How can I get my impega calculator to go put in the decimal places
SOURCE: decimals
This is an easy one and happens often. Simply depress the orange "f" key and then select how many decimal points you want on the numeric keys. For example, for two decimal places you would push "f" 2. I usually keep mine on 3, but you can take it from here.
Posted on Apr 25, 2008
SOURCE: I am trying to get
You should press SHIFT then MODE (setup). Then press 2. Done! If you want to change it back, just do the same again, but press 1.
Posted on Sep 01, 2008
SOURCE: sharp el506d calculator has the decimal in the wrong place.
Try pressing the FSE button to switch between Fixed, Scientific, Engineering, and Normal displays. When in Fixed display, you can use <2ndF> < TAB > then enter a number from 0 to 9 to choose the number of decimal places in that display. To reset EVERYTHING to factory defaults: With the calculator off, press and hold these three keys: <2ndF> < ) > < ON/C > then release all three. The calculator will go through a series of tests (it takes a few seconds) and then be at its factory defaults. I have uploaded the manual for this calculator at www.theusermanualsite.com.
Posted on Dec 09, 2008
  • 7 Answers
SOURCE: calculator won't show decimal places
Haven't heard of it giving nearest whole numbers before. But have you tried pressing SHIFT and then SETUP (upper right hand corner next to ON button) and then pressing 2 (LineIO)? Or perhaps you're in different MODE?
Posted on May 03, 2009
SOURCE: I cant change my decimal place Sharp Calculator model EL-531WH
Set up > TAB > then select how many numbers you want after the decimal place.
Posted on Jun 16, 2010
Percent sign
Despite the goodies this calculator has, it does not have a key for the percentages.
To convert a decimal number to %, move the decimal mark two places to the right and put the % symbol.
0.257 =0.257* 100%=25.7 %
To convert a percentage into its decimal equivalent, move the decimal mark two places to the left and remove the % symbol.
89.32% =0.8932
Feb 03, 2014 | Texas Instruments TI-84 Plus Silver...
I want to set the decimal place without using the decimal key--example: hit the 1234 keys and the shows $12.34
You can select the A (K . A) and then the # of decimal places (F 6 3 2 1 0) you want. So if you want to enter 1234 & it calculates 12.34, this will work.
Jul 22, 2011 | Sharp EL-2630P Calculator
Explain "CUT", "UP", "5/4"
CUT: Values are cut off to the number of decimal places speicified by the current Decimal Place Selector setting
UP: Values are rounded up to the number of decimal places speicified by the current Decimal Place Selector setting
5/4: Values are rounded off (0,1,2,3,4 are cut off; 5,6,7,8,9 are rounded up) to the number of decimal places speicified by the current Decimal Place Selector setting
May 04, 2011 | Corporate Express CEB95005 Calculator
Decimal placing
Above the feed button is an area for controlling the decimal placement. By leaving the slider on +, you have to manually put the decimal in.
0 - Means no decimal will be placed.
1 - Put it one place to the end. Ex: 4132.5
2 - Will make it read 413.25
3 - Will be 41.325
And so on.
Jun 24, 2010 | Canon P170-DH Calculator
Change decimal placement on calculator
pressing the tab button displays the number of decimal places 0, 2, 3, 4, A, F on the bottom of the screen.
Jun 22, 2010 | Office Equipment & Supplies
Only shows 1 decimal place!!
Press 2ndF TAB and then a digit specifying the number of digits you want after the decimal point.
May 23, 2010 | Sharp EL-501WBBL Calculator
Need to program to fifth decimal place
Your BA II PLUS stores numeric values internally to an accuracy of 13 digits. However, the numbers it displays depends on the number of decimal places to which you have it set (choice of 0–9 or floating decimal). To set the number of decimal places displayed to three: hit [2ND][FORMAT][5][ENTER]This setting also continues indefinitely (even though the calculator is turned off and on) until it is changed.
Apr 24, 2009 | Texas Instruments BA-II Plus Calculator
Decimal selector problem??
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Mar 11, 2008 | Sharp EL-2630P Calculator
My calculator has a funny format
Try pushing and releasing [f], then [4]. This will give you 4 decimal places. (It follows that if you want 5 decimal places, push 5 instead of 4, etc). If that doesn't work, you can try taking the batteries out and putting them back in which should reset it to 2 decimal places, then set it where you want it following the above.
If it continues to malfunction I suggest taking the batteries out for 24 hours to allow a static discharge. This will lose anything you stored in the calculator, setting it back to how it came from the factory.
Nov 29, 2007 | HP 12c Calculator
126 people viewed this question
jasbo
jasbo
