Question about Exercise & Fitness
Getting error E01
While switching on the afton treadmill, i'm getting the above said error and sometimes it functions normal. What's the prb and do i have to call the service guy?
4 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: got carl lewis treadmill MOT566 IT SHOWING ERROR CODE E01 WHAT DOES THIS MEAN
1) this means a) problem with the speed sensor b) main motor problem c) main motor board faulty. see the block diagram attached.
God bless you
Posted on Jun 25, 2012
ercupa190
  • 12223 Answers
SOURCE: E5 senson message appears after I starp up my True 450 treadmill
see this causes and remedy, and fix it. God bless you
However RUN the software calibration for diagnostic, troubleshooting.
The power up test sequence has detected a key in the operated condition. The power up test
sequence is performed every time the unit is turned on (powered up). This test is performed
because a permanently stuck key will inhibit the correct operation of the unit.
Possible Causes
1. A key on the display housing is permanently stuck in the operated condition.
2. One of the upper PCA's keypad interface chips has failed.
3. Liquid (perhaps perspiration) is present on the surface of a touch sensitive display.
Possible Remedies
1. Remove the keypad connector cable from the upper PCA. Restart the power up sequence, if
the ERROR 5 is no longer present, the keypad is the cause. The keypad is typically part of
the display housing. Replace the display housing to correct the problem.
2. Remove the keypad connector cable from the upper PCA. Restart the power up sequence, if
the ERROR 5 is still present, the upper PCA is the cause. Replace the upper PCA to correct
this problem. Most upper PCA's are provided without software. Therefore, the software (chip)
must be removed from the upper PCA being replaced and re-installed on the replacement
upper PCA.
3. Wipe the surface of the touch sensitive display clean of all liquid. Restart the power up
sequence, if the ERROR 5 is no longer present, the liquid was the cause.
Posted on Oct 12, 2012
ercupa190
  • 12223 Answers
SOURCE: slimline treadmill error e01
adjust the spee sensor, test for open or faulty, clean it, and tight the connector very well, see the diagram attached.
2) test the input voltage motor, if there are the motor need repAIR, see my personal TIPSO for motor help
3) test the ouput voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Posted on Dec 13, 2012
How do i get the e01 away and start the tredmill
How To Lubricate Treadmill
this error is coming from lack of lube
Let me know
Blessing
cuadra2016@yandex.com
cell+whatsApp: +50588611441
Jan 26, 2018 | Exercise & Fitness
Afton treadmill showing error code E-4 and not starting?
E4:
incline
wire 1.incline motor VR wire not on right position. 1.rework the VR cable head to be sure on right position. 2.incline motor AC wire not on right position 2.incline motor AC wire insert again to be sure right. 3.incline motor connect wire is broken. 3.change connect wire or change the incline motor
Jan 12, 2018 | Exercise & Fitness
What's the problem of error 1 on my york t520i treadmill that stopped working, I need your help please.
Error 1: Speed sensor error Turn the power switch off and on again to reset the treadmill. If the treadmill returns to normal operation, you may continue to use the treadmill. If treadmill does not return to normal operation, then call the dealer for advice.
ERROR 1 CODE This is a safety feature that can stop the treadmill from functioning. This error can occur because the computer is not receiving the correct information from the speed sensor located near the motor. As a precaution the computer stops the treadmill until it begins to receive the correct feedback. By performing a few simple checks, the error can be cleared quickly and easily, and the treadmill can be ready for use. The treadmill does not move and displays "ERROR 1" Switch off the treadmill at the mains, and then switch it on again. If "ERROR 1" still shows switch off and push the running mat round (1 cycle) using your feet. Then switch back on. If "ERROR 1" still shows, then UNPLUG from the mains and check all of the wire connections made during the assembly. (SEE BOLD PRINT) UNPLUG If the treadmill still does not move, then please contact the helpdesk. Doing this may reset the program error, and the treadmill will be ready to use. This should reset the sensor, and the treadmill will be ready to use. Once the cables have been checked, turn on the treadmill again. This should eradicate the problem. 1. 2. 3. When assembling, there are several cables that need to be connected. It is very common for these cables to look like they are connected when they are in fact not fully connected. Make sure that these cables are connected as tightly as possible. The connections may have come apart whilst assembling the treadmill. here is a link to your treadmill web site http://www.yorkfitness.com.au/uploaded/pdf_71T520i%20Treadmill_5562.pdf
Mar 02, 2015 | York Exercise & Fitness
I have just used my LIME MT9 treadmill for the first time and it keeps stopping every few minutes with an E01 error message.
lube the deck belt and proceed according. However you must readjust the speed sensor + Reed switc. Run the software calibration for easy diagnose and fix it. see the diagram attached.
