Question about GE JGBP33SEHSS Stainless Steel Gas Kitchen Range
Top burners will not light
I do not know how to get to the igniter for the top burners. How do you lift up the top? The first thing I checked was the electrical receptacle -it had power to it and the range plug was all the way in.
jsrock516
  • 5911 Answers
SOURCE: Stove burner igniter does not work.
Your problem is not the igniter itself, but the burner switch that controls the igniter. All the igniters get their power from one spark module that is mounted somewhere in back of the oven. That's why you are able to get all the igniters to spark with only one burner control turned on. This is normal. That is also why you are able to light the burner in question buy turning on another burner. The spark is being provided by a switch that is working. To answer your question: the igniter is removable, but I don't think it's necessary. Cleaning them generally doesn't make them work better. I would check the wiring from the spark module to the burner switch and/or replace the switch. I hope this helps.
Posted on Jul 18, 2007
jsrock516
  • 5911 Answers
SOURCE: Gemini Range Dual Burner
Unfortunately, you cannot repair one element of a dual burner. It all comes as one unit. When one portion of a dual or triple element goes bad, you must replace the whole element. I believe the part number is 1032746 and runs about $70. You will have to lift the glass top to access the burner elements. If you decide to pursue this on your own follow these steps: 1. Unplug range and/or turn off main breaker. 2. Open oven door to access screws under front edge of cooktop. Remove two screws and the top should tilt up. 3. The top will not stay up on it's own, so you will need some assistance holding it up. Some ranges have a couple of disconnect plugs that you can unplug, so you remove the entire top and lay it somewhere to work on. If this is the case with yours (as I suspect it is), lay some soft towels down on the kitchen table or counter top and lay the cooktop upside down. This will make it much easier to work on. 4. Remove affected element by disconnecting the wires first. You may want to write down how they came off, so you can be sure to reconnect them in the right order. 5. Remove mounting brackets holding element in place. Pay particular attention to the numbering scheme on the bottom of the element and where the brackets are mounted. The new element usually doesn't come with new brackets which means you have to take the brackets off the old element and put them on the new element. Make sure you install them in the same numbered holes as they were located before. 6. Reconnect wires and reinstall cooktop, making sure you reconnect the disconnect plugs if equipped. Now, be careful when working on the cooktop while it is upside down. Make sure you don't apply too much pressure on the glass or you could crack it. Also, use extreme care NOT to touch the element surface as the oils from you hands can cause hot spots and effectively ruin it. The bake light material in which the element is mounted is also very fragile. DO NOT put to much pressure on it or it may crack and break. Once you get the cooktop reinstalled and power reapplied, op test it to make sure BOTH elements are working. It is normal to see a little bit of sparking at first with new elements and/or an odor. Test the entire range of the element and make sure it regulates like it should. I hope this helps you.
Posted on Aug 04, 2007
jumptrout51
  • 3361 Answers
SOURCE: electric igniters dont shut off
Remember to turn the control knob past the "LITE" setting once the burner fires.
If that is not the issue you have one or more defective spark switches.
Each valve has its own switch wired in series with the others.
Posted on Mar 12, 2009
SOURCE: Model RDSS30QW X-LO Burner Problem
remove 4 screws under the trim that surrounds the burner knob panel. They are on the underside and you will be looking straight up to see them.
Slide the trim down and off after removing the screws.
remove the burner grills and caps
remove the 4 brass venturis and you will then be able to lift the cooktop
the valves are easy to get to
Posted on Apr 24, 2009
  • 8 Answers
SOURCE: I have two burners that don't ignite
We had two that stop working also. If we used a lighter to light it then it would work. We had pots boil over. When the repair man came over to tell us we need a new control panel he fixed the burners. I would call a repairman to be safe.
Posted on Dec 10, 2009
Amana gas range args7650e makes ticking sound, but does not ignite on one burner
Do not try and lift the top. You will break the gas lines. Use a small nail or pin to clean the hole beside the igniter on that burner that will not light.
https://www.youtube.com/watch?v=ACat1pFqZLY&feature=player_embedded
Aug 29, 2012 | Amana Kitchen Ranges
Top Burner Ignitors
Remove the burner grates. Remove the caps off of the burners. You'll see three screws on each burner, remove these and lift the burner heads out. Now you can lift the cook top up (like lifting the hood on a car) and have access to the wiring for the igniters. The part number you need is #WB13K10003. These are kinda pricey at ~$42.00 ea. at your local appliance parts retailer.
Aug 11, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
The gas is connected on the rear side of the stove but the pilot light is not lit, nor will it light. trying to trouble shoot the problem before deciding to purchase a new oven/range. Also, I remember...
