Question about Home
I have just installed a Grohe 33304, bath shower mixer. The tap works fine, but when the diverter knob is pulled up, the water runs from the shower head, but as soon as it is released it turns back to the tap. How do I get it to stay on shower?
  • 44 Answers
SOURCE: Grohe shower assembly leaking
hiit sounds as though the diverter valve is sticking in the mid position although you have turned it to the floor spout as you call it!!
Also it sounds as though the seals are possibly leaking causing the plasterboard (drywall) to get we, or possibly a joint may be leaking. Advice access the pip-work valve etc run shower & check with torch (flashlight) to see where its coming from?
Rectification work replace seals/repair leak...replace diverter valve assembly.
Kindly
Richie (UK)
Posted on Dec 20, 2008
  • 50 Answers
SOURCE: Grohe Atrio Bath Shower Mixer Flow Problem
Check for a flow restrictor in the showerhead, also a clogged intake screen or filter in the showerhead. or hose or pipe...
Posted on Jan 05, 2009
jonbrown725
  • 73 Answers
SOURCE: Kohler K-9511-BN MasterShower Shower Arm & Diverter Doesn't Work
As a helpful hint , on these models, When installed some plumbers or home owners use plumbers putty to seal the threads and in some cases tape.
Most of the time the putty or tape gets pushed through the system if too much was used.
Check by removing the shower head and testing the pressure and blowing anything else through, then checking the head itself for foreign objects.
Kohler has a cleaning and care page on thier web site if it needs cleaned.
Posted on Jan 17, 2009
  • 62 Answers
SOURCE: Water sprays out the diverter
Remove hot/cold button in handle, remove screw/pull off handle. Remove the two screws in the wall plate/remove plate. Use a wrench to remove the diverter assembly. Get new diverter assy and reinstall eveything. You don't need to turn off the water.
Posted on Jun 12, 2009
  • 297 Answers
SOURCE: Diverter valve does not work correctly.
the connections are reversed,just change them over and this will fix the problem.
Posted on Jul 26, 2009
Our bath taps which are a mixer with shower attachment stay really hot if you put the hot on first or really cold if you put the cold on first any idea how to adjust so we can have warm water when turning...
you make no sense. From the picture the water "mixer" is the center lever or is it a diverter valve for the shower and water nozzle below???
The knobs are for hot and cold water??
Jun 08, 2014 | Plumbing
I've just installed a grohe mixer shower/bath
Did you account for wall thickness?
Dec 17, 2012 | Water Heaters
We have installed a moen 82490 one handle tub & shower unit. When we turn on the water you could shower and bath at the same time. If you pull the plug for just a shower the water to the spout stops...
If you pull the silver knob on the tub spout up, the diverter located located inside will redirect water up to the shower head and when lowered it will return the water to the tub spout. It sounds as thought the diverter is not working properly. Hope this helps..
Mar 08, 2011 | Moen & One Handle Tub & Shower Faucet
Price Pfister tub/shower facuet needs much force turn on and off
put water off at mains . step 1.-open your i box mixer. step 2-u will see a 2 mm pin. mabe yours looks difrent. bt there were u change between bath and shower that button... that nob wil have a pin at the back. try to put q20/oil in there or sope. if that dosent work u will have to get a plumber in to unscrew the mixer and clean out the inside. not recomended if not a plumber bt if u do wane try it ur self and the sope and oil dident do the job let me know im a plumber will walk u threw it
Jul 04, 2010 | Price Pfister 07-81PC Savannah 2 Handle...
Feb 18, 2009 | Grohe Eurosmart, 3-hole Roman Tub Filler...
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
