Question about Garmin nuvi 780 GPS
Garmani nuvi 710 freezes on "updating bluetooth firmware 0%" when turned on
  • Anonymous Feb 20, 2009
    My nuvi 780 freezes on "Bluetooth Firmware updating 0%" when I turn th nuvi on from time to time.
    Sergeant:
  • 378 Answers
First off all remove the battery and clean the area where the battery is inserted and also press the reset button after u insert the battery and ON the device.also chage the device properly before connecting it to the bluetooth option. this many a times happens due to the humidity problem or due to the over loaded data processing.
thanks.
Posted on Jan 04, 2009
Updates for the nuvi 710
  • Try to login to their website and then checked if there is a firmware update for your GPS device and for map updates its also on there website. For map updates there will be a payment for the map but for the firmware that will be for free.
If you have questions feel free to reply to this solution. Thank you.
Feb 14, 2011 | Garmin NUVI 710 Car GPS Receiver
Garmin Nuvi 650
1. Browse here and install the latest version of WebUpdater:
http://www8.garmin.com/support/collection.jsp?product=999-99999-27
2. Turn on your Nuvi, press view map, press speed, press and hold the middle of the speedometer (the circle that says 0.0mph in it). After five seconds (maybe a bit longer), the engineering menu will appear.
3. Press "Next" five times (once for each page). You will arrive at the "Bluetooth Status" page.
4. Press "Clear". Confirm by pressing "yes".
5. Press "Updt PR". Confirm by pressing "yes".
6. This probably did _nothing_ for you, but to be thorough, I've included the steps.
7. Connect the Nuvi to your computer. Run the webupdater and if the latest version is already detected on your Nuvi, simply proceed and browse the list of further updates.
8. If "Bluetooth Firmware Update..." (or similar text) DOES NOT APPEAR skip to step 10 below, otherwise complete your fix with the next step, step 9.
9. If the "Bluetooth Firmware Update..." (or similar text) appears in your list, select this update and agree to term of service, and have the updater load the firmware onto your device. Unplug your device. It should powerup automatically. Power off. Power back on. Your BT should be back in business. Do NOT continue with the next steps. You are done.
10. If "Bluetooth Firmware Update..." (or similar text) DOES NOT APPEAR in the list, then you need to remove the offending update that is making WebUpdater believe that your Nuvi is up-to-date.
11. You can access the Nuvi by clicking on "My Computer" and double clicking the Nuvi link.
12. Click the "Garmin" folder.
13. Click the "RemoteSW" folder.
14. DELETE "006B055301.GCD". This file will be one of two GCD files in the directory: <DRIVE>:\Garmin\RemoteSW. The file without the "Date Modified" is the original firmware. The other file is the new firmware that the Nuvi believes is installed. By deleting the newer of the two files, WebUpdater will see that your Nuvi is out-of-date. Return to step 8 to continue your fix.
This should resolve all permutations of this nasty bug.
Feb 26, 2008 | Garmin GPSMAP 60CSx
Garmin Nuvi710 phone book detail does not match phone contacts
I can help you with the phone numbers on your Garmin Nuvi 265WT.
The phone numbers transferred to your Nuvi are only supposed to be available when your phone is paired to your cell phone. Changing the entry on your phone should allow that entry to show up changed the next time it is paired with the Nuvi. Sometimes, a bluetooth mix up causes entries to be duplicated or entries' phone numbers to get repeated.
To correct this, I recommend backing up your favorites, clearing all user data (this hard reset will remove the phonebook info from your nuvi), and then updating your Nuvi' firmware to make sure the nuvi and cell phone bluetooth process runs as smoothly as possible in the future.
Follow these three steps to take to get your Nuvi 265WT running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Erase Nuvi 265WT Phone Numbers here.
Nuvi 265WT Manuals here.
Jan 26, 2010 | Garmin Nuvi 265W GPS Receiver
Garmin Nuvi fails to work after firmware update
When a Garmin Nuvi 205 stops working or behaves strangely, there are two steps you can take yourself to try and get it going again:
  1. Perform a Hard Reset,
  2. Run WebUpdater to reinstall the firmware.
I hope that helps.
Sep 29, 2009 | Garmin nuvi 205 GPS Receiver
Nuvi 265t: no sound or bluetooth after update
Your last upgrade fail.
Load V5.00, wich install the bluetooth driver.
http://www.garmin.com/software/nuvi2x5_regionfileonly__500.gcd
Load this one to your nuvi F:\GARMIN\ and rename to GUPDATE.GCD.
After disconnect your nuvi from PC and downgrade firmware test bluetooth and sound. Then retry to update (Manual as above __530, WebUpdater or Garmin-Website).
Good Luck
Jul 29, 2009 | Garmin nuvi 265 Car GPS Receiver
Bluetooth Connectivity between Nuvi 710 and Blackberry Bold 9000
get the firmware update from the Garmin Updater. It fixes the connectivity issue with the BB 9000
Apr 06, 2009 | Garmin nuvi 255W GPS Receiver
Garmani nuvi 780 freezes on "updating bluetooth firmware 0%" when turned on
Worked for me but not sure why, I had the same problem of freezing when updating Bluetooth firmware on a Nuvi 770. I chose to reset all user data (press lower tight hand of touch screen while powering on) and next reboot it updated firmware sucesfully. No idea why this worked.
Feb 20, 2009 | Garmin nuvi 780 GPS
Bluetooth enable
The complete solution - user reset is NOT necessary:
Whenever I purchase a new electronic device, the first thing I do is update the firmware. This has me in a bind in this case.
I updated my Nuvi firmware, then my BT firmware.
A few days later, I got the "Enabling Bluetooth" hang. I followed the advice on this page, but "Bluetooth Firmware Update" would not appear in the webupdate list.
Oct 28, 2007 | Garmin Nuvi 660 GPS Receiver
Bluetooth enabling
Sep 01, 2007 | Garmin Nuvi 610 GPS Receiver
Garmin nuvi 780 GPS Logo
392 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
