Question about Dryers
I have a white knight bg447 gas tumble dryer. I turn it on and the light for heat lights up and may stay on for a few minutes or for the whole drying cycle. Sometimes it will go off after a few minutes and I may have to open the door, move the laundry around and clear the lint catcher in the door. I may have to do this several times before it will stay heated fro the duration of the drying cycle.
jmeredith
  • 417 Answers
SOURCE: gas dryernot heating up
hi,
try and reset the motherboard by unplugging power and waiting a few minutes and plug back in. What did you clean your dryer with?
If it was sharp you may have nicked a sensor, buy the wiring diagram and study away. Use caution with gas of course, shut it off look for shutoff , the flexible lines are brittle, be careful take time.
J
Posted on Jul 11, 2008
SolutionGuy
  • 331 Answers
SOURCE: I have a magtag gas dryer with that heat sensor
Hi Joy Ann,
The automatic cycle of your dryer depends on air circulating in, through and out of your dryer efficiently. If air isn't circulating properly, your timer will stall and run forever.
Timed Dry, on the other hand is independent. The timer only does what it's told to do... count down time.
So, yes. You do have a blockage in the vent to outside. When you said the "Vents are clean", I presume you mean the lint filter. That's good. It's always good to keep that clear. What I'm talking about is the four inch vent tube from the dryer to the wall. How close is the back of the dryer to the wall? If it's less than 4", the vent is crushed. Take a flashlight and look behind the dryer without moving it. See that flex hose back there connecting the dryer to the wall? If it is pinched, so is your air flow. Either pull the dryer out about 8" from the wall, or shorten the hose.
If all of that checks out OK, though.. (your flex line to the wall isn't pinched) that means that the vent in the wall is blocked somewhere. Trust me... I've seen all kinds of things block vents to the outside. Bird nests mainly, squirrel's, reptiles, rodents... they all love to build nests in the warm place <--that would be your dryer exhaust.
Recommendation: pull the dryer out at LEAST 8" from the wall and see if that helps. If not, your Home's internal dryer vent should be professionally cleaned (should be done once a year for 2 story Homes).
Bottom line is this... if your dryer is heating, it's trying to do its' job. The only reason it can't is because air isn't circulating properly.
Look into it, Joy Ann... Dryer fires are serious and they are caused by blocked ventilation.
Hope this helps,
SG
Posted on Mar 25, 2009
agitateme
  • 88 Answers
SOURCE: my gas dry does not heat anymore
Most likely cause is the gas valve coils. They will tend to work for a few minutes, until they get warm and their resistance rises. Not a big deal at all...part kit is #279834 costs roughly $20-25. The coils are the two small cylindrical parts mounted in a bracket, directly on the gas valve, one with a three wire harness, one with a two wire. To replace, simply remove the two screws holding the bracket on, remove bracket and slide the coils up and off the valve. On one of the coils there is a metal sleeve that typically will stay on the valve, but may stay stuck in the valve, just make sure the sleeve goes back on the valve. Install new coils and bracket, (the bracket has two tiny holes, which correspond with two equally tiny white tabs on the coils to help line them up) that should take care of it! Re-post if you have questions about the install, etc.
Posted on Apr 21, 2009
  • 1738 Answers
SOURCE: Kenmore 600 dryer tumbling & heating, but not drying
Several reasonings. Step One make certain that you have 220 volts coming to your outlet. It takes 110 for the motor, and it takes 110 for the heating elements. If you have a volt meter that would be the best way to do that. Take the red and stick it in to the long part, and the black lead to the ground. Fuse houses was bad about this. Step Two it could be the elements are kicking off too soon. That is usually a sign of almost blown element. Step Three the heat sensor for the element prematurely kicking off the element.
Posted on Aug 10, 2009
milten1
  • 1304 Answers
SOURCE: white knight gas tumble dryer - not heating up,
ignitor issue
Posted on Oct 03, 2009
White knight gas tumble dryer lights then cuts out
Flame sensor next to the burner is eather bad or there is a bad connection at the flame sensor (that's why the kick works)
Jan 05, 2014 | Dryers
Tip
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
on May 10, 2010 | Abbaka White Knight 38AW Electric Dryer
Tip
video section
on May 10, 2010 | Abbaka White Knight 44AW Electric Dryer
White Knight gas tumble dryer BG 457 starts and ignites with the orange light coming on, works for about a minute producing heat then the orange light goes off. The dryer continue to turn but the orange...
I feel you need a new igniter or thermocoupler. Just remember those igniters are activated many times to keep constant right heat for the machine to do its job.
Jan 25, 2018 | Dryers
Hi i havw a white knight gas tumble dryer. My problem is that the flame starts for no more than a minute then turns off. Any ideas how to fix please.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101'
Jun 12, 2011 | Dryers
My tumble drier has no heat and the reset button does not seem to be working
could be thermal limiter fuse in the back of the dryer. this can cause it to not heat but still the drum will turn
May 01, 2010 | Abbaka White Knight 44AW Electric Dryer
WHITE KNIGHT TUMBLE DRYER WILL NOT GET WARM
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 24, 2010 | Abbaka White Knight 38AW Electric Dryer
White knight tumble dryer CL432WV wiring diagram please
This has lots of diagrams on white knight http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Apr 19, 2010 | Dryers
My white knight condenser dryer doesn't heat up anymore what do i need to replace?
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat is this video does not help go to our video section and there are a few on other condenser dryers
Mar 25, 2010 | Dryers
Yesterday the trip switch for the downstairs mains sockets tripped. When i reset it and plugged switched on my White Knight 44AW drier it span as usual but now there is no heat.
Jan 19, 2010 | Abbaka White Knight 44AW Electric Dryer
Dryers Logo
55 people viewed this question
Top Dryers Experts
