Question about Canon Office Equipment & Supplies
Canon IR 3045 Error E000007
Error E0000007
Cogz
  • 1326 Answers
SOURCE: I have a problem with code ''E000007-0000'' (canon IR2230)
A E-000007-000 means that the fixing film in the fixing unit can not find the "Home Postion" for the film. Most likely the fixing film is ripped and the film has proble moved to one side. Basicly you are going to have to have the film adjusted back to HP or the film needs to be replaced. Have you seen any little pieces of thin Black plastic come out of the copier, also is the toner not bring fixed into the paper.... Good Luck..... You may need to call in for reinforcements to solve the code... It will not clear till it is repaired
Posted on Apr 28, 2009
  • 114 Answers
SOURCE: Canon Imagerunner 3300G Error E000007-0000 what
E007 0000 An error in the rotation of the fixing film is detected. The reading of the main thermistor is 100°C or higher and, in addition, the fixing film sensor does not detect the rotation of the film for 6 sec or more while the fixing motor is driven. Main cause The fixing film sensor (PS45) is faulty. The DC controller PCB is faulty. Caution To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR. most of the time the fixing film is torn or slipping
Posted on Apr 20, 2010
canontech
  • 1219 Answers
SOURCE: Describe your canon e0000007 error Problem
E007 means that you have to change fixing film, because white rotation marker is worn out, or you have pressure problems and fixing film dances all over the heater.
TIP: change whole fixing film assy!Check/replace pressure rollers bushings!
Posted on Aug 09, 2010
spinal
  • 287 Answers
SOURCE: my cannon ir 2018i has error code [E000007, we've
Hi robin,
Hope you are well. I participate in the FIXYA forum to help people, and it makes me smile when when I can help folks avoid costly repairs. I don't get paid, (yet) :-) despite the fact the fact I am rated as expert/guru. Anyway.... I dont have good news. Your copier (as all do) has an assemby called a fixing unit/fusing unit. This is an area that by heat and pressure "bonds" the toner to the paper. Because of the extreme heat, all copiers monitor this assembly closely. Your error code means that the copier cannot accurately determine the speed of the fixing assmbly. Which would be like letting an iron rest in one spot rather than moving back and forth across the clothes. The fixing assembly must be replaced.The part # is FM3-3651-000. The first problem is that Canon wont sell parts like this to the general public. Then of course comes, who has the ability to replace it, as it is not really an intuitive repair. It could be done by a layperson, but....... I am so very sorry than I could not "FIXYA" but I hope I have given you enough info that you you won't be in the dark when and if you decide to seek professional help. All dealers have different rates for labor and parts markup. My company charges $150 an hour. The part is about $100. $250 sounds like the ball park. Please be kind enough to provide as favorable review to my time and help as you can when you report to "FIXYA". I wish you the best. SPINAL
Posted on Jan 20, 2011
muleskinner2
  • 270 Answers
SOURCE: photocopy michine canon IR 2025
This is the standard Canon code for failure of the fixing film to rotate in the fuser. It is most likely damaged and the fixing film assembly part will have to be replaced. Once replaced the code should clear itself after power cycling the copier.
Posted on Jun 21, 2011
Error code e0000007
solution E732 scanner communication error
May 25, 2012 | Canon ImageRUNNER 3570 Copier/Printer
Hi guru, my canon ir4570 had E000110-0001, should I replace the laser unit? and sometimes when copier is ready to scan, immediately had error E0000007-0000 and the paper position is jamm under the fixing,...
code 110 is for laser polygon motor you should replace the unit. for problem 007- check fixing film if it is ok then open the unit and take out fuser film apply mixture of some white grease and fuser oil(silicon oil) and put back the film and unit.hope this helps you.
Jan 24, 2011 | Office Equipment & Supplies
Aug 05, 2010 | Canon imageRUNNER 3035 Black and White...
Error code E000007-0000
I have machine of canon ir3300 this time show this problem in machine E0000007-0000.
Jan 12, 2010 | Canon imageRUNNER 3035 Black and White...
1,190 people viewed this question
old marine
old marine
