Question about Olympus SP-550 UZ Digital Camera
Olympus 550 UZ battery
Dear Sir ,
I've been using Olympus 550 UZ for a while , the problem is that it's a battery hog , 4 2700 MAH Camelion fully chraged are onsumed in just 40 shots ( red battery light shows up and Camera dies ) the batteries work o other things for a long time ..
Please help
  • 1 more comment
  • sbeat Jan 08, 2009
    My 550UZ is also just over a year old, but my 2700 batteries only last for 12 pictures before the red low light comes on. This also happens with new batteries. Funny thing is, I can remove the batteries and insert them into my Canon Cybershot camera and they show virtually full strength.
    Does this indicate a problem with the 550UZ???
    sbeat
  • bikedom Mar 23, 2009
    I have the same problem with my SP-550. A solution offered is to use lithium batteries, but do they charge in a NiCd / NiMH charger, or do I need a new charger also?
  • Farhan Chawla
    Farhan Chawla May 18, 2009
    I changed to Energizer from Camelion and they are working fine good enough for a couple of hundred shots on full zoom and all options on
I have been using energizer lithium batteries, and get well over 500 pictures (mixed flash/no flash)
Posted on Mar 06, 2009
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
You may want to use lithium batteries... i find the rechargeables in most cameras to not last as long... also you may need to clean the contacts in the battery compartment with alcohol and let air dry
Posted on Jan 20, 2009
Can the battery case cover of an Olympus SP550 uz be easily obtained & easily replaced?
The cover on the camera is cracked or the battery case is cracked. If it is the battery that is cracked replace it immediately. If its the camera attachment that is cracked Gorilla Tape works wonders :)
DO NOT USE THE PHONE IF THE BATTERY CASE IS CRACKED!
Sep 13, 2014 | Olympus SP-550 UZ Digital Camera
Camera automatically asks to format or turn off. I just bought the XD memory card to use in my camera (OLYMPUS 550 UZ). I had the camera power on and proceeded to put the memory card in while the device...
Never insert or remove a card while the camera is on. You can try to download the pics on the card to your computer using a separate card reader. Then, format the card in the camera.
Mar 08, 2010 | Olympus SP-550 UZ Digital Camera
Battery drainage
20 to 30 shots on "fresh" batteries! Do you use the flash on all shots. That really drains them. I would try to set the camera to "factory default settings" in case you changed something that is causing a drain. I hope you just bought some bad batteries.
The best thing I EVER bought for my Olympus was the Re-chargeable Lithium Ion batteries. The worst thing I did was buy an off brand. That was a waste. I ended up getting the more expensive brand Olympus recommended and all was GREAT again!! 1,000's of pictures later and they still work great.
Good Luck
Oct 03, 2009 | Olympus SP-550 UZ Digital Camera
I've been using Olympus 550 UZ camera for over a year now. I am facing problem with the life of battery though. Tried Energizer and Duracel batteries. 10-15photos and the battery is drained down. Is there...
Switch from alkaline batteries to pre-charged Nickel Metal-hydride (NiMH).
My best experience is with these batteries:
#1. RayoVac (pre-charged)
#2. Kodak (pre-charged)
#3 Energizer (rechargeable)
Find them at WalMart or online
"pre-charged" are new technology rechargeable batteries. They are GREAT! They outlast alkaline at least 15 times per charge.
Sep 28, 2009 | Olympus SP-550 UZ Digital Camera
Can i use the olympus sp-550 UZ as a web cam?
It is not possible to use this as a webcam as the camera is not capable of sending streaming data over the data cable rpovided with it and also the software rpovided with it (drivers) is not programmed for the camera to be used as webcam.
Aug 12, 2009 | Olympus SP-550 UZ Digital Camera
Hey I just bought the Olympus sp-550. My problem is that the memory card will not click in...
the trick to that is, you have to use a dime to push it in deep enough til you hear the small click.
The memory card will then be level with the camera.
Sep 25, 2008 | Olympus SP-550 UZ Digital Camera
Conversion of LCD
Unfortunately such conversion is not possible. If the "vari angle" screen is an essential your best approach would be to dispose of the SP 550 UZ and buy another camera meeting your need. Sorry!
Mar 25, 2008 | Olympus SP-550 UZ Digital Camera
Raw picture on olympus sp 550 uz
Assuming your SP 550 UZ is similar to the 510 UZ "RAW Mode" is not available in "Auto" or any of the "Scene" modes. If you set your camera to "P" and then access the Image Quality item in the Menu RAW is available as an option.
Hope this helps.
Mar 02, 2008 | Olympus SP-550 UZ Digital Camera
OLYMPUS SP-550UZ
When I try to zoom on my SP 550 UZ it says battery empty, yet operates normally otherwise.
Oct 11, 2007 | Cameras
Olympus SP-550 UZ Digital Camera Logo
327 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
