Question about Siemens Gigaset S455 Cordless Phone
Gigaset as200 no dialing tone
I have disconnected re registered,still goes straight to voice message,no dialing tone
  • 4 Answers
SOURCE: No dial tone
It seems you can receive the calls and dial the numbers, by clicking hand free key you will hear the tone. Regarding answering machine I wonder you activate it or not for activating the machine just click the On/Off key on the base or from the main menu on the hand set choose Voice Mail section then activate Answering Machine, in this section you have other options such as Ring Delay (for choosing the delay before Ans.Mach. pick up the phone), Announcements (playing and recording announcements) and Massage Length. Reza from Iran
Posted on Oct 11, 2008
  • 9 Answers
SOURCE: retrieving message
First set up a pin # or use the default which is 0000.
Then from a remote location:
  • Dial the Number
  • Press * Twice before the greeting is completed
  • Enter the Pin
  • Select * to hear all messages or Mailbox number which you are calling to check
  • Use the menu below:
5 - Play New Messages
6 - Record Message
7 - Play All Messages
8 - Play Greeting
9 - Record Greeting
0 - Turn System Off
# - Access help
Posted on Dec 26, 2008
SOURCE: I have a duo Siemens gigaset A140, both the
my panel on my siemens gigaset is flashing, what is the cause?
Posted on Jul 22, 2010
  • 4 Answers
SOURCE: Siemens gigaset 4015, flashing display
SAme problem here. No dial tone. Did you find solution?
Posted on Jan 27, 2011
highfield410
SOURCE: i need a manual for gigaset 3015.
I need the manual to set it up
Posted on Sep 17, 2012
Gigaset AL110 REGISTERED , CANT DIAL OUT OR IN
Is there a dial tone? And have you tried another phone? If there is a dial tone make sure the phone is set for tone dialing. There will either be a switch on the side of phone for pulse or tone, set for tone. or go into the menu and look for it there...
Apr 14, 2014 | Lands Phones
Phone can receive calls but not make them.
hello i have a solution, you need to change you dialing mode on the base option, the deafult is "tone dialling", change to "pulse tone " this fix my problem on my A495 gigaset.
May 16, 2012 | Lands Phones
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
My gigaset 4015 has no dial tone. (My other mechanical phone does, so it is not a phone service problem.) On the screen there are the battery indicator (OK), RDL and MENU. The other usual symbols, time,...
I have exact same problem. Let me know if you find an answer.
No dial tone. I can call out and reach number (though no sound) so connections are there but just no sound.
For incoming calls, phone rings, pick it up, no sound.
Any solutions??
Dec 31, 2010 | Siemens Gigaset 4015 Cordless Phone
Cannot clear message on handset that says I have a voice message.
I resolved the problem but I'm not 100% sure of how I did it. If it happens again I'll try it again. I left the answering machine OFF so the Voice Mail would take any messages. A friend phoned and left a message in the VOICE MAIL, I knew this because of the broken dial tone when I went to make a call. When I erased his message the 'New Voice Message' displayed on the handset disappeared. I figure a previous caller hung up just after the voice mail picked up. It was not long enough so it did not register in the voice mail but somehow registered on the GE phone. Since there wasn't anything registered in the VOICE MAIL to erase the message was 'stuck' on the handset display. As soon as there was a message registered in the VOICE MAIL that could be erased it also cleared the message on the handset.
As i mentioned, if it happens again I'll try it to see if it works, until then I am not going to tempt fate.
Dec 24, 2009 | Uniden Cordless Phone
FLASHING BASE 1 - PHONE'S LOCKED
Unplug the batteries for 30-45 seconds. Reinstall, and attempt to re-register the handsets to the base.
Jan 26, 2009 | Siemens Gigaset 4200 Cordless Expansion...
No dial tone
This is the time that love cannot help with. Buy yourself a new home phone where the massages will pile up. erase all massages on your mobile phone. It is time to buy a cell phone which will record all masseges that you've received.
Sep 23, 2008 | Siemens Gigaset S455 Cordless Phone
Number of rings
press *94, then press the number of rings you want 1-9. The tone will change and thats it.
Nov 29, 2007 | Siemens Gigaset S455 Cordless Phone
Siemens Gigaset S455 Cordless Phone Logo
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
