Nashua 8112RE Photocopier
Start machine and as soon as warm up completes displays C then 62 alternately. Do you know where I can access a manual? Thanks for your time.
    Problem Solver:
  • 12 Answers
Try justmanuals.com
Posted on Jan 04, 2009
'washing machine miele w1714 lock on Message demo programme how i do unlock?
Demonstration Mode (Dealer Displays)
Initial requirements
- Switch off the machine.
- Close the door.
Note
Once you begin the access procedure, it must be completed within
10 seconds.
Accessing
1. Press and hold the Start Button while switching the unit on with
the On/Off Button.
2. As soon as the Start LED lights up, release the Start Button.
3. Immediately press and hold the Start Button, until the Start
LED turns off.
Deactivation
Repeat the accessing procedure.
Note
The Demonstration Mode is NOT deactivated when the power is
shut off with the On/Off Button, or by unplugging the appliance.
Nov 04, 2012 | Washing Machines
I have a Nashua sc550 Aficio 1013. Its displaying error SC550. message displayed is "Functional problems, turn off main power switch then on again. If error reoccur, call service" Best regards
Your question is somewhat confusing as to the model. There is no Nashua SC550 as that seems to be the service code you have an issue with. There is a model 1013F but there is no SC550 code for that machine. That being said I will tell you what an SC550 code means on most all Ricoh, Gestetner,Nashuatec machines. The SC550 means your fuser oil/cleaning web life is over. The solution for this is to replace the web and then reset the counter which requires entry into the service mode. Both of these are going to require a service technician to complete.
Good Luck and Thank You for using Fixya.
Sep 03, 2010 | Ricoh Aficio 1013F Copier
Coffee maker shuts off too soon after brewing.
Hello FloydBob, The Cuisinart DCC-1200 has the ability to program the auto-off function that keeps your coffee warmer plate on after brewing is complete.
The unit lets you select the time increments from zero up to 4 hours.
See page 6 of the attached manual for the full instructions for reprogramming the coffee maker.
To program the Variable Auto Off:
1. Turn the FUNCTION KNOB to the “Auto Off”
position. Press and hold the “Hour” button
for 2 seconds. The clock display will start
blinking.
2. Program the coffeemaker to shut off from
zero to four hours after brew cycle is
finished by using the “Hour” and “Minute”
push-buttons.
I figured you might also like to have a complete instruction/owners manual so you can have access for any other questions you might have about your coffee maker, in the future.
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
I hope you find this Very Helpful and best regards!
Nov 09, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Toshiba estudio 160 Password
Code 08- 263 does not work with the e160
And I cannot find anywhere in the service manual where it specifies how to read it...
Nov 09, 2009 | Toshiba Office Equipment & Supplies
I want to know all error codes for nashua tech dsm618 photocopier AND ITS TROUBLESHOOTING.....
Wow, you'll need a service manual for all of that info. Contact the manufacturer to see if it is available to you, as this information is generally only given to dealers or qualified service techs. However I was able to get a service manual for a Panasonic printer I won without too much trouble ($40 US).
Oct 29, 2009 | Gestetner DSm515pfd Digital Copier -...
Please .. my Photocopier sudunly stop and find
My Sharp is a different model but my reset is:
Hit:
Clear (then)
Auto (then)
Clear (then)
Auto (then)
14 THEN
Start
It resets itself.
Oct 06, 2009 | Sharp AR-207 Copier
C62 error code - NASHUA 8112RE
Is this right out of the box?? If it is, make sure that you have removed all the SHIPPING SCREWS. Check for the one that holds the optical scanner. If this screw is left in the scanner will not move and cause error. ---should be on left side or under left side of optical pan. If all shipping screws are removed, do a once over and check to make sure that all shipping tape and paper are removed. Some companies use tape to hold parts in place.
Jan 03, 2009 | Office Equipment & Supplies
AL-1000 Sharp Photocopier
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Mar 11, 2008 | Sharp AL-1000 Laser Printer
122 people viewed this question
jasbo
jasbo
