Question about Dell (E210882) Motherboard
Dell inspiron 1525 no display
I hve dell inspiron 1525 but there is no display,when i checked the mother board one mosfet no 4s00b is not working . i need a equivalant mospet for the mother board. kindly suggest where can i search for the above mospet.
  • 39 Answers
I have recently worked on an inspiron 1525 that the dispaly got cracked. it works perfectly if it is hooked to an external display. would you like me to see if it is avalible for sale?
Posted on Feb 16, 2009
Inspiron 1525 mother board problem can i fix?
It does seam like a mother board issue ..but I suggest to check the CPU ..if you can get one with a similar socket ..even if it is smaller on properties...just to see if it works ..cause usually when you do have power indicators..and the fan works ..it shows that the motherboard have power ..so it may be ok ..and only the cpu may have issues or something ..So my advice is to see the socket time (see the specs for the laptop ) ...get another one ...second hand but be sure even if it is a cheap one ..that it is functional ..and try it on ..It might surprise you ..In my oppinion ..this is a clear cpu failure..(remember that the fan is powered up from the motherboard..and if this one is faulty there isn't power present .on the fan nor in the indicator led ..
Nov 22, 2011 | Dell Inspiron 1525 Notebook
My dell 1525 charging ic is bad pls how can i locate and change it?.
Sorry if its an IC the best thing you can do is replace the mother board
Jun 16, 2010 | Dell Inspiron 1525 Notebook
How do I find directions on how to change the fan on the dell inspiron 1525
in order to remove the fan on 1525 you have to remove the mother board. see the step by instruction here in dell site http://support.dell.com/support/edocs/systems/ins1525/en/SM/sysboard.htm#wp1180315
Feb 10, 2010 | Dell Inspiron 1525 Laptop
Problems with Dell Inspiron 1525 Intel Core 2 Duo T7250. My lcd won't display anything but an external moniter will work when hooked up? Checked all drivers are fine! what to try next?
LCD displays have a florescent light, if doped the light may be broken, further there is a support pc board in the unit that produces the high voltage for the lamp, this may also be at issue check the lamp first because it is the easiest first step, then with a meter you can check to see if the voltage is present at the lamp, if not this pc board can be purchased and replaced
Jan 27, 2010 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
MY DELL 1525 TURNS ON AND THE NORMAL BLUE SCREEN APPEARS. THEN ALL OF THE SUDDEN IT GOES BRIGHT GREEN, THEN BRIGHT YELLOW, AND STAYS BRIGHT YELLOW
Please connect your laptop to an external monitor and see if the output is the same. If it displays fine on the monitor, then we are looking at either a screen cable problem or a screen problem. If the display is the same as on the laptop, then it is a problem with the display adapter on the mother board.
All the best.
Jan 14, 2010 | Dell Inspiron 1525 Notebook
Dell Inspiron 1525 on board mic not working in win 7
download the driver from the maunfacturer site it will work when it is installed
Oct 13, 2009 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 won't turn on
check the dc power jack connector, open the board. but if under warranty don't open it, bring to warranty..
Jun 05, 2009 | Dell Inspiron 1525 Laptop
CANNOT INSTALL AUDIO DRIVER AFTER CHANGING VISTA TO XP IN DELL 1525 LAPTOP, PLEASE GIVE ME A SOLUTION
Here is a set of links to follow to get the appropriate drivers for XP for the 1525. You also might want to check Dell's site they have a list of drivers available for XP and the components.
http://support.euro.dell.com/support/topics/topic.aspx/emea/shared/support/reinstall/en/reinstall_center?~ck=ln&c=uk&l=en&lnki=0&s=gen
Follow this simple Installation step to downgrade Windows Vista to Windows XP.
a. You have to prepare SATA Driver on your USB Disk. You may get the Dell Inspiron 1525 SATA HERE
b. You have to prepare Dell Inspiron 1525 Wireless Card Driver as well known as Broadcom BCM 4311.
c. For Dell Inspiron 1525 Webcam you have to get Creative Labs Webcam that you may get it in the Windows Update Sites.
d. Get Marvell Yukon 88E8040 PCI-E Fast Ethernet Controller drivers.
e.
Video Card Driver Intel GM965
Dell Application Software Quickset
Ricoh R5C833 Flash Drive controller Driver
Sound Audio Driver Dell Inspiron 1525 SIGMATEL STAC 92XX C-Major HD
Download Intel Chipset
Dell Inspiron 1525 Modem Conexant D330,HDA,MDC,v.92,
Touchpad
Notes: After installing windows XP, you have to prepare windows Downgrade XP patch for Dell Inspiron 1525 before installing Dell Wireless 355 Bluetooth Module and finish Dell Inspiron 1525 driver for Windows XP Installation. Enjoy Xp on your Dell Inspiron 1525 Notebooks.
Jan 29, 2009 | Dell Inspiron 1525 Notebook
Dell (E210882) Motherboard Logo
1,727 people viewed this question
Alun Cox
