Question about Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher keeps tripping electric
Dishwasher stopped through cycle and there is water in bottom please help
    Sergeant:
  • 378 Answers
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwash
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Posted on Jan 04, 2009
SOURCE:
I have a aeg 43070 vi dishwasher It keeps tripping the circit breaker on the house fuse box . I have reset the leak cutout by dipping the dishwasher back and stopped the warning sound,but went for about a...
I assume you are refering to the earth leakage circuit breaker. This trips when a earth leak fault has occured. The normal cause for this could be
A) Water leaking via a pipe at the bottom comming in contact with one of the electric motors at the base of the washer.
B) A heating element has gone faulty with a electrical leak to earth.
You need to test this with a multimeter on the OHMS scale and rectify any short to earth that the meter would indicate.
Mar 21, 2010 | AEG 23 in. Favorit 44070Vi Built-in...
Keeps bringing C3 error code what is it the machine is a WT55DRG
water in the bottom tray of the casing will trip the leak sensor
this stops the cycle and engages the pump which will run until the water has gone (ie forever)
you need to dry the casing taking care not to get water onto the electrics, this will reset the switch
but you also need to find out how the water got there (leak etc.) otherwise it will reoccur
hope this helps
Feb 15, 2010 | Dishwashers
Baumatic BDW45. Keeps tripping the electric out when on a wash cycle and leaves water in the bottom. If I put it on a rince only it works fine. Help
your tub is running out of balance could be due to your counter balance weight in the bottom or excessive load shift sometime you can try rocking the tub by hand to re center it or you may have to turn it on it's side to see if the retaining pins are locked on the tub or the balance weight is broken
Jan 14, 2010 | Baumatic 18 in. BDW45.1 Built-in...
S5N27B keeps stopping mid cycle
If the cycle doesn't complete, check these:---
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 28, 2009 | Bosch Dishwashers
Hi my dishwasher keeps tripping the electrics. it's always the same place in the cycle. there doesn't appear to be anything blocking the filter. there's always water in the bottom after a trip and the...
Hello there, If this unit is tripping the breaker lets say on the pump out drain cycle, then you for sure have a problem in the motor and pump assembly.Anytime a breaker trips, if the breaker isn't worn out, it indicates that it is drawing more amps than it is rated for due to an overload problem and so on.You're motor and pump needs to be checked out on site with the proper electrical tools and so on. Wish I were there to help.
Good Luck, Shastalaker7
Nov 05, 2009 | Dishwashers
Tripping the breaker
How far into the cycle does it trip the breaker?Does the motor run then trip it?Is it at the end of the cycle when it goes to a dry cycle?Does it trip in the beginning when it fill's up with water?
Mar 19, 2009 | Dishwashers
LG Dishwasher Model LD-1403W gets stuck and stops on rinse cycle leaving water in bottom of machine. I have stripped it down and emptied it, made sure filters etc are clean but to no avail
LG Dishwasher LD 1403W. We have cleaned it and when it gets to the heating cycle after running right through to nearly the end, it trips all the electricity and stops everything. Its only 3 years old and hubby thinks its the heating element but between $200=$300 to fix.
Apr 10, 2008 | Dishwashers
My dishwasher when switched on keeps throwing the trip switch
i had this probem and apparently there's a 'float switch' in the bottom of the machine. This switch is a safety cut off and when activated can not just stop the machine but trip the electrics in the house. the reason for it activating is when food clogs up the drainage bit water can not drain and fills up the bottom of the machine. this then activates the 'float switch' as a kind of safety cut off.
the way to sort it is to disconect the machine from the mains and drain and water. empty the clogged up food from the drain bit. then tip the machine back and a load of water will pour out (may need a load of towels for this bit or take the machine out the back and do it)
once this is done, plug it all back in and give it a try - works for my machine, good luck.
Oct 09, 2007 | Indesit 24 in. D63 Free-standing...
Whirlpool GU2400XTP Built-in Dishwasher Logo
475 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
