Question about Toshiba PORTEGE R500-S5006X Notebook
Want help on installing XP on R500
Got XP w sp3 and found the driver at Toshiba (Intel(R) 82801GBM I/O Controller Hub (ICH7M).
Tried to use nlite (copied wincd to dir on hd - run nlite - selected the 2 drivers - done... no iso as told in the manuals of nlite -> so how do i get the new cd made PatKam_au?
rgds
Lars
    Scholar:
  • 88 Answers
I want to instal a windows XP SP3 on Foxconn 915 series with north bridgegrantsdale G-i915G with a IDE H.D.D (pata) and sata O.D.D,it seems that i need a floppy disk for raid driver,but i lost motherboard...
There are a couple options.
  • Check in BIOS to see if your motherboard supports IDE emulation mode. If it does turn it on and XP will install just fine.
  • Download and read about using nlite to incorporate sata drivers into an Windows XP installation disc. (You will need another working computer. Download nlite and insert the XP disc run nlite and select your CD as your windows install file location. Download generic sata drivers, intel has a bunch you can get for free. In the nlite menu to add drivers select folder option and select the folder with the drivers. Set anything else you want in nlite and burn the new XP disc. This disc will install just fine as it now has sata drivers.
Comment if you need further instruction.
Aug 18, 2011 | Foxconn 915P7AC-8KS Motherboard
Toshiba Satellite M65-S9062, Laptop, 2Gb RAM (old... I know :) ) XP Pro SP2 (same problem if SP3) After a total system recovery using original recovery media provided by Toshiba the device manager shows...
please right click the device ( in device manager ) and choose ( uninstall driver ) restart,
and try again to install the driver manually, not through (.exe) wizard
Please tell us your results
Good Luck
May 13, 2011 | Toshiba Satellite M45-S331 Notebook
To install xp over preinstall vista in Toshiba satellit A200, some soultaion is aviable 1. to disable sata but how to disable sata in toshiba no option is aviable in in toshiba Bios. plz help me
There are case where BIOS stting doesn't contain any point of configuration for SATA.,
Step 1 : Download SATA driver
Here is the link :
http://downloadcenter.intel.com/confirm.aspx?httpDown=http://downloadmirror.intel.com/12474/eng/iata621_enu.exe&agr=N&ProductID=2101&DwnldId=12474&strOSs=All&OSFullName=All%20Operating%20Systems&lang=eng
Step 2 : Download a software called "nlite"
Here is the link :
http://home.midmaine.com/~nlite/nlite/nLite-1.4.9.1.installer.exe
Now you need to include SATA driver with Windows XP cd so that windows XP recognize your HARD DRIVE.it can't be include diectly so
Installed the nlite software and follow the instruction by going to the link below.
http://www.nliteos.com/guide/part1.html
Note : Microsoft dotnet framework 2.0 or later is needed to install nlite in Windows XP,but if you are making a bootable Windows XP cd with sata driver pre-install then,you don't need it.
This will 100% recognize your SATA HARD DRIVE.
Hope it will solve your problem.
Jan 02, 2010 | Toshiba Satellite A200-19501F Notebook
Microphone issue with "Toshiba Satellite A135 4656" with XP
Most of the drivers can be found here:
http://il.computers.toshiba-europe.c...jsp?service=IL
Select: Notebook
Select: Satellite Promag-glass_10x10.gif
Select: Satellite Pro A Series
Select: Satillite Pro A200 (PSAE1)
Select: PSAE1
Select: Windows XP
Select : Search
This model has the same Chipset Drivers as the A135-S4677
You will need XP SP2 (NOT SP3)
The LINK will show you alot of drivers, but follow this order by make and version #
Chipset Utility: INTEL 7.1.0.1014
Display Driver: Intel 6.14.10.4833
LAN Driver: Realtek 5.664.205.2007
Wireless Driver : Atheros 5.2.0.125
Sound: Realtek 5.10.0.5464 (Next page)
Modem: You will have to select you region
Sep 26, 2009 | Toshiba Satellite A135-S2276 Notebook
I have a hp 6735s with win vista installed in it. i want to use win XP but it wont install in this computer system.what should i do?
