Question about Toshiba e-Studio 232 Black and White Copier
IP address conflict error toshiba copier - Toshiba e-Studio 232 Black and White Copier
5 Suggested Answers
SOURCE: How do I install my scan enabler device for Toshiba estudio232?
With regard to installing your dongle (i.e. memory stick type device):
on the eStudio 232 there are often THREE USB connectors: 2 type A connectors and 1 type B connector (for information on USB connector types see http://en.wikipedia.org/wiki/Universal_Serial_Bus#Connector_types)
You should try insert the dongle into BOTH type A USB connectors (not at the same time, obviously) to see if the SCAN button is highlighted.
NOTE: your dongle needs to be version GM-2070
I had the same problem with a grayed out SCAN button when I first installed the GM-2070 dongle, but when I inserted the dongle into the other type A USB connector ... VOILA, it worked.
I hope this helps.
Posted on Sep 08, 2009
FixinFax
  • 3085 Answers
SOURCE: No IP address was set
Turn off DCHP after setting the IP address
Posted on Sep 23, 2009
  • 643 Answers
SOURCE: Cannot set IP address on Toshiba e stuido 16s
In order to set IP address, make sure printer kit/NIC is installed. Plugged network cable, Press Program button--> Initial Setup-->Network-->TCP/IP to configure IP address. Once finish, back to Network-->Complete to save the settings.
*Machine need to initialize network during startup, once finish initialize network then only u're able to access network settings. A status page will print out by default after finish initialized network.
Posted on Jan 10, 2010
  • 132 Answers
SOURCE: we have a toshiba e-studio
try making the ip on the machine the last 3 numbers 250 if there is no ip confict add a new port in the print driver with the new ip if you do not know what the computers ip is go start,run type ic cmd press enter and the in the window type ipconfig /all that will give you the ip config of the computer. if there are not to many computers on the network check all the pcs and pick a ip add that is not used by the pcs and give it to the copier
Posted on Mar 13, 2011
I have a desktop which is connect to my router and works perfectly fine. I am running win xp pro. I also have a laptop which i connect wirelessly via the router. The problem is when directly connect to...
The ip address conflict is likely caused by a manual IP address that is entered into the printer that is overlapping with an automatic address that your router is giving out. Either switch your printer to DHCP so it gets an automatic address, or reserve the address in the router's DHCP list or pick a manual address to assign that is outside of the range of the DHCP server. Most router will start at address XXX.XXX.XXX.100 so if you pick an address between 20 and 40 then you should not have any more issues with conflicts.
May 11, 2011 | Xerox Phaser 7750DN Laser Printer
Tip
IP Conflicts in a work place
An IP address conflict occurs when two computers on a LAN or the Internet have been assigned the same IP. IP conflicts between two computers normally render either one or both of them unusable for network operations.
How IP Address Conflicts Happen
Two computers can acquire conflicting IP addresses in any of several ways:
· A system administrator assigns two computers on the LAN the same Static IP Address.
· A system administrator assigns a computer a static IP address within the local network's DHCP range (dynamic IP range), and the same address is automatically assigned by the LAN DHCP server.
· A malfunction in the network's DHCP server allows the same dynamic address to automatically be assigned to multiple computers.
· An ISP accidentally assigns two customers the same IP address (either statically or dynamically).
· A mobile computer is put into standby / hibernate mode and then awakened later.
Note that other forms of IP conflicts can also occur on a network. For example, one computer may experience an IP address conflict with itself if that computer is configured with multiple Network Adapters. System administrators may also create IP conflicts by accidentally connecting two ports of a network switch or router to each other.
Recognizing IP Address Conflicts
On most Microsoft Windows computers, if you attempt to set a fixed (static) IP address that is already active on the local network, you will receive the following pop-up error message:
The static IP address that was just configured is already in use on the network. Please reconfigure a different IP address.
On newer Microsoft Windows computers having dynamic IP conflicts, you should receive a balloon error message in the Taskbar as soon as the operating system detects the issue:
There is an IP address conflict with another system on the network.
Sometimes, especially on older Windows computers, a message similar to the following may instead appear in a pop-up window:
The system has detected a conflict for IP address...
On Mac or Linux computers, a similar message will normally appear on screen.
Resolving IP Address Conflicts
Try the following remedies for IP conflicts:
1. For networks where IP addresses are fixed (statically assigned), ensure each local host is configured with a unique IP address.
2. If your computer has a dynamically assigned address, releasing and renewing its IP address can workaround IP address conflicts.
3. If your home router is believed to have a faulty DHCP server causing IP conflicts on the home network, upgrading the router firmware may resolve this problem.
on Nov 24, 2010 | Computers & Internet
We have a toshiba e-studio 3511 that was working fine with wireless but verizon had us change our ip address to install their wireless internet service and now there is a message on the printer: ip address...
Mar 12, 2011 | Toshiba E-Studio 3511 Color Copier
I have a message that say Ip address conflict, what can I do
Windows system error: "an IP address conflict wit...
This error indicates that you have two devices on your network that have the same ip address assigned to them.
If you have have ip addresses manually assigned to your network devices you can open a command prompt and enter IPCONFIG, this will tell you what the ip address is of the device that is giving you the error. This ip address is assigned to another device on your network.
You can either change the ip address of the device you are receiving the error from or find the device with the same ip address and change that one.
Alternatively, if you have a router that that has DHCP enabled you can change the properties on your network adapters to obtain the ip address automatically by going to Network Connections, right click on LAN connection and click properties.
May 21, 2010 | Computers & Internet
Printer communication error
check the network cable... disconnect the network cable and ping the copier... if you can get the copier IP address to respond... then you have an IP conflict... if you plug the network cable back in... turn the copier off and on and still cann't print from any pc... then reset the copier... if you still cannt print from any pc then you need to try changing the IP address... and try again... still doesn't work... change the network cable and try again... still doesn't work... plug a laptop into the network cable and ping the laptop... if the laptop works... the print card is bad...
Dec 12, 2009 | Canon imageRUNNER 7200 Copier
Brother MFC 8860 has ip conflict. How do I resolve this? The issue is that the IP address is different on my computer versus the printer and thus doesn't allow them to connect. Greg
Each IP-address on a network (private in your home, or public on the Internet) must be unique; hence "IP conflict" when two devices (computers or printers or iPod Touch) try to "claim" the same IP-address.
If you have configured a "static" IP-address into the printer, change it to an IP-address that is *NOT* used on your network.
Or, find the computer on your network that is using the same IP-address as your printer, and change its IP-address and reboot it.
In order to connect, your computer and your computer *MUST* have *DIFFERENT* IP-addresses.
Sep 10, 2009 | Brother MFC-8860DN Printer
THERE IS AN IP ADDRESS CONFLICT WITH ANITHER
Identify the peripheral conflicting with the router and change the network address on one of the two. Their setup programs should give you the possibility to do so. The address should look like: 192.168.2.x
x ranging from 0 to 9
Aug 02, 2009 | NetGear WGT624 Wireless Router
IP address conflicting
Have you checked to see if either computer has a static IP address? that might conflict with the DHCP table.
Jun 27, 2009 | Belkin (F5D7230-4) Router (587009)
Kyocera-Mita going offline
Try an updated driver from the manufacturer or see if they have any know issues with 2003 sp2 and the driver.
Hope this helps!
Nov 27, 2007 | Kyocera Mita KM-5035 Printer
Toshiba e-Studio 232 Black and White Copier Logo
394 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
