Question about True Refrigerators
True 3 door refrigerator model#GDM-72 door does not self close
Hi, I lost a part of the true cooler model gdm-72 door part that let the door side itself to close
Posted on Jan 26, 2013
  • 79 Answers
SOURCE: where do i find the starters for the florescent
They should be located under the front access cover below the door. Under that cover there may be another smaller covered box that they may be located in.Make sure you disconnect the power source before removing any covers.
Posted on Nov 12, 2009
  • 906 Answers
SOURCE: GDM-41 Refrigerator: True GDM-41 Refrigerator getting too cold...
good day,
hope this link below will solve your problem.
ref
Posted on Aug 03, 2010
heatman101
  • 43501 Answers
SOURCE: Some of the refrigerators True
If you check into it further I think you will find that the units are low on freon and the coils are froze up causing the leaks....
Turn them off let them defrost and then have the correct charge placed in the system.....
They will work well, and also save you money because they will run much less...
heatman101
Posted on Dec 27, 2010
domotek
  • 591 Answers
SOURCE: I have a GDM-26 True refrigerator here at work. It
depends in which country you are??? you could replace the seal your self for about 20-30$ in Canada/USA, does it make a suspect sound?? it could be the compressor not working properly, a new fridge goes for about 200$ & + where i live...
Posted on Feb 13, 2011
heatman101
  • 43501 Answers
SOURCE: I have a True refrigerator
You will need to find out why the unit is not shutting down properly....
It may be that the thermostat sensor will need to be placed in a different spot...or the temperature may just need to be raised higher...
Does the thermostat turn off the unit if the temperature is raised??? If so, then place a thermometer in the cooler and then adjust the thermostat to 38F by that thermometer and not by the t-stat calibration, it may be off even if it is new...
If the t-stat is not cycling the unit then you will need to use an electrical meter to trace out the power to the unit and find out why it is not shutting down...
heatman101
Posted on Mar 31, 2011
Check water line good pressure to connection does not want to go go true the black box on the back
Free True Manufacturing Company Refrigerator User Manuals
kitchen.manualsonline.com/manuals/.../true/true_refrigerator_product_lis...
Products 1 - 33 of 33 - True Manufacturing Company Refrigerator GDM-3. True Refrigerator Swing Door Installation Manual. Pages: 0 Saves: 0. See Prices
True Manufacturing Parts and Manuals
Dec 14, 2015 | True Refrigerators
Replace gdm capillary tubes
Shouldn't normally need replacing. Reclaim the gas, cut the capillary end at the drier, and force dry nitrogen thrugh the suction side to clear any blockage in the capillary. Fit a new drier, braze the capillary end and vacuum the system before regassing
Apr 26, 2014 | True GDM-72-RC Refrigerator
Model GDM-69
A GDM 69 three doors. Each door closes using a string attached to a weight, which runs through pulleys or copper tubing, and is held to the top of door. The pulleys or copper tubing can be accessed by removing the aluminum siding located inside cabinet on either side. The left side contains the pulley and weightfs or left and center door, the right for right door (each held on by 4 1/4 screws) . To make the door close, simply make sure string is attached to weight, running though pulley, and attached to top of door.
Nov 07, 2013 | True Refrigerators
Water dripping from inside top to bottom of cooler what is causing this and how can i fix it?
Coolers like yours create a lot of condensate. Every time the door is opened warm moist air enters and changes back to a liquid state on the evaporator coils behind the fan and area you see moisture dripping down from top and back wall should be going down a drain pipe to the bottom of cooler and into a pan where a fan blows warm air over the condensate/water returning it back into the store or business that the cooler is located. Looking inside there shoud be a tray or pan that is at the base of the evaporator. True uses different parts but you need to see why the water is leaking from. If cracked tray or line blockage causing overflow into the cooler. Click Here=> Leaking Refrigerators and then again here=> Leaking Refrigerators! This will help you get a better idea of what I am talking about, if helpful please rate. True MFG. does not share their information to me. I would need to be their registered customer to get answers. Click Here=> E-mail True Technicians I also think if you have questions for them they ask for your model number as a reference. They Will answer you just need that number along with GDM-72-RC I will be here if you have questions, Thank You, Sea Breeze
Oct 13, 2011 | True GDM-72-RC Refrigerator
Why won't my inside lights come on in my True GDM-72
usually controlled by a switch located either in the door hinge or at the top of the door. Be sure the bulbs are good and of the correct voltage.
Start there and let me know if I can be of further help.
Mar 24, 2011 | Refrigerators
I like the wire diagram from 3 door freezer swich to lights inside
http://www.truemfg.com/index_en.aspx?language_id=1&event_id=401
Go to "Support" and then do the "Ask the True service Dept." They will need your model and serial numbers and they will send it to you.
Jan 11, 2010 | True 72 cu. ft. / 2039 liter Commercial...
Where do i find the starters for the florescent lights on a true gdm-72
Nov 12, 2009 | True GDM-72 Refrigerator
Help?
turn thermostat all the way to the left to turn it off. restore power and see if it stays on and inside fan is running. Then turn thermostat to rite to turn on compressor. If the power trips when turning thermostat back on, the compressor may be bad. :(
Dec 27, 2007 | True GDM-41 Refrigerator
Refrigerators Logo
166 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
