Question about Konica Minolta Office Equipment & Supplies
Konica minolta bizhub 420 error d282 - Konica Minolta Office Equipment & Supplies
5 Suggested Answers
Bubbabear64
  • 2794 Answers
SOURCE: konica minolta bizhub C252 printer Problem
It is supported for Vista according to this chart
Here is the drivers for 32 bit Vista
Posted on Jul 06, 2008
herminio_hal
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
herminio_hal
  • 210 Answers
SOURCE: How to setup scan to pc on Konica minolta bizhub 350 Error ED09C7
Your configuration sharing SMB folder is incorrect. Create desktop folder rename all upper case SMB right click on the folder and click sharing and set full control to everyone. Go to web brouser type in the ip address of the printer log on to administrator password 8 zeros or 12345678 and change the setting.
firecontrol7
  • 6696 Answers
SOURCE: what does code 2454 mean on the konica minolta
Developing motor for the Black, working in conjunction with Toner Control Sensor.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jul 31, 2009
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
Error code d282
Communication abnormality between the overall control board
(OACB) and the scanner drive board (SDB). When the power switch (SW2) turns on, there is no SDB response.
Check the connection between these two boards or one is bad! Have tech check it out
Jun 25, 2014 | Konica Minolta Bizhub 500...
Error code d282 in bizhub hub
what model Bizhub????????????????
Jun 25, 2014 | Konica Minolta bizhub Office Equipment &...
D282 error code konica minolta bizhub
what model Bizhub????????????????????
Error code d282 bizhub 420
communication error between the main control board and the scanner control board the scanner is that what is below the big glass particularly the mirrors and exposure lamp (Bright light) something is not talking!!!!
Jun 25, 2014 | Konica Minolta bizhub 420
Error 2803 konica minolta 500
TCR output abnormality.Toner control ratio abnormality error code.Restart the machine if code removes then its OK otherwise simply replace the developer and execute TCR adjustment again.
Dec 11, 2012 | Konica Minolta bizhub 420
How to reset fuser unit for konica minolta bizhub 420
In Tech mode :
System 1
Initialization
Counter data fixing unit
Start button
Power cycle the copier
Jun 22, 2011 | Konica Minolta Office Equipment & Supplies
C5201 error konica minolta bizhub 420 i removed fuser unit after that coming like this error ple help me
reconnect again your fusing unit. then before you ON your machine you long press utility/counter then press the small circle black, then press trouble reset.off/on
Mar 15, 2010 | Konica Minolta Office Equipment & Supplies
Bizhub 420 error code c-2801
error code 2801 plesce relese the code prectical met
Feb 08, 2010 | Konica Minolta Office Equipment & Supplies
241 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
