Question about JVC KD-SX770 CD Player
JVC KD-SX770 Just got a JVC KD-SX770 car cd player and hooked it up and everything is fine except when I try to put a cd in to play the display shows please eject. I have tried other cd's in various formats and this display keeps happening. Any help would be appreciated.
  • 2 more comments
  • Wendy Squires May 22, 2007
    Yep, mine sat dormant for a month. That could be the problem. Anyway, I gave it back to the original owner and got my money back. I am going to get something else. Thanks anyway.
  • Anonymous Dec 09, 2007
    ando buscando un integrado no se cual es su numero podrian darme una pagina para ver si tarjeta sus componentes que tienen toda los integrados en un diagrama
  • erock610 Nov 05, 2008
    have the same problem any one know how to fix it?
  • dhinger Feb 15, 2009
    Yes, I have the same problem...I've had no problem for 3 years....but now every time a insert a CD it ejects it???? HELP!!!!
Per manual, you can lock a cd in by pressing and holding the power and cd button for moer than 2 secondsthe cd cannot be ejected. if acd is inserted upside down, please -eject appears.
Posted on Aug 11, 2007
Necesito una pagina donmde venga el diagrama del jvc kd sx770 porque me hace falta un circuito y no lo encuentro
Posted on Dec 09, 2007
Dude I have the same problem tried all my cds and still wont work radio works but just wont play cds has yours sat domant for a while mine has that could be the problem then again I dont know
Posted on May 22, 2007
I just purchased front speakers for my jvc kd-sx770. the connection to the previous fronts were cut by the previous owner of the car. i cannot find a wire diagram and just need to know what colors to...
front left negitive, white with black stripe front left positive, white
front right negitive, grey with black stripe front right positive, grey
I hope this has helped you and please dont forget to rate my solution.
cheers
Jan 15, 2011 | JVC KD-SX770 CD Player
Need help setting time on jvc kd-sx770
turn off the stereo then ull see the time only on ur set then u can set up!
Mar 14, 2010 | JVC KD-SX770 CD Player
Jvc kd-sx770 car stereo--radio works, but cd player doesn't
Hello beeswing70,
The player is recognizing that a CD has been inserted but is not able to read it.
Sometimes the lens assembly becomes contaminated and obscures the laser. I'd try using a commercial "lens cleaning CD" two or three times and then try a CD again. These lens cleaning CD's are widely available. If cleaning does not help, the player need professional service.
Hope this helps.
May 25, 2009 | JVC KD-SX770 CD Player
Dosent play burnt cds
Try to burn cd in 4x speed burn. Or try to burn the audio as CDDA format at lower speed burn.
Crackes usually appears when burn the cd at high speed.
Pls. leave a comment
Apr 10, 2009 | JVC KD-SX770 CD Player
No audio output from jvc cd receiver kd-sx770
The internal amplifier is at fault.
This will need to be repaired by a electronics repairman.
There is no end-user fix.
You may choose to, instead, use the RCA low level outputs and install a dedicated amplifier to power your speakers.
Verify the fuses on the radio are good, and that there is not a blown speaker causing the internal amplifier to shut down.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 20, 2009 | JVC KD-SX770 CD Player
Sound turns on when it wants to.
disconnect all of your speakers , then hook them back up one at a time when the radio starts to malfunction u have located which channel on the radio is bad.check ur wire installattion
Aug 30, 2008 | JVC KD-S5050 CD Player
Not reading MP3 cds
Have you tried removing the negative terminal from your car battery and giving it a few minutes. Hook the terminal back up and try your cd player again? That should be the same as resetting your cd player settings.
http://instrukcje.elektroda.net/caud/jvc/KD-G501.pdf
Sounds like you have a problem with the mp3 format being used.
Apr 19, 2008 | JVC KD-G501 CD Player
Kd-sx770
You can buy it from pacparts.com
Dec 08, 2007 | JVC KD-SX770 CD Player
Cd ejection
Look for a tiny, recessed Reset button on the front of the unit with the face removed. Press this button with a pen tip; it should spit out the CD and work correctly afterwards. This will also erase your station presets and audio settings.
Mar 13, 2007 | JVC KD-SX770 CD Player
JVC KD-SX770 CD Player Logo
905 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
