Question about Saws
KV-50 band saw RPM's drop when cutting - Saws
  • 22 Answers
SOURCE: band saw not cutting square
Rather than type out the solution again I'll direct you to here: http://www.fixya.com/support/t1751837-jet_414458_hvbs_saw_saw_cuts_round
Posted on Apr 02, 2009
  • 67 Answers
SOURCE: Band saw blade wanders.
cut freehand. A bandsaw blade will always run off to one side or the other, even using a fence.
The rip fence is intended for re-sawing only, and very thin strips
Posted on Jul 24, 2009
  • 4088 Answers
SOURCE: problems with my band saw bs100
Look for any gouges in the metal surface that have metal projecting above the milled surface. Also, file or grind away any sharp edges along the miter gauge track. If the cut surface is very irregular, the blade may have overly coarse teeth, or the blade guide rollers may not be holding the blade firmly allowing the blade to wander while cutting. Hope this helps.
Posted on Oct 24, 2009
efs_perpends
  • 1996 Answers
SOURCE: when cutting wood with band saw saw will cease up
This could have many causes...depending on the model of saw, the wood being cut, the blade you're using, etc. etc.
Check that the blade is correctly installed, up to tension, and sharp. Make sure the wheels run smoothly on their on, and under power. Check the horsepower of the motor, and make sure to keep the feed rate down within the motor's capacity. Finally, don't twist the work being cut to a smaller radius than the size blade will handle, or you will bind the blade in the cut.
If you are cutting wood with pitch or grain that is likely to be under tension, perhaps you need to insert a wedge into the cut to prevent the work from pinching the blade as it continues the cut.
I hope that leads to a solution. Sometimes all you can do is feed slowly and be patient...
Posted on Jan 26, 2010
  • 111 Answers
SOURCE: Band Saw blade coming off
there should be a tensioner nob to adjust to blade, to put tension on it, it may be under the machine.
Posted on Mar 16, 2010
Saw starts runs good then when i start cutting it
Hi Jason:
Make and model might help but here's two ideas:
1) Remove muffler and clean it. They can get plugged up with carbon and the saw will run at low RPM but will quit because of excess back pressure when you try to rev it up.
2) Set the high and low speed carb settings. Start the saw then gradually increase engine speed until full throttle. Screw the hi-speed needle in slowly. If RPM immediately drops, back it out until Rpm increases, then starts to drop. Screw back in until peak rpm reached, then starts to drop. Back out to peak, then 1/3 turn more.
Set low speed so engine runs smoothly but chain does not turn.
Hope this helps.
Feb 01, 2016 | Garden
Mbs45 blade undercuts out of square, twist in 2x2 1/8" tubing
I believe Black bull band saw is a Taiwan imported saw. They are even cheaper to HF band saws. This band saw have so many issues; make sure you align the guides, tune it up and use good bi metal band saw blades. I suggest you use the Haltbar 601 bi metal blade. I'm using Haltbar and I'm getting really nice cut.
Jun 18, 2014 | Buffalo Tools Black Bull Metal Cutting...
WhenI saw a piece of 1/4" basswood the saw squeals like crazy. Otherwise, I love the saw.
There are several factors why band saw blades squeals while cutting. Check this blog for some pointers. I am using a hard back carbon band saw blades for rough cutting. The 201 Series Haltbar blade of http://www.sawblade.com really worked out well to me.
Oct 30, 2013 | Ryobi 9 in. Benchtop Band Saw
Band saw motor won't start just hums
You will need to take the motor out and check the brushes on the back also check the bearings you may need to disassemble the motor to repair.
Apr 05, 2012 | Craftsman 12 Tilt Head Band Saw Owner...
What do i need to do to adjust the tension on my Delta 14" band saw
IN THE TOP COVER THERE IS A ADJUSTMENT NUT,KNOB OR SCREW. TRICK IS NOT TO OVER TIGHTEN IT. WHEN CUTTING THE BLADE SHOULD NOT WANDER. THAN THAT'S PERFECT .. JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA
Jun 25, 2011 | Delta 28 640 20" Single Phase Wood Cutting...
What is the motor rpm on a skil 3385-01 rt table bandsaw?
This Band Saw is designed to use a 1700 RPM motor. It
is wired for operation on 110-120 volts, 60 Hz.
Taken straight from the Owners Manual found here.
https://mdm.boschwebservices.com/MDMCache/English%20[US]//t10/0000001/r01047v-1.pdf
Let me know if you need anything else!
Nov 24, 2010 | Skil 3385-01-RT Factory-Reconditioned 9"...
My drop saw runs at 5000 rpm .most 14" discs are only rated to 4400 rpm. Are there 14"discs rated at over 5000rpms
go 2 home depot and buy Norton brand blades a lot of blade suppliers are putting a pic of cutoff saw on the blade itself 2 tell u its 5400 rated home depot and Norton r the cheapest and lasting
Jun 29, 2010 | RTO 20 14" Abrasive Chop Saw Blades Metal...
Reduce bandsaw speed to cut metal
My old delta has the transmission on the back for cutting metal, and it is geared way down for power, 1140 would be way to fast, It is more like 40 rpm. I don't know if even a set of step pulleys would slow you down enough. Depends on the metal. I have the step pulleys too, but never bother to change them. The transmission, you just pull out the lock in the center of the pulley and it throws it into back gears. real nice, has an oil filled gear box on the bottom. Everybody wants my band saw!
Feb 23, 2010 | Delta Woodworking Delta Rockwell 14 Inch...
Jun 28, 2009 | Ryobi 9 in. Benchtop Band Saw
Blade width usage
Blade Width is important when purchasing a band saw. Most saws accept narrow 1/8" blades for cutting detailed designs and tight curves. Better saws also accept wider blades. Wide blades don’t flex as much as narrow ones, but they make accurate straight cuts in thick stock quicker. There are also some wide blades available that can cut metal.
Aug 27, 2008 | Milwaukee Tool Milwaukee 6230 Deep Cut...
Saws Logo
19 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
