Question about DeLonghi Microwave Ovens
DeLonghi microwave E8021P-Bl
Can't find where light bulb goes to replace it
welcomejee
  • 10594 Answers
SOURCE: panasonic genius microwave light bulb
Does your microwave front display lite?
Posted on Aug 27, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: DeLonghi microwave oven
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Jan 09, 2009
  • 75 Answers
SOURCE: Replacing light bulb in Microwave Oven.
if this is a counter top modle this is no problum, unplug it!!!
open door look for the light hole vents, ( that is where the bulb is )
you will need to unscrew the outer casing. noproblum there is nothing but reguler insalation in side and a area where the bulb is. replase it you can buy them at any hardware store,
if is a under cabinet there my be a axes door if not will need to take down,
hope this helps.
p.s. 1st time i that there was all kinds of things in side but not
Posted on Jan 23, 2009
SOURCE: Delonghi AC930AMQ Microwave, Interior Light Bulb
Managed to figure out what the problem was ,I was a bit heavy handed with the solder/flux which caused a short cleaned up the area around the solder joints and now working great
Posted on Feb 05, 2009
SOURCE: delonghi
Changing bulb in DeLonghi ED 8525S-SBD
This is merely an account of how I fixed mine - do this at your own risk. The oven is full of high-voltage items which include large capacitors which are not discharged when you unplug it from the mains. You can still get a life-threatening shock from the charge which is stored in these components.
Therefore do not touch ANYTHING electrical except the bulb connectors.
1. Unplug the oven and place on a suitable surface 2. Remove the cover. This is held by five screws at the back of the of the machine. Three are along the top and are philips type and the other two are on the bottom left and bottom right corners and are star-grip. The cover must slide backwards first before coming off. 3. Find the bulb holder. It is located on the right of the oven as you look at it from the front. Turn the oven so that its right side faces you. The bulb holder is an oval black part with two electrical connections coming off it. It is about 6-7 cm long and 3 cm wide. It is mid way in the oven (from top to bottom) and a little towards the front. It is held to the oven frame with two bent metal prongs 4. Remove the electrical connectors by sliding them backwards. 5. Bend back the prongs and lift out the bulb holder. 6. The bulb in a 20W 240V oven lamp with a standard oven lamp screw-on fitting. 7. Replace the bulb. 8. Put the bulb holder back in place, bend the prongs back to secure it, re-connect the electricals. 9. Replace the cover and screws.
Posted on May 29, 2009
Light bulb in a hot point oven mod Le no sa2 540 h bl
Get a replacement bulb that is rated for appliances. A regular household bulb will fail the first time you heat the oven. Broken glass is a messy cleanup.
Sep 14, 2017 | In Microwave Ovens
Wheres the bulb in a delonghi AC925EFY microwave
You must remove the outer cabinet from the Microwave to access the bulb. Remove every screw top, sides and bottom and slide the cabinet off.
Sep 06, 2016 | DeLonghi Microwave Ovens
Light bulb
follow this steps and fix it. God bless you
If your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  • Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction
  • Jul 29, 2013 | GE JES1384SF Microwave Oven
    Replace interior liht bulb on whirlpool combi micro ft 339 bl
    If your owner's manual does not address it, then you will have to remove the outer cover of the oven.
    You can download Whirlpool owner's manuals and installation instructions here.
    You can find helpful exploded view diagrams and order parts by entering your full model number here.
    Dec 16, 2011 | Whirlpool FT 339 Black Microwave
    My delonghi ac925chs combination oven and grill work... microwave has stopped heating have noticed there is no light on in the microwave.and when i went to use it yesterday it would not heat in the...
    Check this video it goes through checking and replacing magnetron, capacitor, diode and fuse. It will be one of those. Check the safety instructions in the description.
    Sep 04, 2011 | DeLonghi Microwave Ovens
    Delonghi microwave AC 930AMQ. I have lost the manual, so could you tell me where the light bulb is situated, and can I purchase one from any electrical store. Many thanks Dawn.
    Hello Dawn,
    You should be able to get a replacement bulb from a number of places, however here is a message I got off the internet.
    To replace the bulb would involve the removal of casing and the use of special screwdriver, thus invalidating the warranty.
    Regards
    Alan Hood
    ami-man
    UK
    Sep 24, 2010 | DeLonghi Microwave Ovens
    hope this helps.
    Jan 23, 2009 | Danby DMW1153 Microwave Oven
    The bulb is usually run by one of the door switches, but in some cases they are run by a relay on the board.
    I would suggest you look over our files on safety & door switches here:
    http://www.microwavedisplay.com/safety.txt
    http://www.microwavedisplay.com/doorsw.txt
    Please write back with more details if you need further help.
    We're happy to help and we appreciate your thoughtful rating of our answer.
    Jul 05, 2008 | DeLonghi MW 605 Convection/Microwave Oven
    Microwave Ovens Logo
    Top DeLonghi Microwave Ovens Experts
    William Miller
    William Miller
    Steve Mason
    Are you a DeLonghi Microwave Oven Expert? Answer questions, earn points and help others