Problem : When Windows XP was made there was no concept of SATA drives now ur drive is SATA and ur installation disc does not contain drivers for ur Hard disk thats why it is unable to find ur hard disk as it doesnt recognize it u need sata raid drivers on ur windows inst cd
Solution:
this specific model HP 6735 was shipped with vista OS and drivers now u are downgrading it to XP it depends on the installation disc if it is new one like SP3 included then u would have never faced this issue in ur case u should get a RAID driver from www.intel.com and then include them in ur copy of windows XP cd to load them at the startup of installation , so u need them in the first place to carry out installation, u have to do some job here download RAID DRIVERS from www.intel.com select ur board and chipset either it is 945 or 965 gm and then download nlite a software used to integrate these drivers to ur inst disk , u can also include SP3 thru this software in ur current win xp cd
just download sata drivers from intel and nlite from the link and install the software integrate these drivers and burn ur cd incl them and then install normally as u were installing them earlier now it will recognize ur drive simple for more info how to do check this out
http://www.zimbio.com/Laptop+Reviews/articles/10840/How+Integrate+Floppy+SATA+RAID+Driver+Windows
http://lifehacker.com/386526/slipstream-service-pack-3-into-your-windows-xp-installation-cd
pls dont forget to rate me fixya for this help if u like
pls let me know if i can help u more
Mar 12, 2009 | HP Compaq 6735s Notebook
Installing WIN XP SP2 in aToshiba Satellite A205-S7459 Vista original
simple solution: get WINDOWS XP CD with SP3 it contains support for sata drives
Workable Solution:
this specific model of Toshiba was shipped with vista OS and drivers now u are downgrading it to XP it depends on the installation disc if it is new one like SP3 included then u would have never faced this issue in ur case u should get a RAID driver from www.intel.com and then include them in ur copy of windows XP cd to load them at the startup of installation , so u need them in the first place to carry out installation, u have to do some job here download RAID DRIVERS from www.intel.com select ur board and chipset either it is 945 or 965 gm and then download nlite a software used to integrate these drivers to ur inst disk , u can also include SP3 thru this software in ur current win xp cd
SATA DRIVER FROM:
http://downloadcenter.intel.com/license_agr.aspx?url=/17268/eng/iata87enu.exe&ProductID=2800&agr=Y&sType=&PrdMap=&DwnldId=17268&strOSs=45&OSFullName=Windows*%20XP%20Home%20Edition&lang=eng
after windows XP installation u will have one more task to find drivers for ur notebooks with XP support but it is the next step if ur some hardware like modem / sound/ doesnt work then i can help more
and rate me FIXYA if i have fixed ur problem
Mar 03, 2009 | Computers & Internet
To change os from vista to XP
I hate Vista from my guts! I installed XP SP3 (Slipstreamed) and my Toshiba Portege R500 Flies!
I have posted some notes on similar issue from this forum. Use this website's search engine on "Toshiba R500" and you should be able to fine my posts.
My current job involes rebuilding laptops and desktops so many times that I created this automated slipstreamed XP SP3 CD and I had no issues of Harddrive not being found after all the waiting.
PatKam_AU
Oct 18, 2008 | Toshiba Satellite A205-S4617 Notebook
Laptop xp instalation
Im sorry I didnt understand your problem???
Jan 03, 2008 | Computers & Internet
Installing XP on Toshiba Portege R500 Notebook
Guys, if you have the genuine XP CD, please download the Storage Driver from Intel and slipstream it into your version of XP CD. You can also slipstream Service Packs into it as well.
Personally I hate Vista so much. It really brings out the angry devil in me.
By the way, the best and easiest way to slipstream is to install and use nLite http://www.nliteos.com/
Let me know if you want help on installing XP on R500 (I build it a few days ago, but regret to update the BIOS to version 1.06 as I lost the Ctrl key on it).
To get to the BIOS, press and hold the Esc key then Power button.
Oct 03, 2007 | Toshiba Portege S100-S1133 Notebook
Toshiba PORTEGE R500-S5006X Notebook Logo
129 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
