Question about Simplicity Garden
Simplicity coronet will not move
Engine starts right up! Runs great. But the transmission wont engage. It worked fine before I removed rear wheels to fix two flat tires due to needing new valve stems. Put tires back on and now it won't move when I put it in forward or reverse.
SOURCE: Transmission won't engage
My Craftsman 24 hp twin 42in cut motor runs ok as well as the lawn mower. However will not move forward or backwards something is not connecting.
Posted on Oct 12, 2008
SOURCE: Hydrostatic mower goes in reverse but not forward. Only 73 hrs on it!
On my hydrostatic there is an adjustment on the forward/back lever which can be made to run all reverse or all forward. Normal setting gives both of course. Look at that adjustment. Maybe something let go.
Posted on Oct 14, 2008
  • 79 Answers
SOURCE: lawnmower will not move in gear with motor running
Hi
Check to see if any oil leaks between rear wheels where the tractor was parked. Also make sure hydrostatic disengage lever, at rear of tractor by hitch, has to be pushed in.
Posted on Apr 06, 2009
libaredneck
  • 119 Answers
SOURCE: MTD RIDING MOWER with 618-0229 transmission.
sounds like you need a new drive belt
Posted on May 04, 2009
SOURCE: Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
Posted on May 15, 2009
97 4 runner wont move,no noises just like your in nuteral.Fluid is fine i can move it in 4x4 what can i look for before my girl tells me to dump it
To understand you
the car runs but when you engage drive it doesn't move
however if you move the selector from 2 wheel drive to 4 wheel drive it does move
is that correct
logically if that is the case the auto transmission is working but the drive to the rear wheels is not functioning
That would point to a problem in the , diff connection ( broken rear axle )
by engaging 4 wheel drive you are moving by the front diff only
Oct 01, 2016 | 1997 Toyota 4Runner
Why wont my john deere d140 move when I ngage the double foot pedal
The drive belt may be broken, or it may have slipped off a pulley.
Aug 03, 2014 | John Deere Garden
Simplicity
The key on the shaft may be sheared. Remove the wheel and check the keyway.
Oct 20, 2012 | Simplicity Coronet 13.5/30 Riding Mower
Craftsman lt 2000 mower runs fine but wont move
is the lever on the rear disingauged the one that allows you to push it
Jun 06, 2012 | Garden
John deere stx38 wont move transmission locked up?
Engine OFF, raise drive wheels and check if transmission is locked
Jul 14, 2009 | John Deere Garden
Simplicity mower stalls when brake released
There is another safety switch connected to the parking/service brake. Check that one too. Sounds like its the one.
Jun 22, 2009 | Garden
Hello, 1986 Toyota 4X4 Truck 22R carb engine manual transmission. My son was driving it and the rear wheels locked up. Driving in 2 High mode. He got the truck pulled over to the side of the road using 4X4...
I've seen a similar issue on other transmissions where the shifter slips out of the slots in the shift forks, either due to shifter bushing wear or just general wear on tte trans. It can usually be remedied at least temporarily by popping the shifter top off the trans and resetting the forks all back to nuetral and then reinserting the shifter. It gets jammed when two forks are trying to engage two different gear sets.
On one of the 4x4 sites, they tell you how to replace the shifter bushings, cheap fix if you are lucky.
Good luck.
Dec 09, 2008 | 1986 Toyota Pickup 4WD
Garden Logo
324 people viewed this question
Top Simplicity Garden Experts
Dennis Key
Dennis Key
Pcm2048
wadingriver
wadingriver
Are you a Simplicity Garden Expert? Answer questions, earn points and help others
