Freesat just stopped working on my samsung smart tv
My TV is 3 months old and Freesat worked initially and they just stopped working saying - no signal
3 Suggested Answers
  • 182 Answers
SOURCE: Dear Expert, My elderly parents have
first thing to check is the tv working in its old mode of analouge tv.
if this is instant and the slow start is with freesat box.this is probably faulty .
does the tv have freeview built in this is worth checking .
Posted on Aug 17, 2010
budmrtn
  • 11361 Answers
SOURCE: Panasonic TX-32LZD81 (freesat) 18 months old.
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Jun 27, 2011
How can I change from tv to freesat on my samsung smart tv
Consult the owner manual but that should be in the setup or main menu you access with the remote.
Dec 02, 2012 | Televison & Video
Don't understand what you mean by changing from TV to freesat. Can you explain more? I.e. what equipment you have already to receive freesat and what source you're receiving your TV signal from at present.
Will my westinghouse tv work in the uk in conjuction with a bush hd freesat box?
Both the tv and the Bush HD freesat box was bought in the Euoupean union?Wright?Yes,it will work together with no problems,both the tv and Bush HD freesat box both are recieving the same tv incomming broadcasting signal in PAL signal frequencies will be compatible.
Oct 27, 2011 | Westinghouse TX-47F430S 47 in. LCD TV
How do i connect my samsung dvd recorder sh853m to my free sat box? Also is it possible to record a channel from free sat onto my samsung recorder while also watching a different free sat channel.
If it's a Standard-Definition (SD) FreeSat box then a SCART cable would be the normal method of connection to your DVD recorder. This would connect to the SCART/EXT OUT socket on the back of the FreeSat box and the SCART/EXT IN on the DVD recorder. However, this depends on whether your FreeSat box has multiple SCART outputs and whether you are using a SCART cable to connect to the TV.
If there is no spare SCART output socket on the FreeSat box, then you need to use an alternative connection which is common to both devices, i.e. co-axial, and make sure you are connecting from an OUT socket on the FreeSat box to an IN socket on the DVD recorder.
If you have a FreeSat HD box, then you need to connect it to the DVD recorder using an HDMI cable or another cable type that will carry an HD signal.
You will only be able to record from a different Satellite channel if you have a Dual LNB with 2 feeds to the FreeSat box. The LNB is the receiver that attaches to the arm on the satellite dish. You can determine whether you have a Dual LNB as you will have 2 cables from the Dish to the FreeSat box. They may be joined as one cable, but there will be 2 F-plugs (threaded co-axial plug) on each end.
If you don't have 2 cables then you will only be able to record the same channel as you are watching. To record another channel, you need a FreeSat box that supports this feature and each channel needs also a separate feed from the dish.
Hope this helps. If you need any further assistance please post back with the brand model number of your FreeSat box and details of the connections you are using between the FreeSat box, the TV and the DVD recorder.
Regards,
BElectric
Dec 29, 2010 | Samsung Televison & Video
Dear Expert, My elderly parents have just purchased a Bush single scart socket Freesat viewer to use with a LG HD ready TV etc.... I have installed this successfully and it was working perfectly. Now...
Aug 17, 2010 | Televison & Video
I am about to receive an LG32LF4700 Freesat/HD TV If I disconnect the SKY Box and connect the TV direct to the Dish cable will I receive Freesat HD channels. Also can I connect an extra bedroom TV into the...
Yes you can split the signal out from the back of the Freesat/HD (not the TV)to the second TV.
Look what outputs are on the Freesat box - the RF (standard cable) output should go to the 2nd TV (TV set to CH3) and the a/v cables,HDMI or DVI cable should go to the new TV - Note:To receive HD the output from the Freesat should be either HDMI,DVI or Composite output (RGB video jacks) with red White for audio. If you have HDMI this is best - it also provides audio.
Oct 28, 2009 | LG 42LC2D 42 in. LCD HDTV
No sound on hd tv thru freesat
HDMI to DVI adaptors do not always support audio.You have to run seperate audio into the TV.
Jan 12, 2009 | Televison & Video
Setting a new Panosonic TV
If it has no freesat tuner then you can only record what the TV is viewing/tuned to as an output from the TV.
Mar 21, 2017 | Panasonic CT-27SF36 27" TV
Freesat box connect to tv with hdmi cable when slect hdmi tv shows all colour screen no picture
i returned the freesat to the shop going to buy tv with freesat built in
Nov 08, 2008 | JVC Televison & Video
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
