Question about BEL 880 Radar Detector
Code ?lo1 cal comes up and wont go off
Mainly occurs in hot weather but happening more often now.
  • Anonymous Mar 11, 2009
    I have the same
  • 134 Answers
This means that the primary local oscillator couldn't be calibrated during the RD's self-calibration procedure. You could get your RD repaird by Bel/Escort, but with these older models, your best bet would be to take advantage of Bel/Escort's trade-in offer to get a current model which provides significantly better performance -- particularly with regards to Ka band radar.
Posted on Apr 24, 2009
The engine sputters as if flooded when it is hot and when the weather is hot. If it is cold it will run and start perfectly.
Check your Distributor Cap for cracks, also check the pcm for DTC's.. I have seen 02 Sensors cause symptoms like this also..
I will need more information to help you further diagnose this problem
Feb 20, 2014 | 1996 Ford F150 Regular Cab
My 2000 expedition feels like it's out of gas and wont start when it's hot weather
Can you get any codes out of it..You said it wont start when its hot..So that means it will start first thing in the morning? Does it go dead while driving?Anyway is possible to drive it to advance or autozone,,if so they will scann it for free..If you get any codes it might help find out whats going on
May 02, 2012 | 2000 Ford Expedition
I have a subaru legacy L 1993 model car. The car wont start in hot weather. It doesn't make any sound. In cold weather or shade area, no problem. When the car also gets heated during motion (trave
hmm thinking --- i suspect the crankshaft sensor first if that doesnt cure the problem then maybe a faulty transistor or chip in the computer ? best i can offer is to ask a local mechanic to have a look or the most likely the cheapest way out ? and dont laugh - the main dealer
Nov 26, 2017 | 1993 Subaru Legacy
"fail safe engine mode". this warning comes on constantly when driving usually in poor weather conditions
This warning means that a fault has occurred that would have disabled the car in older models, the computer control has worked around the fault to avoid stranding you with a non operational car. You need to see a dealer or a well equipped shop and have the computer scanned for the fault code or codes that are stored when this happens. The engineers who design cars and trucks call this "Failure Mode Strategy"
Dec 06, 2011 | Cars & Trucks
1997 dodge ram wont start hot, starts fine in the cold but in hot weather needs the throttle pumped and sometimes even that wont do it
What is the condition of the starter ? Is this an engine hard to turn over problem when hot ? If so, the starter might be grounding out, this happens only when the casing is hot.
Jan 18, 2010 | 1998 Dodge Ram 1500 4WD
Won't start when hot.
its weird sensor failure possibly ... if your car has no computer or ecu i doubt the weather has much to do ... but i do not deny the problem...
May 07, 2009 | 1995 Jeep Wrangler
2000 Kia Rio stalls when slowing down from highway speeds or just prior to stopping.
remove whatever you have to to gain acess to throttle plates. the spray a good carb cleaner in throttlebody while openinng/closing throttle then wipe clean with clean rag.
Oct 22, 2008 | 2004 Kia Rio
Starting in hot weather
Turns out that Hondas are notorious for having starting problems during the summer (sometimes it also happens when you just run them for a short while). I have a 1990 honda civic lx and was having starting problems and noticed that it was mostly during hot days. I got my starter rebuilt but the problem continued. Also I noticed that my car was flashing CODE 16.
The flashing code, together with the starting problems, points to a problem with the MAIN RELAY.
Turn the ignition on and check for codes, pull the carpet back on the passenger side floor and look for the flashing LED, count the flashes--that'll be the code (there's a short pause inbetween codes).
The Main Relay is located under the dash on the driver side, usually on the left hand side, can be up against the left wall, it's a small black unit with a plug. You need to unscrew it from its mounting bracket first. Change the main relay and it should solve your summertime starting problem.
Jul 27, 2008 | 1990 Honda Civic
Beltronics 890 Problem
I am looking for a fix as well mine says" ?LO1 CAL "
Help!!!!! now mine wont go back to working mode at all
I will restart and get the same error message and of cource nothing in the instructions I say " W T F !! "
Oct 13, 2007 | BEL 890 Radar Detector
BEL 880 Radar Detector Logo
515 people viewed this question
Top Beltronics Vehicle Parts & Accessories Experts
John Nolan
Steve
Jerry Greenberg
Jerry Greenberg
Are you a Beltronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
