Question about Garden
I have polaris magnum 325 4x4. The transmission grinds or clunks when put into forward high. What would cause this?
SOURCE: My 2001 Polaris Trailblazer has a grinding noise
The problem is most likely the silent chain inside the transmission. I had this problem on a '98 Trailblazer. Made the grinding noise in forward but no noise in reverse. The new chain solved the problem. You will have to remove the transmission and split the case. Not a hard job if you have some mechanical know how.
Posted on Aug 13, 2009
SOURCE: 2001 Polaris sportsman 500 magnum 4x4, speedo dont work
I'm not sure but it might be the sensor on the right front wheel disk
Posted on Sep 05, 2009
SOURCE: 1999 polaris magnum fuel comming out carb
i have no spark
Posted on Oct 26, 2009
SOURCE: 1995 polaris magnum 4 x 4
1995 polaris magnum 425 when you mat on it it goes but then doesnt kick into high so you are reving out and its not going fast
Posted on Jan 04, 2010
  • 123 Answers
SOURCE: Where are the cam timing marks on a polaris magnum 1998
There will be a couple sets of timing marks for your cam. The first and probably most important is the mark on the flywheel. On the top of the recoil cover, there is a bolt that can be removed to see the timing mark on the flywheel. The mark on the flywheel will be a "T". You will notice that the threads where the bolt was removed will have a point, kind of like an arrow that the "T" needs to be lined up with. Next there should be 2 dots on the camshaft gear. If the "T" is in the window, the dots should be at the top of the gear, and the piston should be at top dead center. The camshaft lobes will also be facing away from the valves. Hope this helps, Daniel.
Posted on Nov 04, 2011
Where are the fuses on a 2001 Polaris 325 Magnum 4X4
Polaris 325 MAGNUM 4X4 HDS A00CD32FA Parts Manual
www.manualslib.com > ... > 325 MAGNUM 4X4 HDS A00CD32FA
View and Download Polaris 325 MAGNUM 4X4 HDS A00CD32FA parts manual online.Polaris Automobile Accessories Parts Manual. 325 MAGNUM 4X4 HDS ...
Aug 07, 2015 | Polaris ATV
1994 Polaris 300 4x4 want shift into high range just grinds
Bad linkage between shift lever and the transmission.
Apr 07, 2015 | ATVs
Won't drive in reverse
Failed Transmission Again
Part with it
Get something else
Maybe American (Rear Wheel Drive Only)
Dec 12, 2012 | 2001 Mazda Tribute
POLARIS TRAIL BOSS LOOSES POWER WHEN IN REVERSE
have you ever had polaris(s) before!
my magnum does the same thing , it is a safety thing
press the yellow button on handle bar while on reverse and you will go as fast backwards as forward
Nov 29, 2011 | Polaris ATV
overheat check that the fan work properly if not check your temputure sensor if good check coolant level last change radiator cap
-high gear shifter probably needs to be adjusted
Sep 16, 2009 | Polaris ATV
My 2001 Polaris Trailblazer has a grinding noise in the transmission when in high and driving. It doesn't seem to make any noise in neutral or reverse. Any ideas?
Jun 12, 2009 | Polaris ATV
Possible Tranny problem...
I am sorry to have to tell you this but it sounds to me like your transmission is shot and will need a rebuild. If you can get it to a transmission shop they will tell you 100% what wrong with it. .
Apr 06, 2009 | 1998 Dodge Grand Caravan
Garden Logo
111 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
