Question about Sony Televison & Video
Screen breaks up and sound goes off for a second or two then is ok for 5-10 min.
KDL46VL160 sony
  • Dollar Bill
    Dollar Bill Jan 03, 2013
    Problem solved, possible bad signal from Time warner.
    Top Expert:
  • Sony Master
  • 14,553 Answers
To try to rule out source of signal causing this issue does set do same thing when a DVD etc is connected to a rear audio/video input or not?
Posted on Nov 02, 2012
2 Suggested Answers
SOURCE: sony V lcd 32 inch losing digital channels and
You answered the question in your question.
''weak signal' means exactly that, however it can also mean the signal is too strong.
If you have a booster installed into the ariel remove it, if not, try one. Make sure the TV is directly connected to the ariel, not via a DVD recorder or any other devices which require an ariel input.
Sony tv's have very sensitive tuners installed so its just a case of making your aprticualr settings compatible.
Check signal strength over at www.digitaluk.co.uk
Thanks
Posted on Dec 16, 2009
Sony wega 55" 3LCD turns
Have you changed the lamp? If not the lamps life is around every two to three years. The lamp is easy to change out. Most local repair shops carry the lamps. Hope this helps.
May 29, 2011 | Sony Grand WEGA KDF55E2000 55" Projection...
Mx4000 128mb on xpsp3 problem
in windows power settings, you ajust the time the monitor runs and shuts down one setting is do you want the monitor to stop after 5,10 or so mins you answer never that will cure the shut down
Jul 06, 2010 | XFX GeForce MX4000, (64 MB) Graphic Card
Hi I have a Sony Grand WEGA KDF-60XS955 TV
Ur right the cooling fan is defective,check it,clean it might work normal again.Not, than the cooling fan must be change.
May 04, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony kf 50e200a screen goes black and sound turns off for min...
TV has gone into "protect mode" to do just that to protect against the damaging failure that has been detected, you will need a servicer to diagnose the failure. Good luck and Merry Christmas!
Dec 25, 2009 | Televison & Video
Standby Indicator flashes red 6 times between 2 second intervals
My TV (Sony Bravia LCD KLV-32S310A) goes of after 20 seconds when it is switched on. The standby indicator then flashes (red) five (5) times then there is a two seconds break followed by another six flashes then two seconds break etc. What might have caaused this and what should i do?
Apr 13, 2009 | Sony Televison & Video
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Flashing Screen
ok, the problem you may be having is bad solder connections on the vertical deflection IC. resolder them or have a tech do it. also check for bad solder on the 9 volt regulater IC as well. these problems are common to older sony sets.
Feb 29, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Picture problem
Usually that symptom is caused by cracked solder joints on the vertical output IC. As the IC starts heating up, the picture starts breaking up at the top with several "dancing" dark lines appearing, the top scrunches down and then when the vertical quits altogether, the screen goes completely black. A good slap on the side of the TV might make it happen faster or clear it up temporarily. If you have experience working on PC boards then you can resolder the pins of the vertical output IC but if you have never soldered parts on PC boards then allow a qualified tech to handle it for you.
Nov 20, 2006 | Sony KV-35S42 35" TV
Televison & Video Logo
316 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
