Question about Garmin Nuvi 360 Bilingual GPS Navigator and Personal Travel Assistant GPS Receiver
Screan on 200w garmin reads "no detailed maps found"
The garmin worked 100% in the UK.It is 10 months old.I loaded South Africa and now the garmin no maps at all.
  • 385 Answers
Check your menu-maps-map info,
Tich the box
Unit I.D. and serial number needed to activate.
switch off and restart.
Regards.
Posted on Apr 16, 2009
Cannot obtain any addresses on my GPS
I took the Garmin back to the retailer and they gave me a new memory card, seems like the other card did not have any maps stored on. Garmin is now working 100%.
Thank you very much for your response.
Regards
S Reddy
Sep 11, 2009 | Garmin GPS
USA Garmin nuvi 200. Can I download Ireland map?
You will have to buy a version of European maps. After you download them into your Garmin it will work just like in the US.
Here is a link I found for you. It looks like you need to buy all of Europe but there may be a way to just buy individual countries. Best wishes on your trip.
Wide and way cool, nüvi 200W shows you the way with detailed maps on a bright ... Garmin Garage" vehicles compatible (download car-shaped icons to your device ): yes ... nuvi 200W, Eastern Europe, 010-00656-25. nüvi 200W, Italy, Greece ...
https://buy.garmin.com/shop/shop.do?pID=9122
Aug 17, 2009 | Garmin nuvi® 200 Car GPS Receiver
Garmin Nuvi 200 Maps Disappeared
Hope this helps!
I wanted to add maps to my 250W. I found the maps I wanted on a Torrent. However, many searches around various forums never revealed how to install these. Found the following through reading and experimentation.
1. Downoaded map image file GMAPSUPP.IMG. Download also gave me "Use code XXX when generating unlock code for maps"
2. Downloaded Garmin Unlock Generator 1.3 by JetMouse
3. Looked on my GPS to find the UnitID
4. Entered the UnitID into Garmin Unlock Generator. Ignore the GM XT device unlock code and the top Generate button.
5. Selected Map Product as Custom and entered the code given for the downloaded image file.
6. Hit the bottom create button to generate a 25 digit code.
7. Download Img2Gps and run
8. Click Load Folder to load the image file. Select the tick next to it.
9. Check the Use Unlock Key option and paste the 25 digit code in.
10. Load a blank SD card into your Garmin
11. Connect the Garmin to your PC using a USB cable. You should see two dirves in windows: one is the Garmin and the other is the "Removable Disk" SD card.
12. Create a folder called "Garmin" on the SD card
13. Select Folder/Card in Img2GPS
14. Click "Copy Maps". Select the folder /Garmin on the SD card. You may need to click copy again.
15. Upload will take a while.
16. You should now see a file GMAPSUPP.IMG on the SD card in the /Garmin directory.
17. Create a new text file called GMAPSUPP.UNL in the same directory (make sure it does not have a hidden .txt extension).
18 copy the 25 digit unlock key into this file.
19. Close the file.
20. Disconnect the Garmin.
21. On Startup it should load your original maps and the new ones.
May 28, 2009 | Garmin nuvi 200W GPS Receiver
Does Garmin GPS 295 contains Maps for Africa and the Middle East
Hi there -
The GPSMap 295 can only have one region at a time - North America, South America, etc. You can purchase an updated database specifically for Africa and the Middle East - it's about $50 USD. It will erase whatever region you have in there right now (you can't store Africa/MidEast with America, for instance. It's one at a time.)
The Garmin Website:
http://shop.garmin.com/aviation/databases/
lets you download new Jeppesen databases to your GPSMap 295. Select your model, then select which region you want.
***Before you buy:*** You'll have to have the data cable to connect it to your computer. Without that, you will have no way to update the maps and database.
If you do have the data cable, the process is very easy - just follow the instructions carefully, and make sure all the numbers they ask you for are correct. I just did mine today. Good luck!
Mar 24, 2009 | Garmin GPSMAP 295 GPS Receiver
My garmin just worked yesturday and now reads no detailed maps found that support routing.
check to make sure you have a map set selected ?
settings -> Map --> map info - make sure there is a checkmark next to the map data set (info for a nuvi 350 but it might apply for you)
Mar 18, 2009 | Garmin nuvi 200W GPS Receiver
Loading Australian Maps on Nuvi 200
She can purchase the City Navigator Australia DVD and load the Australian maps onto an SD card. Insert this into the unit and she'll then have both S Africa and Australia maps.
Mar 10, 2009 | Garmin nuvi 200W GPS Receiver
Contact Garmins Tech support hot Line they will walk you through the process and if they can't fix it over the phone they will send you a disk that will completely fix the "NO detailed maps found that support routing" I have contacted them with the same problem and the disc was free of charge.
Jan 01, 2009 | Garmin nuvi 200W GPS Receiver
GPS Logo
95 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