God bless you
Mar 23, 2013 | Lime Pro Lime Mt9 Treadmill Exercise...
Davina treadmill motorised jx-622w wont start display says e00
E00 Means the red magnetic key (the one on the string) is not inserted.. If it is then the magnetic switch may be faulty.
E01 Is an electrical fault - the wire that runs inside the frame is probably crushed while assembling
E02 Means the motor is not running - either burnt out, stuck or the optic device is not functioning correctly.
This are what I found out by trial and error - hope its useful to someone - I'm looking for a copy of the manual for this thread-mill if anyone could send me a scan or photos of the pages - thanks very much.
Mar 17, 2013 | Exercise & Fitness
Slimline treadmill error e01
God bless you
Dec 09, 2012 | Exercise & Fitness
Got carl lewis treadmill MOT566 IT SHOWING ERROR CODE E01 WHAT DOES THIS MEAN
God bless you
Jun 24, 2012 | Exercise & Fitness
Error 100 won't connect to network anymore to use ifit live
Check the power cord to ensure it is connected to the power supply and the treadmill if the power does not stay on or does not turn on. Look at the circuit breaker, located near the base of the unit, to see if the circuit was tripped. Push the switch back in to reset the circuit.
  • 2 Take the key out of the console, wait a minute and place it back in the console to resolve issues with the power turning on and off during use or if the console displays are not functioning properly.
  • 3 Remove the console key and press the "Stop" button to turn off the "Demo" mode, which is often the default setting when the treadmill is first purchased.
  • 4 Reset the incline by holding down the "Stop" and "Speed increase" buttons and putting in the console key. Release the buttons and then press the "Stop" button, followed by the down or up arrows for the incline. This step can be taken if errors are occurring with the incline function.
  • 5 Turn the treadmill "Off" and unplug the unit if errors continue. Wait five minutes and then plug the unit back on, insert the console key, and turn the treadmill "On." This will reset the treadmill and should return to normal funcTION
  • Oct 04, 2011 | Nordic Track NordicTrack Elite 9500 PRO...
    What does e01 mean on a tredmill?
    error 01 var fctb_tool=null; function FCTB_Init_9ca4cf8dddd44654bf538c9ee2a551bb(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_9ca4cf8dddd44654bf538c9ee2a551bb(document['FCTB_Init_0dde2bb1d3294205889a4a3a8539a897']); delete document['FCTB_Init_0dde2bb1d3294205889a4a3a8539a897'] var fctb_tool=null; function FCTB_Init_7ce68d65cfd643589a9add54ad09ffb9(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_7ce68d65cfd643589a9add54ad09ffb9(document['FCTB_Init_1d78963a8d054bb1a1d0dcc13663fe1c']); delete document['FCTB_Init_1d78963a8d054bb1a1d0dcc13663fe1c']
    May 05, 2011 | Sport & Outdoor - Others
    Kettler treadmill "silikon wartung"
    Hi eirik,
    Your treadmill needs lubricating.
    Get a an aerosol with silicone lubricant and spray it under the belt & on top of the ground board.
    Then turn the belt by hand (treadmill switched off!) until you've lubricated the whole belt.
    Next leave the machine running for 5 minutes at 5 KM/H (3 M/H) without any load on it.
    That should do the trick.
    Mar 29, 2009 | Kettler Exercise & Fitness
    Exercise & Fitness Logo
    110 people viewed this question
    Top Exercise & Fitness Experts
    Howard
    Howard
    Sportsmith LLC
    Sportsmith LLC
    Tom Chichester
    Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
