Question about Onkyo DX-C380 6-Disc CD Changer
Onkyo 6 disc cd changer DX-380 has CD stuck under carousel
The carousel kept opening and closing and a CD was knocked out of the tray and it slipped under the carousel. How do I open the case to remove the CD?
  • sew8 Jan 05, 2009
    I'm not terribly mechanical, so I am going to recruit some help before I start prying thngs apart. I think it's worth a shot before buying a new unit. Thanks for the suggestion!
This has just happened to us. Often when the changer tries to select a CD on random play, it somehow knocks one CD off the carousel, usually on top of the other 5 CDs and then you can retrieve it easily. This time it knocked it down behind the carousel so the drawer could not close. We left the drawer open, carefully took the player out and tipped it upside down and then tipped it forward. We then closed the drawer while it was still upside down and then turned the player back up the right way. The loose CD fell onto the carousel and we could then open it and retrieve the CD. No damage to either CD or changer and we are now listening to music again!
Posted on Mar 04, 2009
After the CD fell under the carousel, the carousel continues to operate without difficulty -- opens and closes, moves from disc to disc, etc.. Should I be concerned about just leaving the CD without trying to retrieve? I can live without the CD.
Posted on Aug 13, 2011
  • 51 Answers
Find the screws that hold the to of the case to the chassis. They should be on the bottom, and back. Once they're removed, gently pull the top off. You may have to fish under the carousel to get the CD, but if you're gentle, you should be okay. Make DARN sure the power's unplugged, and keep your tools away from the power supply, just in case there's some residual energy left. Good luck!
Posted on Jan 04, 2009
I have an ONKYO CD Changer and there is a CD that is stuck in the tray the tray will open but the CD won't drop down.
Ronald, The unit would have to go in for service to have a technician release the CD. Thanks, FJD
Jul 25, 2016 | Onkyo DX-C390 6-Disc CD Changer Player
How do I fix my Sony cd player with 5 disc carousel changer in which the door keeps opening up? When I close the door the carousel moves around a bit but then the door opens up again.
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
Apr 27, 2008 - Uploaded by Eric Barr
I have a Sony mini hifi stereo(pixy) and when ever I close the tray it continues to ... my cd player drawer opens ... Repairing a 5 disk CD player - YouTube
? 10:09
Nov 23, 2011 - Uploaded by Todd Harrison Repairing a 5 disk CD player ... Sony CDP-CX300 300 Disc Changer Belt Repair and ...
Jan 01, 2016 | Sony Audio Players & Recorders
C.d.s get stuck and now tray wont close
The problem is in the loading bay, sometimes 2 CD's will get jammed locking up the system, or the timing gear is out of sync, or possible broken gears.
May 04, 2012 | Onkyo DX-C390 6-Disc CD Changer
Onkyo DX C330 carousel goes in and out without stopping and won't quit spinning around
Sometimes the tray ribbon goes bad causing bad connection to main board! Common
problem with alot of brands!
Apr 22, 2011 | Onkyo DX-C390 6-Disc CD Changer
I have a Harman Kardon CDR2 and the cd drawers will not open. Do you know how to fix this?
hi jlcady
sounds like the belts need to be replaced. for that the units eject mechanic assy has to be disassembled.
feel free to text for further assistance.
Feb 13, 2011 | Harman Kardon CDR2 2-Disc CD Recorder
CD carousel won't rotate. Opens and closes fine, but will not change discs in either the open or closed position.
gears may have something obstructing them. Check and clean with dustaway. Gears may be broken jammed or slipping belt.
Apr 06, 2010 | Denon DCM-360 5-Disc CD Changer
CD jammed in player. Won't open.
Your going to have to take it apart and manually remove the cd.
To do this remove the top cover.
Make sure the power is off and that it is unpluged when doing so.
Mar 28, 2010 | Onkyo DX-C390 6-Disc CD Changer
NAD C541 tray does not open.
if i'm right it will have the sony mechanism so if you take the lid off and unscrew the 2 screws, 1 at either end of the cd clamp and remove it, you should see part of a large cog just under the front of the cd tray, try turn this clockwise and the tray should open.
once open, you should be able to see a small plastic cover, loosen this slightly and replace the belt as this is prone to slipping on this mechanism stopping the cd tray from opening and also clamping the disc properly when closed.
hope this helps?
Mar 11, 2010 | NAD C541 CD Player
Onkyo DX-703 CD tray engine tries to oepn but cannot when I put CD player on and hit open. What can I do?
You're tray may be opened with a belt, maybe it's slipping over the plastic wheel.
Good luck,
Jan 14, 2010 | Onkyo DX-C390 6-Disc CD Changer
Onkyo DX-C380 6-Disc CD Changer Logo
1,071 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
