Question about Xerox Office Equipment & Supplies
Xerox 510 LL 24 error code. What is it and how do I fix it? Thanks.
Just switched out the toner cartridge and waste bottle. Made a few copies and ran out of paper. Loaded a new roll, made a few copies and then got code LL 24 in the display. What happened and how do I fix it without calling for service?
SOURCE: my Xerox Documate 510 adds
you probably have something on the scanning bulb when it goes through the feeder. The scanning bulb is directly to the left of where you use the flatbed. Clean that glass with a dry, clean cloth and you should be back in business.
Posted on Mar 05, 2009
SOURCE: No paper message for ADF
I called Xerox and the technician told me the ADF cable was loose. I went home readjusted the ADF cable and now it works like a champ.
Posted on Apr 28, 2009
Ickoajnc
  • 183 Answers
SOURCE: waste toner bottle
this is the waste toner bottle
Posted on Jul 16, 2009
  • 12 Answers
SOURCE: Xerox 510 will not scan from ADF
If it is new, and not assuming there is a hardware problem with the scanner (some fault), might be a software problem. If the scanned image from the flabed is OK the drivers would be installed properly. You do not say which software you are using but when you have a "Professional" documentscanner and intend to use it for "production" scanning you need proper software also, To scan, to mix documents, rearrange pages, auto remove blank pages, deskew, produce small PDFs even when scanning color and so on. Look at PixEdit - it will do the job for you.
Posted on Aug 21, 2009
  • 97 Answers
SOURCE: My Oki C9600 Printer showed an error message,
940: Error
Waste Toner Transfer Error
The transfer mechanism of the
toner duct for ID is not operating
properly.
Check to confirm that the basket
assembly is in position (if it is
engaged with the gear of the
printer).
Check to confirm that the holder
magnet D contains a magnet,
and check the magnetic polarity.
Replace the HAL IC circuit
board.
Replace the duct assembly
toner.
Posted on Mar 29, 2010
Hello, we have a Xerox Workcentre 7545, the waste toner cartridge needs replacing but we don't have the part yet. Can I manually empty the cartridge in the meantime so we can still use the machine? ...
If you can remove the waste toner cartridge go ahead and empty it out manually. Make sure that it is completly clean out. I use compressed air to flush out any residue.
Sep 22, 2011 | Xerox WorkCentre M-24 Color Copier
Where is the waste toner bottle on the xerox workcentre 5030 located at?
  1. Open the Waste Toner Bottle Access Door. The door is located on the left hand side of the machine, behind the Bypass Tray.
  2. Pull the colored cap from the top of the bottle and screw the cap onto the opening of the bottle.
  3. Remove the used Waste Toner Bottle and dispose of it according to the instructions contained in the new Waste Toner Bottle box.
  4. Unpack the new bottle from its box.
  5. Install the new bottle in the machine. Make sure that the bottle is placed correctly in the machine cover.
  6. Close the Waste Toner Bottle Access Door.
Mar 30, 2011 | Xerox WorkCentre M-24 Color Copier
Error code 004-341
MCU PWB cannot detect INTLK +5 VDC.
arrwup.gifInitial Action
  • Check that the Waste Toner Bottle and all four Drum Cartridges are seated correctly.
  • Check fault history for 9-925 faults. If this fault has occurred recently, go to the 9-925 RAP.
  • Check that the I/F PWB is securely connected to the MCU PWB at P410.
  • Reinstall the IOT software. Refer to the instructions on the s/w install CD.
Nov 01, 2010 | Xerox WorkCentre M-24 Color Copier
CANON CLC3220 COPIER ERROR CODE E0000001-0003
although the waste container is empty still it show 'THE WASTE TONER IS FULL' cleaned the bottle neck of waste container see to it that the 2transparent round hole area is not clouded by toner .this is the sensor path it should be cleaned(remove one screw to remove transparent cap)
Oct 01, 2009 | Canon Office Equipment & Supplies
Unknown error 009-391
Remove Cyan Cartridge. Trun Off the Machine.
Now Insert Cartridge, make it properly inserted.
Trun On the Machine And The Error Is Gone......
Try It
May 20, 2009 | Xerox Office Equipment & Supplies
How to reset waster toner bottle full Xerox 3535
Here's what I did.
Emptied the waste toner cartridge. Left it out of the machine. Held the microswitch (located to the right of the optical sensors) in the "cartridge in" position with a paperclip. Printed one document. Inserted the waste toner cartridge. Error now gone!
GCC.
Aug 27, 2008 | Xerox DocuColor 3535 Copier
Lexmark C500 printer SVC LL ERROR, SVC L1 ERROR
As i'm sure you already know the error means - Laser power is lower than the output limit.
It's probably due to a bad contact on the engine board. If you would like the service manual it can be downloaded from the following link free of charge http://www.eserviceinfo.com/equipment_mfg/Lexmark_22.html any problems come back to me.
Aug 11, 2008 | Lexmark C510n Laser Printer
Waste motor error
The wate motor transfers (you guess it) waste toner to the waste toner bottle. If the bottle fills up, the motor cannot transfer more waste to it. This is rare, for the printer should ask for a new waste toner bottle when the previous one fills. However,it happens frequently when users try to empty and clean the bottle instead of replacing it.
If a new waste toner bottle is in place, then the printer needs a new motor, which can only be purchased through an Authorized Service Center.
Oct 24, 2007 | Samsung CLP-510 Laser Printer
Error code: E000019-0000
Error code E000019-0000 is a waste toner full error, so to get rid of this error you remove the waste toner bottle which is located left rear side of the machine and dispose the waste toner and dont forget to clean the neck of the bottle because the waste toner might obstract the toner sensor passege and then switch off then on and you are up and runin.
Oct 17, 2007 | Canon (6981A002AA) for imagerunner 2200,...
121 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
