Question about Krups Dolce Gusto Circolo Blanca [Color: Silver]
How do I descale my krups circulo
How do I descale my coffee machine
  • 2039 Answers
SOURCE: Cleaning and descaling Krups Orchestro 889
take a descaler solution never mind vinegar not strong enought 1part solution 1part water put that in our water container start the machine open valve let it drip for a few second untill you see the solution leave it like that for 10 minute after open the valve and do it again untill emty after you emty the solution clean water container very good fill it with water open the valve rinse very good because that solution is very corosif enjoy cheers
Posted on Jan 19, 2008
ginko
  • 19396 Answers
SOURCE: Where to buy the descaling
Check here
Krups Espresso Machine AntiCalc Descaling Kit
and
Krups Espresso AntiCalc Kit
Posted on Sep 08, 2008
SOURCE: How do i clean my krups proaroma coffee maker
I put a mixture of water and vinegar thru the coffee maker and let it sit for about one hour. Then i rinse clear water thru and its find.
Thanks.
Posted on Jun 06, 2009
  • 3741 Answers
SOURCE: I dont have an instruction manual for a Krups coffee machine.
click on this link directly for user manual of Krupp 867 and yours is 866 but its the same.Download the complete
user guide (411 Ko)
------- This will help. Thanks please keep updated.please please do rate the solution positively .thank you for using fixya
Posted on Mar 19, 2010
SOURCE: Error code 07 on my Krups XP 7220 coffee machine
Error code 07 on my Krups XP 7220 coffee machine what to do? Nick
Posted on Oct 24, 2010
Error code 5 on saeco minuto coffee machine
Error code 5 means the water flow is obstructed. Here are possible locations:
1- The machine was not descaled. Calcium deposits are clogging the water system.
2- The flow meter is not passing impulses for water flow speed & quantity.
3- Descale Descale Descale.
Before you select the automatic descaling, make a few espresso without adding coffee grounds. The automatic cycle does not clean the coffee side of the machine. You have to do it intentionally.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Dec 18, 2016 | Saeco Coffee Makers & Espresso Machines
My Capresso s8's display is blinking and making strange noise
All Jura machines in the series C, E, F, J, S & Z models have the same problem. The Jura recommended maintenance is insufficient or erroneous:
1- When new machine is set up, the owners click OK for use of Filter cartridges. This helps only to display reminders for replacing the filter.
2- The instruction also advises, regular use of Filters, eliminates descaling the machine. That is not accurate. Reminders for descaling are delayed or eliminated. This allows accumulation of Calcium deposits in the entire hydraulic and coffee system.
3- Cleaning tables recommended & sold by Jura do not remove Calcium deposits in the coffee/water passages. The automatic descaling method recommended by Jura also leaves the coffee side of the machine unclean. The error message in your machine is due to Calcium deposits in the Brew group, coffee outlet & the faucet dispensing coffee in the cup. I suggest all Jura machine owners should manually descale machine. Manually descaling includes use of 6 to 10 rinse cycles with descaling solution in the water tank. The error message "Clean Machine" is accurate & pointing to descaling the Brew group, coffee outlet tube and coffee dispensing faucet by using rinse cycles.
After the rinse cycles are complete, refill Descaling solution & continue descaling the rest of the machine using hot water dispensing function, until the tank is empty. Finally, give a final flushing of machine to flush out remaining descaling solution inside the machine.
Services Unlimited Inc Parts Guru Since 1988
Sep 23, 2016 | Jura Capresso Impressa S8 Coffee Maker,...
What is wrong with my silvia? No coffee or water, but steam ok. Loud burring noise
Hi There,
Your coffee group is blocked, with lime or coffee oils.
Try descaling 1st Pulycaf coffee machine descaler . You will find descaler and cleaner in this rancilio silvia kit. Rancilio Silvia gasket kit . Descaling should be done every 3 months or so.
If the descaler does not work - you may have to remove the solenoid valve and descale that - not an easy fix. Takes 20 min.
May 29, 2014 | Rancilio Silvia Espresso Machine
Need a descaler
instractions are from manual HD7810/00
Use the correct descaling agent
Only citric acid-based descalers are suitable for descaling the SENSEO
machine. This
type of descaler descales the machine without damaging it. For the correct amount,
see under 'Descaling procedure' below. Each descaling mixture can be used only once.
After use, the descaling mixture is no longer active.
We advise you to use the special SENSEO
Descaler (HD7012/HD7011/HD7006).
Read the instructions on the package of the descaling agent.
Never use a descaling agent based on mineral acids such as sulphuric acid,
hydrochloric acid, sulphamic acid and acetic acid (e.g. vinegar). These descaling
agents may damage your SENSEO
coffee machine.
Descaling procedure
1 Mix 50 grams of citric acid with 1 litre of water in a measuring jug. Stir until
the powder is completely dissolved.
