Question about Hansgrohe Plumbing
HOT WATER PRESSURE LOW ON HANSGROHE SHOWER - Hansgrohe Plumbing
arealplumber
  • 33 Answers
SOURCE: low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
Posted on Dec 05, 2008
  • 44 Answers
SOURCE: no cold water only, just tepid to hot on thermobalance I
hi i think the problem is the temp has not been adjusted to your requirements as it will come factory set at 43 deg c so you will probably need to get it adjusted by the guys who fitted it as it wiil need to be set by a professional.
Posted on Dec 15, 2008
  • 11 Answers
SOURCE: faucet issue
Sounds like it was installed upside down or the cartridge is installed improperly
Posted on May 07, 2009
  • 82 Answers
SOURCE: moen T2113 shower faucet no hot water
You need to replace the stem. This will not cost you a dime; call MOEN and tell them the issue, with the model number, and they will send the replacement part. Many people don't know that MOEN is guaranteed for life (to the original owner)......another words, say you are the original owner :) They will not ask any questions. Good luck! PS Also works on any MOEN faucets you may have.
Posted on Sep 03, 2009
  • 10 Answers
SOURCE: No hot water pressure on kohler bath / shower faucet
Try draining the system and apply air pressure (min 30psi) to each faucet. Open other hot water faucets to allow pressure to vent. Next try draining and cleaning the hot water tank.
Posted on Oct 24, 2009
One of my HG shower systems has increasingly lower volume. The shower head and supply hose are fine. what should I check next?
If you are using water in another part of the house most times the pressure at the bathroom shower will go low. For instance if some one in the kitchen draws water in the kitchen sink this will make the shower water even turn cooler because of low pressure. Flushing the toilet will also do the same.
Most houses are plumbed with half inch water pipe and would work a lot better if it was three quarter inch to give more water pressure.
Jan 12, 2015 | Hansgrohe Home
I have a problem with low hot water pressure can you help would an elec shower help
1) If possible, it is Best to solve pressure problem before installing new shower.
http://waterheatertimer.org/Low-hot-water-pressure.html
2) If the cold water has good pressure, then Electric shower could fix problem ... but shower would have to be connected to the cold water line and not the hot.
3) Seems the expense of adding a electric shower would be greater than having plumber fix low hot water pressure.
Assuming you have access to plumbing pipes, and this is not apartment building.
Jan 05, 2013 | Water Heaters
No pressure in Hansgrohe shower when on hot setting
This is most likely debris in the filter screens on the thermostat cartridge or the thermostat cartridge has worn out. Cleaning the filter screens may resolve the issue. If cleaning the filter screens does not resolve you may need to purchase a new thermostat cartridge. If you need further information feel free to contact me at Hansgrohe. 1-800-334-0455. Press 2 for tech and ask for David Scarborough. I'd be happy to help.
Oct 27, 2012 | Hansgrohe Shower 26101 Pharo Prestige...
Adjust hot water on hansgrohe metro shower
The hand shower and wall bar does not control temp. The valve in the wall would control the temperature of the water going to the shower. I would need to be able to identify the model number of the valve in the wall to be able to give accurate instructions on temperature adjustment. If you need help identifying this valve feel free to give me a call at Hansgrohe 1-800-334-0455. Press 2 for tech and ask for David Scarborough
Oct 13, 2012 | Hansgrohe 06496 Croma Hand Held Shower -...
To adjust hotter
Your shower has been installed for a while and you are noticing the dial must be turned further and further to the hotter settings to get a normal shower - In this case the filter on the hot inlet is getting clogged with debris. Refer to the cleaning instructions in the manual that came with your shower, or contact Hansgrohe USA by calling 800-334-0455 for the documents.
If your installation is brand new or old, debris on the filter is the number one cause of this problem. You can test it by noticing if there is a drop in pressure when you dial to a hot setting as opposed to the cold setting. The drop in pressure indicates dirt on the filter where water has a tougher time getting through.
Filters on a shower valve may seem strange to US consumers. Your old two handle valve system woul run for years without needing servicing. Now you have filters to deal with. These filters, like any filter need to be cleaned periodically and the frequency depends on the quality of your water supply system.
The real benifit, is that the filters protect your smart valve and the shower head from malfunctioning due to debris.
Aug 31, 2011 | Hansgrohe 06642000 Chrome Solaris Single...
How do I remove cartridge part # 9273000 from my Hansgrohe kitchen faucet?
Please contact us at the below number or email me directly and I will get you a copy of the instructions that you need.
Regards
Chris
Christopher Scott
Technical Support Specialist
Hansgrohe Inc.
1492 Bluegrass Lakes Parkway
Alpharetta,Ga 30004
Tel:1-800-334-0455
Fax:678-762-7042
Email:Christopher.Scott@hansgrohe.com
Feb 19, 2011 | Hansgrohe 06649860 Solaris Single Hole...
Hansgrohe 06358620 shower not hot enough
Remove the handle by loosening the screw near the bottom. You should see a plastic ring, probably green, that is the hot water safety. Adjust it so that the handle will turn further for more hot water. It most likely pulls out, then turn it left, reinsert and reattach the handle.
Apr 26, 2010 | Hansgrohe 06358620 Pressure Balance Valve...
No hot water coming through the shower system, though hot water comes through the pipe without system attached
When you adjust the dial to mix the hot and cold for your desired liking, it goes into a mixing chamber before going to the shower head, im asumming your issue is within the mixing chamber.
Nov 05, 2009 | Hansgrohe Shower 26101 Pharo Prestige...
Insufficient hot water from Gledhill pulsacoil 2000
changing the shower head will not do anything.to do what you want,you would need more BTU's or a bigger unit to supply more water,someone may be hogging the water also.
Feb 25, 2009 | Hansgrohe Axor Hansgrohe Starck Shower...
Plumbing Logo
41 people viewed this question
Top Hansgrohe Plumbing Experts
Andrew Bugbee
Ian Lulham
Ian Lulham
Level 1 Expert
ray gallant
Are you a Hansgrohe Plumbing Expert? Answer questions, earn points and help others
