Question about Neovo F-417 17" LCD Monitor
Half Dead Monitor
Most of the time my F-series 17" LCD Monitor will not turn on, or not turn off. I have had the monitor for about a year and a half with no other problems. A couple of months ago it started acting up. If I turn the monitor off, it will take a couple of days to turn back on. When it does, the LCD light is green and everything is fine until I need to turn it off, and it won't. It takes another couple of days to turn off. What is my problem?
  • sympatoche Sep 05, 2008
    Hello.
    My english is approximative, sorry. I am in Belgium (Western Europe)
    I have a Neovo F-417.
    The LED is OFF continuously.
    Nothing on the screen.
    On the power circuit :
    Fuse is OK.
    4 Volts on Diode 822 (only 4 volts instead of 5 volts)
    I think there is surcharge.
    Is it possible to obtain some aid, or a place to find shematics ?
    Many Thanks
    Pierre
    my e-mail (if you prefer) super_sympatoche@hotmail.com
    Problem Solver:
  • 19 Answers
Dear
This problem is caused by keyboard switches which are bad quality they are easy to replace, so if you are able to work with solder you can finish replacement in 15min.
Good luck.
Posted on Jan 17, 2008
Only the top half of my Philips 170S LCD monitor displays a normal picture. Below this there is a one pixel wide white line and then the bottom half of the monitor has a lined pattern that gradually...
If the monitor is connected to a DVI output on your computer try to connect it to the VGA to see if it's an issue with the input or if the monitor is shot. It sounds like your monitor just crapped out.
Jun 06, 2017 | Philips 170S4FG 17" LCD Monitor
17" flat screen upper half is dark until "thumped"!
The inverter board that controls the lighting on the screen is dying. since its a 5 year old monitor and only a 17 inch. the cost to repair is greater than the cost of buying a new one. unless you know how to replace the part yourself. I think its best to just buy a new monitor
May 04, 2010 | Rosewill R900J 19" Flat Panel LCD Monitor
My dell P2210t will only light up the top half of
it may be better to bring your LCD to where you bought to claim the warranty. don't try to open the LCD and try to fix it because you will lose the warranty.
Oct 15, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Lower half of monitor goes dim
Replace the backlight in this unit will bring you back in business.
Thanks please rate.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 19, 2009 | Star Logic 17" LCD Monitor
Screen turned black
your monitor got a hardware problem:
1) the LVDS controler board out of work, only change or repair it could be fixed.
2) if you can see some show like smaller signal detect windows in the centre of screen a very short time (bright flashing one time), this is inverter board damaged or worn lamps, thay all need repair or replace
hope give you some idea. please take a rating let me know how much helped you thanks!
May 20, 2009 | Dell E176FP 17" LCD Monitor
Acer Monitor Doesn't Receive Signal From Computer
can you test your monitor on another computer to verify the monitor is at fault? If the monitor is at fault its time for a new one, factory warranties on monitors are usually 1 year unless you purchased an extended warranty.Otherwise repair is usually more costly than buying a new one.
Dec 25, 2007 | Acer 17" AL1706B LCD Monitor
Monitor took half an hour to warm up, now won't start.
doubtful this is a driver issue warm up is not needed for any monitor. this is a power board issue internal to the monitor capacitors or some issue on the main power board. let me kow what you will do. good luck.
Nov 18, 2007 | Mag Innovision LT782S 17" Flat Panel LCD...
Acer Al1716
Need to replace the power inverter board..
Oct 12, 2007 | Acer AL1716B 17" LCD Monitor
Neovo F-417 17" LCD Monitor Logo
234 people viewed this question
Top Neovo Computers & Internet Experts
Questman
Questman
Level 1 Expert
Dimitar Todorov
Are you a Neovo Computer and Internet Expert? Answer questions, earn points and help others
