Question about Microsoft Xbox 360 with Kinect
Xbox 360 kinect keeps restarting - Microsoft Xbox 360 with Kinect
5 Suggested Answers
  • 23 Answers
SOURCE: my xbox 360 keeps on restarting on its own
about the only thing I can recomend is make sure all connections are tight inside,because the most common thing to cause random resets is if a cable is loose,and the vibration causes it to make intermittent connection,shorting out and resetting.
Posted on Feb 19, 2009
  • 13 Answers
SOURCE: Xbox 360 Doesn't recognize Xbox 360 games
try going into your settings and family prefrences and if tht doesnt work tht means your game is scratched
Posted on Apr 24, 2009
  • 1082 Answers
SOURCE: My new xbox 360 with
If it is new, Microsoft will fix it under warrenty. http://support.xbox.com/en-us/pages/xbox-360/troubleshoot/warranty/default.aspx
But.. sounds like the CD open button is stuck in.
The button on the case is a springy plastic lever extended to reach the button on the drive itself, inside the case.
If you plan on opening it (the case), you will need a special tool to avoid damage to the case, and you will void the warrenty.
Without a cd in it, try tapping the case on sides with finger tips or knuckles, and on the front of case next to button. Hopefully to allow button to pop out to normal position.
Posted on Dec 08, 2010
pollo1233
  • 31 Answers
SOURCE: can i use xbox 360
Yes. All XBOX 360s are compatible with Kinect.
Posted on Feb 28, 2011
Testimonial: "good"
Can I make my Xbox 360 kinect sensor wireless as I would need a really long cord to plug it in
Sorry but no. You can pick up a Xbox Kinect extend link cable. There is a 15 foot cable for $19.99 usd. Try this site. Xbox Kinect Extend Link Cable
Dec 05, 2014 | Microsoft Kinect Sensor for XBOX 360
Where is the reset button on my xbox360
I hope this helps:
  • Remove all discs from your console.
  • Turn off your Xbox.
  • Then turn it on using your controller. Press and hold the Guide button until it turns on.
  • While the device is booting, press and hold the Y button + right trigger. The Xbox 360 logo will appears (keep the button pressed).
  • The device will restart and you'll get the Xbox 360 logo again.
  • The display settings are now reset to the defaults.
Mar 13, 2014 | Microsoft Xbox 360 with Kinect
Twister Mania start up issues
Make sure to run the Kinect setup and calibration in the Xbox 360 Dash. Move all the way to the right and select kinect settings. Run the setup and follow the instructions there. Make sure to have a Kinect setup card handy. (comes with games.) This should help with any calibration issues. If that doesn't work, try signing in with a different account, or doing an xbox live sign in test.
Jun 01, 2012 | Majesco Twister Mania X360 Kinect
Trying to connect the kinect
First off make sure you have at least 190 mb of space in your HDD before trying to set up your kinect.
Setup:
Step 1: Make sure your xbox 360 is properly connected to the television with the AV cables and power cable to an outlet.
Step 2: Place sensor under or on top of your television on a stable flat surface.
Step 3: Depending on your xbox the sensor has two different connections. If you have the new slim xbox 360 then you do not need the extra add on connection you simply connect it to a special port for it on the back of your xbox 360 slim. If it is a older version xbox then you will need the extra power adaptor since it will not work without it.(Cable with power connection)
Step 4; (ONLY FOR OLDER VERSION XBOX 360): If you have a wireless connection adaptor unplug it from the usb port in the back of the xbox 360 and connect the kinect sensor's power adaptor into the port you took the wireless connection adaptor off of. There should be a special cable that will act as an extension for the wireless connection adaptor you unplugged this is so you can connect it directly to the usb ports in the front of the xbox 360. Then plug the end with the power outlet connector of the kinect sensor power adaptor into the wall socket.
Step 5: Turn on the xbox 360 and the kinect sensor should move up and down to adjust.
Step 6: Put kinect game in and it will guide you through kinect settings and your on your way to start playing! Have Fun!
Feb 26, 2011 | Microsoft Xbox 360 Console
When am playing on my kinect the game goes off then when i restart it keeps asking me to download updates and the kinect bar stays red
they kinect wants you to install video updates for online chatting, if you do not install this it will not work right, thankyou for using fixya.com
Jan 21, 2011 | Microsoft Kinect Sensor for XBOX 360
Trying to install kinect to xbox 360 get error message C00000C2
Welcome to Fixya!
Solution 1: Update your console software
  1. Insert a Kinect game disc.
  2. Start the game from the Xbox Dashboard.
  3. If your console software needs updating, you will see the following message:
    Update Required: An update has been found, to apply this update you must restart your console.
  4. Select Yes, Restart to install the update
Solution 2: Check the cables Xbox 360 S console
  1. Turn off the console.
  2. Unplug the sensor from the console, and then plug the sensor cable into the AUX port on the back of the console.
    Important Remove the power/USB adapter cable if your Kinect sensor came with one.
  3. Turn on the console.
Original Xbox 360 console
  2. Make sure the power cord is plugged into a working electrical outlet.
  3. Make sure the USB connector is plugged into the back of the console.
    The light located near the middle of the split cable should be green.
    No green light? Try plugging the cable into another outlet to make sure that the cable is working properly. If you still do not see a green light, your cable might need to be replaced. Contact
    Xbox Support.
  4. Turn on the console.
?Thank you for using Fixya!
Jan 01, 2011 | Microsoft Xbox 360 Console
Trying to connect kinect.... its saying that it has insufficient power
Hi Eddie,
Try with different USB ports if you are using old XBOX and getting message as " insufficient power". It seems to be a adapter issue why don't you visit store and exchange the XBOX 360 Kinect device.
Thank you for using Fixya.
Xbox 360 kinect Games List
Dec 25, 2010 | Microsoft Kinect Sensor for XBOX 360
Our xbox will not read the program for kinect, when trying to install kinect the screen just keeps searching...
XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console..............
click here to download repair guide
Dec 22, 2010 | Microsoft Xbox 360 Console
I bought a new xbox with 250gb, when i turned it on it says please insert disc that came with device but it didn't come with a disc, I never heard of an xbox coming with a instalation disc, help PLEASE!
If you have a Kinect Sensor connected to the Xbox 360 S, turn off the console first and remove the Kinect Sensor. Then, restart the console and go through the initial set up. After the set up is complete, turn off the console and reconnect the Kinect Sensor. Restart the console and you will be prompted to insert the game disc that came with the device, which is Kinect Adventures. Insert the disc and it will update the console then go through the Kinect set up. Problem solved.
Nov 26, 2010 | Microsoft Xbox 360 Console
Microsoft Xbox 360 with Kinect Logo
195 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