You may have a pilotless ignition.Check around door frames for model #plate.
Also , open broiler door ,turn on oven and look inside . If you see an orange glow appear after awhile, that is the electronic igniter and you have an electronic ignition(no pilot).In this case the top burners use a spark ignition system.If you don,t hear clicking when you turn on a burner your ignition module might be bad.
Easily fixed though.
Aug 18, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Gas cooktop won't light properly
lift the top up ..inspect all burners ..all the small holes ..at the bottom of the burners need to be open an clear ..use a needle /tooth pic to clean them the burners ignite from these bottom holes ..let me know an good luck../joe/
Aug 29, 2010 | Dacor Preference RSD30 Gas Kitchen Range
I smell gas and my burners wont light - is there a pilot light in these ranges?
The best way to find out if if your stove has a pilot light, is to lift the top panel of the range . The pilot will usually be located between the burners. Typically you will have two pilots. One for the left and one for the right. The pilot light will ignite with a match without having to turn the burner knobs to the "on" position. Good luck
May 20, 2010 | GE Spectra JGBP35 Gas Kitchen Range
My gas was recently shut off for repairs from the gas company, now its back on and i dont know how to get my oven or stove back on
Ok you did not mention if your oven or stive had pilot lights or igniters. Given you asked the question how too turn it back on I have to assume it does not have electronic igniters. You need to light the pilot lights. There are 2 in top that are between each of the 2 burner sets. If you can not gain access to the pilot light by lifting the top of the stove up you can use a fire starter type lighter and re-light them. Sometimes they will self light if you just use a match on the burners.
As for the oven you can gain access 2 ways to the pilot light. One is to unlatch and remove the oven lower inside panel. The pilot light will be near the burner head. Just light it. The other is to remove the broiler drawer and reach way back in there to light the pilot light.
Again if you have igniter ignition all you have to do is turn on a burner or the oven. Good Luck.
Jan 22, 2010 | Ovens
GE Cooktop burner doesn't click or light.
Remove all the burner heads and lift the top. Sometimes easier said than done. How do you know it is the module? It could be a cracked insulator on the ignitor. To verify you can swap two of the connections on the module and if it lights then it is the module.
eric
Jun 20, 2009 | GE 30 in. JGP328 Gas Cooktop
Getting to the Pilot
Your model JGBP28DED2WH uses spark ignition on the stove top burners, and a glow bar ignitor, part number WB2X9154 for the oven and broiler. To get to the bake ignitor if oven will not light: Take the racks out of the oven. Remove oven floor by removing two screws at back of oven floor and lifting floor. Remove the square metal flame spreader to get to the burner / ignitor assembly. (note: The ignitor may still glow when you try it, but usually is still the problem)
Feb 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Replace burner spark ignitor?
Electric igniters are usually very simple installs since they usually only come with a common and hot wire, and the igniter clips on to the burners right near the burner top for ignition. The easiest way a DIYer can do this themselves is to slowly take apart the current ignitor after lifting the top of the range up and taking note of every thing's placement. If you have the direct OEM part, then it either work or will not, based upon the fact that it's either the ignitor or the switch for it that has gone bad.
To test if your igniter has gone bad, remove it completely. (it should only be a small cylinder with two prongs, and two wires coming out the other side) Be sure not to strip any screws as heat from the oven will make them hard to remove. From there, you'll need to jump the connection on the top of the igniter with a conducting piece (ie: aluminum foil or wire), then test the common/hot wires with your circuit tester or volt meter. A solid tone or light means that your igniter is good, and the problem lies somewhere else.
Feb 29, 2008 | KitchenAid KGST307 Gas Kitchen Range
Ketchen aid kgst 307
There are several screws under the front lip of top of the range. You will have to open the oven door to see them. Once the screws are removed, the top should just lift up. Of course, if it has been a couple of years, grease and oil can creep into the seams along the sides and cause the top to stick. If this is the case, carefully take a putty knife along the side seams and lift up at the same time on the front. The top should open. Now, if ALL your burners are not lighting, that sounds like a bad spark module. Do you hear a clicking noise when you try to light any of the top burners? If not, the spark module not the igniters, is the likely suspect. The spark module provides a voltage to ALL the igniters simultaneously. Removing the top will not be necessary if this is the case. The spark module is usually located in the back of the oven cavity under bottom pan of the oven. Or, it may be located behind the panel in the rear of the stove. Let me know if this helps you.
Jul 29, 2007 | KitchenAid KGST307 Gas Kitchen Range
GE JGBP33SEHSS Stainless Steel Gas Kitchen Range Logo
24 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
