Question about Wilbur Curtis Alpha G3 Concourse ALP3GT63A000 12-Cup Coffee Maker
MyCurtis,Alpha-111S coffee machine isover filling the coffee pots
It continiously over fills the coffee pots by aprox 1.5 cups continiously. Its an Auto matic fill
Curtis, Alpha-111S Automatic fill coffee machine. 3x's warmers
    Problem Solver:
  • 9 Answers
That model may have a digital timer that is acssed using the panal swithes get the number for wilbur curtis from thier web site they will talk you through it {simple} the other style timer is a potentiometer type To adjust first unplug brewer, look behind either the front panel or top cover for a dial with numbers around it. turn the dial down slightly brew a pot of water see where the water level comes keep turning down till desired level is reached
Posted on Jan 04, 2009
Hello. Bunn coffeemaker VPR Series. When water is poured in coffee starts to make. Carafe gets about 1/3 full and then just drips through filter for about 5 minutes. Never makes full pot.
VPS/VPR are pour over brewers. Like the 12 cup brewers you find at home, they need to be filled with 12 cups of water (a full pot), heated and then peculated over the coffee grounds and collected in a decanter.
BUT there is one main difference! The VPR and similar COMMERCIAL coffee machines are quick brewers. They usually have a pre-heated pot of water stored inside the machine.
* VPR's and similar machines REQUIRE a pre-fill and heating period prior to brewing. This means it's sitting on a level table and filled with water until water sprays from the brew head. At this point the unit is plugged in and the heater is turned on (there may be some water discharge from brew head as the water expands). Ready light will come on in about 15 mins.
* To Brew; Place coffee grounds in filter, place in funnel and brew head, clean empty decanter under funnel, slowly pour one full decanter of water (cold or hot) into brew tray. Do not overflow tray. Allow water level to sink before adding more water. Only fill with one pot as an equal amount will come out the brew head and funnel.
* Make sure the decanters are all the same size. do not mix a 12 cup pot with a 10 cup pot. One will over fill and the other will under fill. Make sure they match (in cup volume) FYI; Thermo Air pump pots are usually bigger than one pot. Typical filling only to 3/4th of the container. (I think most are in 2.5 to 3 liter sizes)
* If your not getting a full pot then the brewer was partially empty. The second brew (if done within the next hour) should come out full.
* If your still not getting a full pot then the water is leaking or is boiling off. Does it always steam from the top? Thermostat is shorted. Unplug the brewer and call vendor for service.
* Final; If your unplugging when not in use. Then follow the Pre-heat instructions mentioned above prior to plugging the brewer back in. If the tank has been emptied at night or dried up after an idle week. Then there is a chance you may over heat and blow the thermal fuse. Or at best have a half pot short brew as the water dried up.
* Note leaving the brewer plugged in without brewing daily is not a good idea. The water evaporates and eventually drys out the pot. Takes about 1-2 weeks but it does blow the fuse(s) and the unit will need service.
* Final; Follow the Bunn set up and care instructions (manuals from Bunn.com for down loading. *FREE*)
Aloha, ukeboy57
Jul 20, 2017 | Bunn Coffee Makers & Espresso Machines
How do you make coffee with Mr. Coffee, Jr. 4-cup automatic coffee pot?
Its pretty easy to open the top and fill the reservoir with water up to the level needed (i.e. 4 cups). Then press the ON button to start the brewing process. Make sure you fill the filter with ground coffee.
See the following link:
Mr Coffee Coffemaker
Apr 13, 2015 | Coffee Makers & Espresso Machines
Water overfill
The A10 has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the tank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
* If it leaks (from the bottom) only when you pour in water. Then your pouring it too fast and over flowing the fill tray. slowdown, watch the level in the tray. do not fill past the lid.
* If it leaks just sitting (not brewing) then there is a hole in the tank. Call for service.
* If it leaks after filling the tray half way. then the top of the tank has a leak, loose, cracked, or missing gasket. There is quite a few gaskets on the lid. Call for service.
* Final; Leaks are always bad around electrical equip. Best to unplug and call for service to be safe.