2 Fill the water reservoir up to the MAX indication with the descaler mixture.
Then put the water reservoir back into the coffee machine. (Fig. 3)
Note: Not all SENSEO
machine types have a water reservoir with a capacity of
1 litre. If you have a SENSEO
machine with a smaller water reservoir, repeat steps
2 to 6 with the remainder of the mixture without filling the water reservoir up to
the MAX indication.
3 Press on/off button 3. (Fig. 10)
The machine is ready for use when the indicator light lights up continuously.
4 Place the 1-cup holder h with a used coffee pod in it in the coffee machine.
Close the lid and make sure it is properly locked.
Note: Always put a used coffee pod in the pod holder when you descale the
machine. This pod serves as a 'filter' to prevent the sieve or hole in the pod holder
from getting clogged with scale residue.
5 Put a bowl with a capacity of at least 1500ml under the spout to collect the
descaling mixture (Fig. 8).
6 Press the 2-cup button hhand let the machine operate. Repeat this until
the water reservoir is empty. (Fig. 25)
Never interrupt the descaling process!
7 Repeat steps 1 to 6. Replace the used pod with another used pod to filter out
the scale residue.
Note: To descale properly, you have to use 2 litres of descaling mixture.
Never descale the SENSEO
coffee machine with the lid open. Make sure the lid is
properly locked.
8 Rinse the water reservoir with tap water. Fill the water reservoir up to the
MAX indication with tap water and repeat steps 3 to 6.
Note: Do not refill the water reservoir with used hot water or the used descaling
mixture.
9 Fill the water reservoir with fresh tap water up to the MAX indication again
and repeat steps 3 to 6 once more.
Note: Always rinse the machine by letting it empty two full water reservoirs.
10 Remove the used pad and clean the pod holder after descaling to prevent the
sieve or hole in the centre from getting clogged.
Mar 30, 2014 | Philips Senseo HD-7810 Coffee Maker
Leaking from under the machine
Descaling will not fix a leak. If you want proper help you really need to identify the product you have by model number.
Jan 16, 2014 | Krups XP Coffee Makers & Espresso Machines
How to descale the delonghi icona pump coffee machine?
Have you ever wondered, 'how do I descale my expresso machine?' First lets us understand what is exactly is scaling. The build up of minerals inside the hot parts of your coffee machine or espresso machine is commonly called lime scale. When lime scale builds up inside the Espresso machine, it slows down the water flow, reduces the boiler capacity and can prevent your coffee machine from working properly. To keep your Espresso machine operational at full order, it is important to descale it every three months. The time intervals between descaling depend upon many factors. Quality of your water and the amount of water running through the machine are the two main factors that decide the frequency at which you should descale your Espresso machine. The more you your machine, more often should you descale it. In some cities, in conjunction with a water filter you can use your coffee machine for a year or more without descaling at all. If you use less water by drinking espressos you'll need to descale less often than if you make cappuccinos.
Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Espresso machine is intended for this specific use only. Before you descale your Espresso machine, always unplug it and make sure that it is cold. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Expresso machine. In case your Espresso machine does not come with a instruction guide or booklet, then use a proper citric acid based descaling solution designed for espresso machines. This should be mixed and prepared as per the instructions on the bottle or packet. Once your Espresso machine has been descaled properly you would not be left wondering, 'how do I descale my expresso machine?', treat yourself to a great cup of coffee. Some popular models of Espresso machines are Krups EA8080 Espresseria Automatic, DeLonghi Magnifica EAM3200S, Krups Nespresso CitiZ & Milk XN 7106 Fire-engine red, DeLonghi Perfecta ESAM5400, DeLonghi PrimaDonna ESAM6600, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5500 and Magimix Nespresso Citiz M190.
Jun 12, 2011 | DeLonghi EAM3500 Espresso Machine/Coffee...
What do you do when it says calc. on the display?
Calc is indicating that it's time to descale the lime build up inside your coffee maker. Most machines are easily cleaned by running a solution of 4 parts water to 1 part vinegar. Run this solution through a regular coffee cycle (no coffee). After running this solution, you may want to run straight water once more to ensure there's no vinegar aftertaste. Your machine will now be clean and the CALC message should disappear. If not, post back with the Model # of your Krups coffee maker for further instructions. Some machines have a Descale or Self Cleaning option built into them.
Apr 24, 2011 | Krups Coffee Makers & Espresso Machines
My Krups XN2005 coffee machine switches itself off as soon as I try and brew coffee from the pod. Any suggestions?
My Krups Nespresso XN2005 machine turns itself off when I try press the start button- any solutions ?
Feb 21, 2011 | Krups Nespresso Essenza XN 2009 Espresso...
Descale how do you descale ?
Check out this tip about how to descale your Keurig coffee brewer
How to Descale your Keurig Coffee Brewer
heatman101
Jan 24, 2011 | Keurig B60 Coffee Maker
Krups Dolce Gusto Circolo Blanca [Color: Silver] Logo
54 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
