Question about Air Tools & Compressors
3/8" drive impact gun socket retaining clip/ring
4 Suggested Answers
latoss101
  • 47 Answers
SOURCE: need rebuilding kit for air gun
you can buy repair kit on the snap-on web-site.
www.snap-on .com
Posted on Jan 03, 2009
  • 174 Answers
SOURCE: where can I get the socket retaining ring for a
1-888-4AIRCAT for a dealer/distributor near you.
Posted on May 30, 2009
  • 83 Answers
SOURCE: looking for piece that screws in the handle of a
Central Pneumatic (aka Harbor Freight), is usually very good for those replacement parts. On their website, to order replacement parts it says:
Please call our Customer Service Department at (800) 444-3353 Monday thru Friday, 6:00 am - 4:30 pm PST. Hope this helps... it might help to have the manual with an exploded view of the parts handy to describe what you need.
Posted on Sep 26, 2010
I have a husky 1/2 inch air gun, I bought the 1/2 inch impact sockets, they do not attach... They appear to small. What is the problem?
At the end of the anvil there is a retaining ring with an o-ring acting as a spring which holds the socket to the anvil. Sometimes they need to be adjusted. You can try and compress the retaining ring slightly by using a channellock plier, adjust accordingly and squeeze slightly until you get the desired tension. If you still cannot attach the socket then you will have to replace the retaining ring and o-ring as a set.
Jun 14, 2014 | Air Tools & Compressors
Ingersoll Rand model 2135. Gun still runs with the trigger off. Disassembled, but cannot figure how to remove throttle assembly.
The throttle valve is housed inside the inlet bushing assembly (item# 26). To remove the assembly there are 2 slots near the bottom of the handle, you will see a metal tip through the slot, that is the clip (item# 27) that need to be depressed in order to remove the inlet bushing assembly (item# 26). There is a special tool to depress the clip but can be substituted by using a small flat head screw driver, once the clip is released, slide the assembly out of the housing and at the very top is the throttle valve (item# 28D) it is held in by a retaining ring (item# 28G). WARNING the throttle valve (item# 28D) has a spring (item# 28C) below pushing up, be careful when removing the retaining ring (item# 28G) it could pop out with some force!
Follow this link to the parts list:
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/45534070_ed3.pdf
Nov 24, 2013 | Air Tools & Compressors
Rockford CAC-110 1/2" Impact Wrench
Mine had a metal ring on the end that held the sockets on. I also had the same problem as you but what I did was took a flat screwdriver and removed that clip ring. I did that because I change sockets quite frequently and having it so hard to replace sockets would just slow me down.
Feb 02, 2013 | Air Tools & Compressors
92 buick regal gran sport replacing harmonic balancer having trouble getting the retaining bolt off can you help me
if you don't have a 1/2 impact gun, then take a breaker bar and socket, and lock the breaker bar under the passenger side rail and use the engine starter to brake the bolt lose. be careful !!
Apr 17, 2011 | 1992 Buick Regal
How to remove crankshaft bolt to change timing belt?
Borrow an air compressor , a pneumatic impact wrench , and an impact socket. It will take the bolt off with minimal effort (you wont even have to hold onto the pulley).
Jan 16, 2011 | 1998 Honda Civic
I have just bought a Bosch GDS 18 E Impact Wrench second hand. My question is how do i keep the socket from falling off the anvil.
A hand ratchet wrench uses a ball to hold the socket on the shaft. Impact wrenches use a ring. The ring is needed for the high speeds.
There should be a groove on the end of the socket end. That groove should have a round or flat ring in it. That ring keeps the sockets from falling off. It is missing go to Bosch for a replacement.
Jan 06, 2011 | Garden
Shoots two nails at a time, gun jams
I found the solution to the double shooting happens when the retainer ring on the feeder paw inside half of the coil nail holder. Part #92 (962112-6) retainer ring R-22. I found the clips broken in two of my guns. Now they work great.
Oct 18, 2010 | Makita Roofing Coil Nailer AN451
My impact wrench wont engage to the socket.
I have the same problem, brand new impact wrench, brand new impact sockets, but can't get a socket onto the gun. Leaned on it with all my weight, wiggled, nothing. and yes they are both 1/2" drive. WTH?
Nov 21, 2009 | Craftsman 1/2" Impact Wrench
Air Tools & Compressors Logo
149 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
