone Omni 3700
I have verifone vx510
GO ON LINE
VERIFONE OMNI 3700 SERVICE MANUAL
OR
VERFONE VX510 SERVICE MANUAL DRIVERS
ENTER
OR
VERFONE 3700 VX510 FLASHING LIGHTS
ENTER
ROD
Feb 10, 2009 | VeriFone Omni 3700
Retail Supplies Logo
839 people viewed this question
Top VeriFone Retail Supplies Experts
danielle yancer
danielle yancer
Are you a VeriFone Retail Supply Expert? Answer questions, earn points and help others
