Question about Kitchen Ranges
Smeg SA 360 X/1 how to replace oven element - Kitchen Ranges
ronaldo1
SOURCE: cooker not heating up
removed broken element and replaced it. You have to access the fixing screws from the back of the cooker to remove it
Posted on Feb 15, 2008
  • 409 Answers
SOURCE: Smeg A2 - Oven gets too hot
is there a heat probe inside the oven? sound like you owen is overheating. i would check the TOD, if the oven has one. this thermostat regulates the temperature and if it's "open" it needs to be replaced.
Posted on Sep 13, 2008
  • 1462 Answers
SOURCE: Smeg Oven not heating to
if oven does not heat atall, then suspect element.
take back panel off inside oven and element is in view. sometimes the damage is obvious but not always.
remove back of casing and check for continuity thro the element with a multimeter. replacement is easy
Posted on Sep 16, 2008
redbeard00
  • 957 Answers
SOURCE: rear circular element not working
more often the element burns out before the selector switch. If there is an indicator lamp that illuminates when you turn it on and the light isn't coming on then it could be the switch.
Posted on Apr 28, 2009
SOURCE: smeg sa9066xng oven
although no evidence of elements blowing out , when tested both were dead. we do then recall maybe oven wasnt cokking quite so good so one element must have been already blown.replaced them both and all is good
Posted on Jun 26, 2009
Replace heating element in smeg oven
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Mar 02, 2013 | Smeg Ovens
Smeg oven not working
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Mar 06, 2012 | Smeg Ovens
Fan bake on smeg oven not heating ,mod SA 9066XS
Feb 02, 2012 | Smeg Ovens
Smeg oven stopped working
Jan 27, 2012 | Smeg Ovens
I have a Smeg SA 398x model. firstly, I would like to know the year of manufacture please. Secondly, for some reason the fan element options do not heat up. The fan in the back of the oven works but no...
Jul 19, 2011 | Smeg Linear Pyrolitic Single Oven Electric
How to fit a fan element for a smeg se335ss-5 oven
Jan 31, 2011 | Smeg SC712U Oven
Does not heat up fan turns on smeg scp 111 multifuncation ELECTRIC oven
If this helped like us on Facebook please
How to Video Tutorials on Domestic Appliances
Sep 10, 2009 | Smeg Ovens
Smeg oven
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Smeg oven and hob ubit: Fan works but oven wont heat up
If this helped like us on Facebook please How to Video Tutorials on Domestic Appliances
Oct 05, 2008 | Smeg Kitchen Ranges
Smeg oven SA 392 EB - technical difficulties
first of all the yellow/orange light glowing is a known fault. it needs a slight wiring modification to fix it, however it dose not affect the operation of the oven nor is it dangerous.
now to the heating problem, there is a round element at the rear witch surrounds the fan. is this element getting hot? if not then it most likely needs replacing. it could be the thermostat but more likely the element.
Mar 05, 2008 | Ovens
Kitchen Ranges Logo
143 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
