Question about Carrier 52CQ-312-4 Comfort Series Heat Pump Air Conditioner
3 amp fuse blows on a carrier 58mcb furnace board
Fuse will blow whenever the heat pump kicks in. Using an infinity thermostat, a four wire system. The furnace works fine and i am temporarily running a manual thermostat across R and W for now.
Which components in the heat pump would you suspect in blowing the 3 amp fuse in the furnace. Could it be the control board itself in the heat pump or the compressor contactor coil. Should i measure the resistance of all the components in the heat pump running low voltage?
Thanks in advance
carrier 58mcb-120 furnace and carrier 25hna660 heat pump
  • robertochekw Jan 06, 2009
    Thank you for all your advise. The carrier system belongs to a client of mine and once the snow clears off the roads, i will go apply your advise on his system. I will report back on what i find on the low voltage short.
    A question i had is, the swelling capacitor, is that a capacitor found on the control board?
    Regards,
  • dwkcool May 11, 2010
    yes it could be either one or the capasitor, open the panel and look at the capasitor for swelling
Ok, If 3 amp fuse is blowing in the air handler unit when switch is turned to cool check to see if outside unit jump starts and stops when this happens. If this is the case wiring is fine check main relay in outdoor unit. There will be a spring contact on main relay (Black relay close to where wires come into unit), check for corrosion or carbon build-up on little round contacts. If you can clean contacts with a small piece of sand paper. Make sure all breakers are off before removing cover! You might have to remove relay in order to clean it. Make sure you write down exact locations of any wires you remove. This should fix the problem.
Posted on Jul 01, 2012
  • 96 Answers
The capasitor is in the outside unit , it is either round or oval in the electrical compartment , it has 2 or 3 termanels
Posted on Jan 06, 2009
  • 163 Answers
Hi!!! Does your ac unit work fine?If not check your low voltage problem..You have a low voltage problem check the wire going out to your condensor make sure that they are not touching..Good luck..Check low voltage wires..short in progress..
Posted on Jan 04, 2009
  • trey mork Nov 03, 2010
    Alright I had the same thing. 3 amp fuse keeps blowing. I don`t have an ac hooked to this like alot of these posts everywhere, just a furnace and a thermostat for heat. I`ve been working on this for 2 days and I can say after all this I found that I had an intermittent problem but didn`t know it. I`d check something and then 20 mins later I`d check it and it was differant. Make sure things you already checked are the same 20 mins later. Overall, i found thermostat wire wore thru were it enters the furnace and shorting to ground. i changed the board and thermostat, but as it turns out it was the short and no need for that stuff. The best way to fig this out is, disconect the thermostat at the board see if fuse blows, if so short inside furnace. If not, short out thermostat at board and while leaving thermostat wire DISCONNECTED. If blown then maybe board, or short, keep looking. If it doesnt short its the thermostat wire somewhere on its way to thermostat.
My(38ycc030340)carrier heat Pump ac unit blows 5 amp fuse on board in handler in attic when switch stat to heat.
Miss wired or shorted low voltage wiring. Have you changed stat? Animal chewed wires at foundation wall or in attic?
Oct 10, 2016 | Carrier Heating & Cooling
Coleman furnace dgaa077bdta
The control fuses keep blowing tells me one or more of the control that operate the control on 24 volts is malfuctioning. Most controls operate at about 5 watts and on a clamp on amp meter normally pull about 0.2 amp (p = current x voltage, 5 watts = 0.2 amps x 25 volts) I install 75 watt 24 volt transformer with a resettable overload to save on fuses. I reset the transformer and quickly go to the controls and determine the amp draw. When I find the one >0.2 amps I found the problem. The things to check is the emergency heat sequencer, fan control sequencer, reversing valve for heat pumps, main contactor on the condensing unit and any other 24 volt control loads. I have had to replace the themostat wire because the increase current for the thermostat wire can cause the entire length of wire to form a long heater and cause insulation degradationa and cause the thermostat wire to short out and blow the fuses.
Hope this helps
Aug 30, 2014 | Coleman Mobile Modular Home Gas Furnace...
