I have a casio DL270B Calculator one of the paper tape holder broke,where can find the part to replace it.
  • 3 Answers
SOURCE: Casio FR-2650A
the tape goes into a small slot on the backside of the machine, not in the clear plastic cover. Install the roll so the paper rolls off the bottom, not over the top. Folding the paper back about 2" does help you get it through.
Posted on Feb 01, 2008
DR NITIN
  • 221 Answers
SOURCE: I have a casio calculator
Contact the Vendor.
Sahaja Yoga : www.sahajayoga.org
Sahaja Yoga is FREE OF CHARGE and is the Only Way to Save the World.
Posted on Mar 30, 2008
maridian
SOURCE: Loading Paper into a Casio Calculator
This isn't too complicated. And for the lazy guy that just put a phone number for the fix, what the heck do we need FixYa for anyway? :\ For cryin' out loud! :) )
1. Slide the clear plastic cover toward the back to remove and flip of the metal spool holder up. Place the roll of paper on the holder. (Make sure the paper drops off the "back" of the spool for proper feed.)
2. Feed the paper into the bottom slot at the **** end of the calculator.
3. Feed the paper through that bottom slot along the inside case under the black guide inside. If you tilt the calculator correctly, you can look inside and see there is a way to slide the paper under the guide.
4. Making sure the paper slides as far as it can, press the FEED button until the paper starts feeding.
5. Feed enough paper to slide through the clear plastic cover and you're all set.
This isn't factory, it's just what I figured out playing with the thing. If you can think of a better way of explaining the procedure, by all means edit this and post!
God bless!!
Maridian
Posted on Nov 14, 2008
SOURCE: Victor 1560-4 calculator
http://www.victortech.com/accessories.asp
109640-01 (Arm Set) for $5.00
Posted on Mar 06, 2009
jackcity
  • 33 Answers
SOURCE: HOW TO INSTALL PAPER ROLL IN CASIO HR-8TM
There is a slot just in front of the printer
1. turn the power on
2. turn the switch to "PRINT" position
3. slot the paper in & press "FEED"
4. the paper should be able to feed up
Posted on Sep 13, 2009
How do I change the paper tape roll on casio HR-100TM?
Pull about a foot of paper loose from the roll so it's easier to handle. Put the paper from the new roll in the back slot, and hit "FEED" this will feed it through; after you have it through, roll up any lose paper, mount roll in holder, done, Should take about 3 minutes
Mar 02, 2011 | Casio HR-100TMPlus Calculator
I replaced the roll of paper and now it will not
The Casio DR-T220 does not use regular adding machine tape, it requires a thermal tape since it is a thermal printer. There is no ink or ink ribbon in this caculator, it is heat activated and it is the special paper that make the numbers appear. Thermal tape is available at all office supply stores.
Oct 05, 2009 | Casio DR-T220 Calculator
Reloading tape roll on a Casio DR-T120
place the paper sticking out of the top, then close the cover. it will start working; good luck
Jun 02, 2009 | Casio DR-T120 Calculator
I have a Canon P23-DHV calculator and I cannot remember how to load the paper into it. I tried to read some of the solutions but could not ger any of them to open so I could actually see the solutions
  1. cut the paper/tape cleanly on a slight diagonal
  2. hang the paper/tape so it comes from under the roll
  3. insert the fresh cut into the slot on the back (between the power plug and tape roll holder)
  4. press the FEED button to advance the paper.
Now, does anyone know how to turn off this blasted auto-shut-off feature????
Jan 24, 2009 | Canon P23-DHV Calculator
Place the tape between the two posts; then put back portion of cover down followed by the removal front portion - press feed button and it should feed. Remember it will only print on thermal paper ----
Dec 08, 2008 | Casio DR-T120 Calculator
God bless!!
Maridian
Apr 04, 2008 | Office Equipment & Supplies
Paper Roll Replacement
i work i mservice ,but for that model i don`t have a holder,but if you want i vill send you a universal holder.
beljin sasa
sbeljin@mgnet.co.yu
Feb 01, 2008 | Victor 1240 Calculator
Tape wont register on this after we changed the tape
Make sure that it is installed properly ... going under not OVER. Does the paper feed when the paper feed key is depressed ??
1. Lift the paper holder up.
2. Fold the leading edge of the paper roll 3 to 5 cm. (Do not fold it slantwise.)
3. Insert the paper roll from the left side of the paper holder and make sure the paper
roll is set in the proper direction (with the paper feeding from the bottom).
4. Insert the leading edge of the paper into the opening directly behind the print
mechanism.
5. Press the paper feed key and feed the paper under the edge of the paper cutter.
Dec 07, 2007 | Sharp EL-2196BL Calculator
Sharp EL-2196BL
mechanism.
Calculator tape holder
I love the calculator, had it for years but also need the tape holder replacement part.
Nov 21, 2007 | Casio DL 250LA Calculator
Computers & Internet Logo
David Payne
David Payne