Aloha, ukeboy57
PS. Check your using the correct size decanter for this brewer. If it's a 10 cup brewer then make sure all the decanters in the office is also 10 cup. Pouring a 12 cup pot into brewer will have 12 cups of coffee come out (over flowing the 10 cup pot.) Note that not all decanters are made the same size. Other brands may be different. Test by filling a pot with water (from faucet) then pouring directly into pot in question. It should match and not under fill nor over fill.
Apr 04, 2014 | Bunn A10 Coffee Maker
Cant start the coffee
VPS/VPR (VP17-3 are the same except it has 3 lower warmers) are pour over brewers. Like the 12 cup brewers you find at home, they need to be filled with 12 cups of water (a full pot), heated and then peculated over the coffee grounds and collected in a decanter.
Aloha, ukeboy57
Mar 28, 2014 | Bunn VP17-3 Coffee Maker
I have a Hamilton Beach Aroma Elite, but i hate a coffee. How can I boil only the water? It may do it or not?
You can actually just fill up the pot with with water and pour it into the back without adding coffee with practically all coffee machines.
If it tastes like leftover coffee, then here's what you do to fix it:
1.)Fill your pot with 10% bleach.
2.)Fill the rest of the pot with water.
3.)Fill the machine.
4.)Switch on and wait for it to run a full cycle.
5.)When it's done, run it again 3 or 4 more times without bleach until you can no longer smell the bleach in cup of hot water that you pour.
6.)Ta-da, your coffee maker has been successfully turned into a hotwater machine and it's been cleaned from any coffee.
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Jun 04, 2011 | Hamilton Beach Aroma Elite 48101
How much coffee do I use for the 22-cup Farberware coffee pot?
that would depend on the coffee, and how strong you like it.
as well as how large your standard cups are.
I use 1/4 cup of folgers classic blend for 4 'normal' cups of coffee. I also use an oversized camping mug - so 4 normal cups fills two of the mugs. - - - you may want to try 1 1/8 cup of coffee grounds in the filter if making a full pot.
regards,
Oct 12, 2010 | Faberware 12-55 Cup Coffee Urn
My coffee pot is very slow and only 3/4 of pot fills
With the machine full of water and still turned on, pour in 1 qt of white vinegar into the top and place decanter on base and close the lid. You will let this sit in the machine for 2 hours. At the end of 2 hours, flush out the vinegar with 8-10 decanters of water.
Jun 29, 2010 | Bunn 10 Cup Home Coffee Brewer
DCC-1200 coffeemaker cleaning button flashes constantly after it starts,slowly makes coffee and is strong and lots of steam. I have cleaned twice with vinegar solution. What should I do. The coffee maker...
Make sure that when you do the vinegar solution, you do at least 4 cups of white vinegar, and fill it up the rest of the way (max fill line) with water. The manual says to "fill to capacity with a mixture of 1/3 vinegar and 2/3 water," which lots of people misunderstand, and think it means "1/3 CUP vinegar and 2/3 CUP water," which is not the case. It means 1/3 of your 12 cups (and 1/3 times 12 is 4 cups) of vinegar, and 2/3 of your 12 cups (aka, fill it up the rest of the way) of water.
You might have to let it soak for an hour before you try to brew it--this lets the vinegar work at the calcium buildup a LOT better (kind of like soaking your pots and pans before you try to clean them), but it should definitely work for you. If not, call Cuisinart's tech support (1 800 726 0190) and they might be able to get you a replacement :)
Aug 21, 2009 | Cuisinart DCC-1200 Coffee Maker
How to clean a coffee pot with viniger??
Try 1 cup viniger fill rest of pot with water. run it through the machine. through away fill pot with water run through 2 more times. that should do it.
Apr 23, 2009 | Mr. Coffee TFX20 / TFX23 Coffee Maker
Coffee is weak
Check where the water comes out under the brew filter. It sounds like you may be missing the sprayhead. It is a round metal or plastic piece that is screwed on to the water dispense area and acts like a little showerhead forcing water evenly over the coffee grounds. If it is missing, the coffee will be weak. Check the water temperature. If it isn't hot enough, the coffee will be weak.
Jul 11, 2008 | Bloomfield 8571 Coffee Maker
Wilbur Curtis Alpha G3 Concourse ALP3GT63A000 12-Cup Coffee Maker Logo
338 people viewed this question
Top Wilbur Curtis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Wilbur Curtis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