My honeywell thermostat will not let the fan blow if it's on automatic
Depends on what type of heat you have...if it is electric, it could be your thermostat (some electric heaters use contactors & rely on the thermostat to switch the fan on). Heat pumps also use the thermostat to switch the fan on in heat & cool mode. Most electric furnaces use a sequencer to switch the low speed of the fan whenever there is a call for heat. Gas furnaces use either a fan/limit controller (if the unit is older) OR a circuit board based on time (after the thermostat calls for heat). SO depending on the type of system you have, it could be a bad sequencer, controller, relay, thermostat, or control board.
Dec 17, 2013 | Heating & Cooling
My york heat and air unit with emergency heat is blowing 30 amp fuses and sparking at the fuses and contactor when turn main breaker back on. I have replaced contactor, transformer and the compacitor on...
You either have something wired wrong or you have a direct short in the system. Are you starting the A/C or the furnace? If it's the A/C, it could be a shorted compressor, capacitor, fan motor or it's wired wrong.
Oct 30, 2013 | Heating & Cooling
My furnace keeps blowing fuses why it is a nordine model #e2eb-015ha
The first thing i would do is shut off all the power to the unit and disconnect all the wiring from the thermostat. then i would install a jumper wire from R to W on the circuit board and see if the furnace runs good. if it runs good and does not blow a fuse, your problem is in the wiring between the t-stat and the furnace. If this does not help, please indicate if your system is a straight a/c, furnace system. or if it is installed with a heat pump. also does it make any difference what the temperature is outside. for example, does the fuse only blow when the temp drops down into the 30s or does it not make any difference.
Nov 19, 2010 | Heating & Cooling
Heat pump doent kick back on after defrost-blows 5amp breaker
If you continue to blow the 5 amp fuse, you have a "short" in the control circuit. It could be the reversing valve solenoid coil (very rare) or it could be in the wiring. It is possible that you have a wire with cut or melted insulation that is causing the low voltage short. If this is happening only during the defrost cycle, then you want to check the wires going from your defrost board to your reversing valve solenoid coil. Also check the wires going from the defrost board to the defrost thermostat. Often, some electrical tape and some wire ties to pull the wires away from the area that damaged the insulation is the only thing that is needed to correct this problem. I hope this helps. Good Luck!
As far as the refrigerant is concerned. Yes, it is possible to overcharge a system. It would have to leak out, but it is not uncommon to charge a system that has 5 years and perform a quick check for leaks. Sometimes systems have very slow leaks or the leaks reseal after time. It is better practice to charge it, look for obvious leaks and then see how it does than it is to spend hours looking for a leak that may not be found. It costs you more money and the tech more time. Hopefully, you used a reputable company to charge this system.
Feb 07, 2010 | Carrier Heating & Cooling
3 amp fuse blows after three hours on Goodman 4 ton 16 seer pump
I would suspect you have a problem in the defrost circuit of your heat pump. there are a couple of things you can try. first just run the system on emergency heat and see what happens. you could have a defrost board that is shorting when it kicks into defrost. it sends a signal back to the furnace so it will come on during defrost. if you do not blow a fuse as long as you are running in emergency heat, i would suspect the defrost control board. also you could have a dead short in the wire that runs from the "w" terminal on furnace control board, out to the heat pump. keep in mind that any of the wires could be the cause and i am just tying to give you the most common things. your furnace will still run if you unhook all the low voltage wiring out at the heat pump. if you do this and stop blowing fuses. you know it is something on that wiring. goodl luck.
Jan 26, 2009 | Haier Energy Star ESA3183 Air Conditioner
No heat new thermostat
you have a short in the wireing.disconnect at air handler and hook-up short t-stat wire to t-stat,ifok chk wire to condenser
Jan 10, 2009 | Heating & Cooling
Carrier Infinity Control Thermostat SYSTXCCUID01-B
Your old stat is wired for a traditional thermostat and not a communication stat like the new infinity you have. There is a module plug on the furnace board that will need to be connected to the new thermostat for it to work. The wires that are wired now are from a terminal strip inside the furnace. Please contact your local Carrier dealer. They may be able to get that harness for you
Dec 06, 2007 | Heating & Cooling
Heating & Cooling Logo
3,026 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
