Question about Huffy 12 in. Girls Disney Princess Single Speed Bike. Purple
Rear wheel not running smoothly.
Hi, i was just wondering if anyone could help me with my bike problem.
I recently noticed when i rode my bike that it was taking much more effort to ride; I also noticed that when i took it inside, the rear wheel isn't spinning smoothly. it spins approximately one-and a half cycles smoothly and then becomes stiff...and then smooth again.
Is it possible to fix it myself? or should i just throw it out? its a malvern...nothing too fancy.
    Genius:
  • 1,689 Answers
Thank you for using fixya, the problem that you are encountering may be attributed to the freewheel (rear) or the hub to axle assembly on both front and rear.
Im currently using a Haro Flightline and used a few. When this kind of problem occurs, you may want to focus on the following:
crank set: remove the chain and check if it rolls freely, if not, try to open the case and look out for broken ball bearings or misalligned parts, then lubricate it.
Rear wheel assembly: remove the chain and the whole assembly from the bike, then check if it rolls freely. If not, same method, check the bearings and the freewheel. allign and lubricate it.
Posted on Jan 04, 2009
1996 Electra Glide Primary Cover Oil Leak
Hi, Tonyce835 that would be 10 ft. lbs. for this scenario you will need your service, parts fiche, and owners manual if you can not find the best tool you ever bought for your Harley, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
How to Fix Primary Oil Leak on Harley
http://www.carlsalter.com/pdfs/Harley%20Davidson-HD%201984-1998%20FLH-FLHT-FXR-FXSB-FXEF%20Service%20Manual.pdf
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
http://www.harley-davidson.com/content/h-d/en_US/home/owners/maintain-your-bike/owners-manual.html
Instant Tech Relief To speak to me personally absolutely "FREE"
Jul 17, 2017 | Harley Davidson FLHTCUI Electra Glide...
Hyosung GT250R Tacho not working
These bikes are never senen with many miles on them when for sale, invariably they have issues uncommon to a newer bike, this sis due to the workmanship and metalurgical issues etc, they are clones but thats where the similaritys end, they nevr last from all I ever saw of these bikes.
If you mean loses power on hills due to clutch slippage, the springs i know get weak fast and lose tension sufficient to engage fully thus allowing plates to slip and losing power to the rear wheel, if you mean otherwise nobody can tell you this way correctly.
Feb 25, 2012 | 2007 Hyosung GT250R
Bike turning smooth on left side but is not smooth when turning right. its hard to turn right
Hi, check :
rear wheel for alignement
front tyre for pressure and condition (if you notice diferent wear between left and rigt side, replace it)
did the bike sofered some crash?
also chek your front suspention
Sep 13, 2011 | 2008 Yamaha FJR1300A
I have a 2005 Honda VT1100 Sabre with 22,000 miles. I bought the bike with 12,000 on it. I keep it maintained at all times and of course "rub" on it constantly. Anyway, when I first bought the...
Hi, Roadwarriorc and the usual suspects are:
1. Wheels and or tires worn or damaged.
2. Engine/transmission/vehicle not aligned properly.
3. Primary chain is badly worn or links too tight as a result of insufficient lubrication or misalignment.
4. Engine to transmission mounting bolts loose.
5. Upper engine mounting bracket loose.
6. Ignition timing incorrect due to a poorly tuned engine.
7. Internal engine problem flywheels have shifted.
8. Broken frame.
9. Stabilizer links worn or loose.
10. Rubber mounts loose or worn.
11. Rear fork pivot shaft nuts loose.
12. Front engine mounting bolts loose.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Vibration on VT750C
http://www.fireblades.org/forums/honda-cruisers/96304-unmanagable-vibration-shadow-aero-vt1100c.html
Honda SHADOW VT1100 Owners Workshop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT1100C2 Owner Manual
Apr 12, 2017 | 2004 Honda VT 1100 C2 Shadow Sabre
2003 yz 125 keeps breaking the c shaped locating clip which is on the kickstart assembly. Not the return spring. Replaced assembly with a completly diff. one kickstarter engaged, bike started. Only rode it...
Hi, Snowleapo932 no gear should wobble it needs to be repaired for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your problem. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
YAMAHA YZ125 Owner Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
yz 125 tips and tricks YouTube
Yamaha YZ 125 02
May 05, 2011 | Yamaha YZ 125 Motorcycles
1983 Yamaha XJ Maxim 750. Rear tire rubbing on driveshaft
Hi, Blzofaz for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
rear tire rub normal
How to remove the rear wheel of your shaft driven motorcycle
Yamaha XJ750 Owner Manual
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
May 25, 2010 | 1985 Yamaha XJ 700 S Maxim
Hi im JACK. i am thinking about buying a 1998 KAWASAKI KLX300 but there is no spark is that a common fault. because there is no spark i can not hear it run and what else shoud i check on this bike because...
Jack, find a newer bike. Most dealers will not work on a bike over ten years old. Parts availability is one reason. Another is the workload in the shop and the need for the mechanics to stay current with the new models coming out yearly. If they fixed every bike that came in the service backlog would be really bad.
The KLX 300 was never a popular bike. Not many still arround. I would not buy the bike until I rode it for an hour or so. You gotta check the suspension, handling, power, shifting smoothly, shocks, forks, power valve, clutch, water pump, oil pump, radiator, electrical system, front and rear brakes, carb, rings,
Jan 20, 2010 | 1998 kawasaki KLX 300
Running better in cold
Cold air is denser and you'll get more air in the bike and the engine compensates with more fuel. It's cold as hell at 20F outside but damn does the bike run crisp!,,
Nov 10, 2008 | 2005 Factory bike Chrono SM 250
Huffy 12 in. Girls Disney Princess Single Speed Bike. Purple Logo
776 people viewed this question
Top Huffy Cycling Experts
Michial Gueffroy
Charles T Nevin
Charles T Nevin
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
