Question about Mitsubishi Car Audio & Video
Wiring power supply for Mitsubishi MZ312569 cd changer
Should I connect to a permanent feed?
bestdarngood
  • 3037 Answers
SOURCE: Panasonic CX-DP880, will not load disk. disk tray jams, new unit
Alright, it looks like you copied and pasted something and your first questions about the 12v wire not being long enough was answered and you just needed to splice the wire and add another wire to it which is correct but do it with the battery disconnected.
the error 3 is a jammed error, try resetting it by first removing the battery and if that doesn't work then try turning the key in the ignition back and forth quickly 10 times to reset the truck.
Let me know how this goes, also is the changer trying to open on its own (whirring of gears) or was it not doing anything?
Please update me after doing the above suggestions and let me know where we are at with this problem.
good luck
Posted on Jun 03, 2008
tech48
  • 624 Answers
SOURCE: cd changer
You can use any CD changer that has an FM modulater. You would listen to it by tuning in to a station on your tuner.
The sales person at any place that sells car stereos would be able to show you the right type of changer.
If your radio has a cd changer controller built into it, you need to check with the dealership to find out what the OEM changer would be. But a FM modulator will work with any car stereo.
Kenwood, Pioneer, JVC, Clarion, Alpine all sell FM modulator CD changers. I would not personally buy any of the cheaper no name brands. The money you save on the cost is not worth the difference in quality. Panasonic is a very good brand for car stereos but not home stereos, but I don't know if they make CD changers. if they do, that would be a good brand.
Posted on Jun 18, 2008
LVT7857
  • 116 Answers
SOURCE: can i connect an alpine
I dd a preliminary check with Periphial and no go. Give me a year and model of the Mits and I can give you a definitive answer.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
welcomejee
  • 10594 Answers
SOURCE: How do I supply power to this cd changer?
Below is an image of Jack PCB inside unit and Fuse is marked that need to be checked.
Posted on Apr 26, 2009
kenw392
  • 2226 Answers
SOURCE: i want to connect my alpine stereo to my standard
that is not possible
Posted on Jan 20, 2010
1998 buick regal stereo what are the wire color codes
showgif.do?image=73222
Connector Part Information
12110115
32-Way F Micro-Pack 100 Series (Blue)
Pin
Wire Color
Circuit No.
Function
E1
DK GRN
835
Entertainment and Comfort (E&C) Serial Data Communication
E2-E5
Not Used
E6
DK BLU
1796
Steering Wheel Controls Input
E7-E8
Not Used
E9
LT BLU
1405
Remote CD Changer Common Input
E10
ORN/ BLK
1406
Remote CD Changer Left Channel Input
E11
LT GRN
1407
Remote CD Changer Right Channel Input
E12
BRN
199
Speaker Feed-Left Rear
E13
YEL
116
Speaker Return-Left Rear
E14
DK GRN
117
Speaker Return-Right Front
E15
LT GRN
200
Speaker Feed-Right Front
E16
BLK/ WHT
351
Ground
F1
ORN
640
Fused Battery Feed
F2
YEL
43
Fused (Retained w/KP2) Accessory Power Feed
F3
DK GRN
145
Radio Switched Power
F4
GRY
8
Interior Lamp Dim Switch
F5
YEL
32
Fused Interior Lamp Dim Signal
F6-F10
Not Used
F11
BARE
2011
Remote CD Changer Drain
F12
TAN
201
Speaker Feed-Left Front
F13
GRY
118
Speaker Return-Left Front
F14
LT BLU
115
Speaker Return-Right Rear
F15
DK BLU
46
Speaker Feed-Right Rear
F16
Not Used
Dec 20, 2014 | 1998 Buick Regal
WIRING
yes there should be a wire indicating this connection as example when adding amp/seperate wire connection to turn on when radio is turned on/off
Apr 01, 2014 | Pioneer Cd Rb20 Auxiliary Input Adaptor
Hey guys, I've just installed a CD changer in my car - having some difficulties getting it to work. After some Googling I came across this forum so I figured I'd see if any of you guys know where I'm...
there should be a small connector on the changer itself for the power ground and remote wire for power to the changer unit. the cord coming from the unit to the changer doesn't supply this power and this is why it wont eject and also your head unit wont recognize it until it gets powered up and able to communicate with the head unit and then it will show up as a selectable source when switching between sources of music. check the back of the changer for a small connector containing 3 or 4 pins and you should have a connector with the corresponding wires coming from it to plug into this spot after connecting the wires properly. if you bought it on ebay it is possible you didn't get this piece which is critical when connecting this changer.
Apr 03, 2011 | JVC CH-X1500 12-Disc CD Changer
Yellow wire with fuse ? coming out of cdx4090
usually the yellow wire is your permanent power wire that connects to the battery or any power that stays on when the ignition is off. if you are losing your preset stations when you turn your car of then my bet is that this is what it is.hope that helps
Jan 26, 2011 | Sony CDX-4090 CD Changer
AM FM CD DET FACE CAR STEREO: installed an alpine stereo in my mustang and every...
That's because the memory wire has not been connected to a permanent live supply.
There will be an ignition switched 12v supply and a memory wire. The first is yellow on many brands and the second is red, but you need to refer to your fitting manual to check or look directly at the wiring harness as the wires are often individually labelled.
Since they both take 12v some folks mistakenly think that they can just be piggy-backed to each other and feed from the same supply. They can, but only if it's to a permanent live feed but that then leaves the risk of the unit being left switched on when the car is parked and draining the battery.
May 07, 2010 | JVC AM FM CD DET FACE CAR STEREO
Hi All, I have a peugeot 206 and when I enter my four digit code into radio everything OK until I turn off ignition,then I have to input number again.Is there something else I have to do to stop this...
It looks as though the "permanent battery" feed to your radio is missing.
There are 2 battery supplies to your radio ; the main one via the ignition switch that switches the radio on/off and the permanent battery feed that supplies battery to the radio memory.
Check your fuses and connections at the rear of the radio
Apr 03, 2010 | Car Audio & Video
I can not hear any audio
If you have the correct head unit, and assuming the cable is in good condition, the it should work. Although I do remember some Pioneers needed Permanent 12V+ and ground hooked up in order to work. If this is one of those, on the changer side there should be another white plug next to the changer cable with two or three wires in it. This should be the power feed wirs for the changer. I need more info to confirm.
Jun 14, 2009 | Pioneer CDXP1280 Multi-Disc CD Player...
Fiat cd changer wont keep its code inthe memory
The radio requires TWO battery feeds.
One is a permanent battery feeding the code and station memory
The other is the main one  via the Ignition Switch
May 27, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
QWESTAR 10 DISC CD CHANGER WITH FM MODULATOR
connect the 12V IGN to the switched supply from the ignition and Back up to the unswitched supply straight from battery.
Jan 09, 2008 | Qwestar QC280 10-Disc CD Changer
Car Audio & Video Logo
99 people viewed this question
Top Mitsubishi Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Mitsubishi Car Audio and Video Expert? Answer questions, earn points and help others
