Question about Paradigm PDR 10 Speaker
Have a buzzing noise from my paradigm pdr 10 it works but has this horrible buzzing
Everytime i turn my sub on to watch a film it works but have this horrible buzzing noise from the subs amp
3 Suggested Answers
  • 21 Answers
SOURCE: Paradigm PDR-10 Sub Box
Since this is a sub I assume the sound is not coming from the speaker but is mechanical and coming from the amp in back. The tranformer can be the problem if it has delaminated or may be loose. Try removing the amp and tightening the screws. If there are rubber grommets to isolate the tranformer don't overtighten. www.pardigm.com for contact info and parts. They are very nice. If the noise is coming from the speaker then you are still under warrantee and they will replace it free.
Posted on Aug 27, 2007
SOURCE: Power Indicator Light on Front Doesn't Light
The indicator light needs to be replaced, there is a loose or poorly soldered connection on one of the led's leads, or the circuit providing the signal (voltage) for the light isn't functioning.
Posted on Feb 10, 2008
My Paradigm PDR-10 subwoofer needs a new fuse (1.5amp 250v) but I cant find the physical location of the fuse on the sub anywhere. Ive looked at it for a long time now. Any help? Thanks, Bryan Tal
Try right behind the power panel. Certain models you have to remove amplifier back panel. Then some are soldered on and some are encased in some kind of holder usually by the power input. Be carefull of electric shock. Make sure device is un-plugged while powered on to help with discharging internal capacitors if possible or drain caps with appropriate resistor to drain them safely if possible.
Nov 17, 2014 | Audio Players & Recorders
My Paradigm PDR 12 subwoofer has started to make crackling noises. Is this an amplifier malfunction?
Depends when it makes these crackling noises.
If it's when the sub isn't being driven, then it could be the amp. (Check for bulging capacitors on the amp board). If it's when you move cables about then it could be a broken lead or a dry solder joint on one of the inputs.
If the crackling is when the sub is running then it might be the voice coil has distorted due to being overdriven with a poor and highly distorted signal.
Sep 07, 2014 | Audio Players & Recorders
Subwoffer will not power up
PDR-8 Specifications
Design
Single driver, bass reflex system with critically tuned resistive port and built-in amplifier Amplifier High-current, discrete output, 90 watts RMS
Amplifier Features Soft clipping, thermal protection Frequency Response On-Axis 29Hz - 150Hz Low Frequency Driver 210mm (8 in) extended travel with 38mm (1-1/2 in) voice-coil, aluminum former Low Frequency Extension 29 Hz (DIN) Finishes Black Ash, Light Cherry, Dark Cherry Inputs From A/V receiver/processor or Paradigm X-Series Subwoofer Control Unit mono-sub out or preamp left/right output;From receiver/amplifier speaker terminals or main/satellite speaker terminals Weight 25 lbs. (11 kg) Dimensions HxWxD 13.25" × 9.75" × 15"
(34cm × 25cm × 38cm)
Specifications are subject to change without notice.
© 2016 Paradigm Electronics Inc. Conditions of Use Privacy Policy Unauthorized Dealers WARNINGSouth Africa
Dec 26, 2013 | Paradigm PDR 8 Subwoofer
Paradigm pdr80 no sound
If it is a powered sub, the sub power supply may have failed. There might be an open fuse.
Dec 25, 2013 | Paradigm PDR 12 Speaker
I have a 110v power input Paradigm PDR10 and would like to convert it to 220/240. I'm sure it's a case of change the series connection to parallel on the transfomrer but I'm not sure the exact functions...
I have the same problem. An external transformer would step down the voltage, but it wouldn't help with the frequency, which would still be 50Hz. Paradigm says there's a risk of burnout if an unmodified PDR-10 is run at 50Hz rather than 60Hz
Oct 16, 2010 | Paradigm PDR 10 Speaker
PDR-10 subwoofer has no output. 120vac to unit is
I have exactly the same situation with my PDR-10. Paradigm techs were of no help, don't me to take it to a service centre which i did. Of course when it was there they plugged it in and it stayed on for a day and a half so no problem right? Get it home, nothing, plugged and replugged, got it on once but not for long. Opened up back, everything including fuse looks solid and fine....to naked eye anyhow.
Dec 20, 2009 | Paradigm PDR 10 Speaker
Power problem with Paradigm PDR 10 Subwoofer
Yes it can be.You can check it with ohmmeter the impedance should be 4 or 8 ohms.But if you can disassembly the sub its better then you can see and check everything.My guess is that one of the cables on the speakers connector is broken and its just touching the conntact.
Mar 08, 2008 | Paradigm PDR 10 Speaker
Sep 17, 2007 | Paradigm PDR 10 Speaker
Sep 28, 2006 | Paradigm PDR 10 Speaker
136 people viewed this question
Top Paradigm Audio Players & Recorders Experts
 Grubhead
Grubhead
woodzowl307
Are you a Paradigm Audio Player and Recorder Expert? Answer questions, earn points and help others
