Question about Epson Office Equipment & Supplies
Epson EU-T432 prints slow
Connected to serial port
4 Suggested Answers
  • 9 Answers
SOURCE: I can't print label from ZM400 PRINTER thru' serial port
There are a number of parameters for the serial port that have to match the pc. i would print out a config page from the printer via the menu, or power on with the cancel key held. then compare it with the settings on the pc. on the config page you should be looking for things like data bits, host control, parity etc.
Posted on Jan 27, 2009
  • 3 Answers
SOURCE: Serial port settings Epson LX-300+
Make sure you have at least 10 sheets of paper loaded.
Turn the printer off for at least 5 seconds, hold down the Tear-Off button, turn it back on, then release the button when the language menu starts printing.
After the language menu prints, verify the left and right Font light are off and the Pause light is on (for English). If not, press the LF/FF button until the lights are lit in this order. Press the Tear-Off button to select English.
Once the current settings print, press the Tear-Off button to enter setup. Follow the directions to change the serial port settings.
Posted on Apr 28, 2009
ap-it
  • 53 Answers
SOURCE: epson printer just printing question marks
It sounds like it could be a driver problem, try downloading the latest printer driver for your printer from http://www.epson.co.uk/jsps/searchResults/layouts/landingPage.jsp?userQuestion=TM+U210D&_dyncharset=UTF-8&_requestid=391173
If this has helped you then please rate me!
Posted on Aug 23, 2009
Unable to install Epson TM-U220B[U220 with UB-U02III usb interface] on Windows 7 AND XP!
Hi!
Are you using a third party USB adapter or a USB interface? On the self test page that you printed does it say USB connection or something that will say about USB? or does it say parallel or serial connection? try to check the dip switches setting if its configured properly. visit epsonexperts.com site for more info.
Dec 24, 2011 | Epson TM-U220 Matrix Printer
Epson TM 88II not working with Win XP SP2
Are you confident this is using a parallel interface?
The ones I used to work with used a 25pin to 9pin serial connection. The 25 pin connection on the printer is the same as a parrallel port on a PC, but if you think of a normal parallel lead the printer should use a 'centronics' connector to conform to this. I think you may need a 25pin to 9pin serial lead which aren't very common but plenty of people should still make them.
Stephen
Feb 18, 2010 | Epson TM T88II Label Printer
I have an epson tm-t88IV on a USB port it is very slow to react when sent a print job, I did not have this issue with the Parallel Port, is there anything that can be done?
Have you used EpsonExpert.com yet to find the solution?
Go there (it's an Epson site) and set up a free user account.
From what I'm reading, it has to do with using Windows drivers slowing the response and printing. There are drivers on Epson Expert which should solve your issue.
Oct 28, 2009 | Epson TM-T88IV Printer
Epson printer just printing question marks
Aug 23, 2009 | Epson TM U210D Matrix Printer
Mar 13, 2009 | Epson LX-300 Matrix Printer
Printer prints garbage...
Hi
make sure it is configured to the right port and using the epson driver. go to printer and faxes and properties then ports. check of the correct printer driver is check. what type of cable are you using anyways? com for serial, LPT for parallel.
Hope this help
Jan 02, 2009 | Epson TM-U220 Matrix Printer
Slow Printing
is it serial or parallel?
If it's serial, You can change the com port settings (baud rate) to a higher speed. You would need to change the dips on the printer to read the same Baud rate.
Mar 25, 2008 | Citizen CBM 1000 thermal Printer
Epson LX-300 can't print
Check your parallel port settings on the XP computer. Compare these setting with the settings on the computer where the printer works. If you are using serial port for printing, then check the serial port settings.
Jul 01, 2007 | Epson LX-300 Matrix Printer
Printer problems...
It sounds as if the port is trying to operate a mouse - giving the ???????. If you have windows XP then go to control panel, printers and faxes, then click "add a printer". The add printer wizard starts up, click next. select the "local printer" option and make sure the "automatically detect and install....etc" option is turned off. Click next and you should be able to select printer port. If you are using the serial port COM 1 (usually the only one externally on the pc), then select it from the list and follow the wizard through to the end. Restart the PC and you should hopefully find that the port has become dedicated to the printer alone. if still problems, go to device manager, right click on the COM 1 port and select properties, it should allow you to start the troubleshooter for the port. This should help. Other operating systems will have a similar procedure. Also worth trying is to uninstall the epson drivers, restart, plug the printer in and turn it on, and see if windows will automatically install the printer without the epson drivers. If it will, then let it do it's stuff and hopefully it will work. Hope this helps :)
Jul 01, 2007 | Epson TM-L90
MY Epson Stylus C60 wont print
This means that your printer is trying to print from the wrong serial port connection, as your printer should be connected via a USB cable. Go to start>control panel>printers and faxes. Double click the printer and faxes icon and your Epson printer icon should be there and set as default with a tick next to it; right click on the icon>properties and then at the top of the next window, click on the tab that says ports and a list of ports will be there and the one that should be ticked should be USB001, and not LPT1 as it will be show, press ok and close windows and restart the pc.
Jun 29, 2007 | Epson Stylus C60 InkJet Printer
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
