Fujitsu Siemens Laptop loose screen
Where are the screen hinge securing screws for E series Lifebook? I have a loose screen but I can't find the hinge screws.
  • andy_howlett Jan 04, 2009
    e8020
  • Christoffer Petterson May 11, 2010
    witch lifebook do you have?, e4010, e4010d, e7110? if it`s one of those let me know:)
  • 201 Answers
Some hinge screws are under the power button bar,over over the keyboard,also in back or under the unit where the lcd is located
power button bar is also the hinge covers this pops out , but may be screws on bottom holding it
Posted on Jul 20, 2009
Laptop hinge wont move
I would loosen or unscrew the 8? screws that hold the display on, this will loosen it off without everything coming apart, then tilt the screen down, lift the from the bottom of the screen, pry without breaking, take that panel off and see if you can replace or find the part that came out, it maybe screws or another piece. You can probably put it back together if it fell out, then just put the screen plate back on.
Aug 23, 2013 | Fujitsu Siemens Computers & Internet
Turn off snooze function
I'm a bit confused by your terminology, "snooze" function? We are talking about a Fujitsu Siemens LifeBook A Series Laptop, Correct? If your referring to the Sleep or Hibernate settings, Open the Control Panel, select Power Options, you didn't post your OS, so here's a Win 7 solution, set to High Performance, select Change Plan settings, under Plugged in, set Display time and set Sleep to Never, select Change Advanced power settings, go through the settings one by one set to your preference. Sleep and Hibernate to Never.
Apr 25, 2013 | Fujitsu Siemens LifeBook A Series Laptop...
How do you replace the fan on a Fujitsu s2210 laptop?
How to Replace a Fujitsu LifeBook S2210 Fan
1. Follow your laptop owner's manual and assembly guide carefully as you disassemble the laptop. Touch something metal periodically to remove static charge, and work on a large table with a bright light source.
2. Turn off the laptop and unplug it. Remove the main battery, DVD drive , Ac adapter and the hard drive. The hard drive is usually located in a slot on one side of the laptop. Remove the screw that holds the cover in place, then pull out the hard drive, screen sled.
3. Turn the laptop over and remove the screws on the bottom that hold the keyboard in place. Flip the laptop over, open it, then lift the keyboard up and out. Unplug the flexible ribbon cable that connects the keyboard to the motherboard.
4. Remove the screws that hold the laptop keyboard bezel and palm rest in place. Carefully pry loose any plastic snaps on the sides, then lift the bezel and palm rest up and out.
5. Unplug the Fujitsu LifeBook S2210 CPU Cooling Fan. Remove the screws that hold the heat sink and fan in place, then remove the entire unit from the laptop. Remove any thermal compound residue from the bottom of the heat sink and the CPU.
6. Apply a thin layer of thermal compound on the CPU, then replace the heat sink and cpu cooling fan. Replace the screws, plug the Fujitsu LifeBook S2210 Fan back in, then reassemble the laptop.
7. Plug the laptop in and turn it on. After you use it for a few minutes, you should hear the new Fujitsu cpu cooling fan running and feel warm air blowing from the vent on the side of the laptop. A Fujitsu LifeBook S2210 Fan does not run continuously, so don't be concerned if the Fujitsu LifeBook S2210 Fan shuts off periodically.
Jun 26, 2011 | Fujitsu LifeBook A series AH550 NoteB......
Adding memory to Fujitsu LIfebook Series A3040
You remove the access cover which is where the power button is right under the screen by sliding it to the left until it comes off.Then you push the keyboard up to the back of the laptop until it will lift up exposing another cover. You remove the second cover and that is where the ram is located.Ram is under the keyboard.
Oct 09, 2009 | Fujitsu Siemens LIFEBOOK A3040 PC Notebook
Fujitsu Siemens Black Screen problem
Hold the power button in for a few seconds, until it powers off. When it reboots, change your power settings. Don't shut the monitor off after any time span, it isn't necessary.
Aug 08, 2009 | Fujitsu Siemens LifeBook T1010 Tablet PC
My Fujitu Lifebook c1020 display is bad and needs swapping. I need a repair maual.
its pretty simple to change the screen on this computer, and you dont really need a service manual (i dont even think you will find one for that)
the way you do it is remove the rubber "dots" around the screen, there should be atleast 4.
when they are out, and you have removed the hidden screws, you can take of the frontbezel around the screen.
when the bezel is off you might need to loosen or remove 1 of the 2 screwes on each side at the bottom hinge.
the screen itself is fastened to the hinge with 2-4 screws on each side of the screen. remove them, take out the flat/wide cable on the backside, and disconnect it from the 5-6cm long printbord.
reverse the process when you put in the new screeen.
May 28, 2009 | Fujitsu Lifebook C1020 Notebook
CPU cooling fan failure on Fujitsu Siemens Lifebook 7010D
I have opened dozens of these in the past and i have one in front of me at the moment...the easiest way to do it is. Get a blank white sheet of paper. Close your laptop and turn it face down. Remove all the screws underneath.As you remove the screws put them on the white piece of paper.So if you remove the screw from the top right then put the removed screw on the top right of the blank white page.
When you have all the screw removed the first thing to come off is the section at the on/off button (about 1nch thick covers the six buttons and has the display on it) Open the screen flat and fully extended.Remember at the back you will need to clip off on both side the grey plastic piece.(beside 2 usb connections and network port) when this section comes off you will see 2 screws underneath for the keyboard to come off...I think you will get it from here....
PS: watch out for the wireless button on the front left... this can pop off when putting it all back together....I'd say somewhere like maplin is a good place to look for one of these fans when you have it removed....best of luck
Mar 26, 2009 | Fujitsu Siemens LifeBook S7010 Notebook
How to remove hard drive from Fujitsu Lifebook N3010 PC laptop
Remove the DVD drive, and then there are 4 outer screws holding the hard drive chassis in place. There are also 4 inner screws that hold the hard drive to the removable hard drive chassis, those do not have to be removed to remove the hard drive from the computer. Carefully remove the screws so they don't fall into the holes on the sides of the screws, and then slide the hard drive out of the pin slots.
Nov 03, 2008 | Fujitsu Siemens LifeBook N3010 Notebook
Computers & Internet Logo
575 people viewed this question
David Payne
David Payne
