Question about Samsung UN55ES8000 55 LED-LCD 3D 1080p HDTV
How to set A Samsung UN55ES800 to show all station in full Screen
Have a Motorola Top box DC6416 DVR connectet with a HTMI input to The TV, 16-9
SOURCE: Samsung TV Mode not supported message
check to see if the output is set to 480i. HDMI does not support 480i - http://samsungplasmatvfaq.com/index.php/Display_settings
Posted on Nov 19, 2007
SOURCE: connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Posted on Jul 15, 2008
lukster
  • 217 Answers
SOURCE: HDMI INPUT FOR NON HIGH DEF CHANNELS WILL NOT DISPLAY FULL SCREEN
if you have a cable box then it is probably the resolution settings in the cable box, what type of cable box do you have
Posted on Jul 20, 2008
driveallnigh
  • 89 Answers
SOURCE: I have a Samsung LCD HDMI 37inch TV series 5 do I need a set top box
No set top box required. Your TV has the latest technology. If so desired you could subscribe to a cable or satellite network and you will receive a box that will pick up all channels. HD channels are usually extra. As far as picking up "digital" broadcasting, no worries because your TV is already digital capable.
Posted on Apr 16, 2009
rootbeer001
  • 352 Answers
SOURCE: samsung lcd 720 ln32b360 doesn't fill screen in
If by regular cables you are talking about the standard red/yellow/white composite cables, then, yes, it will affect HD as composite cannot send an HD signal. Only HDMI and component (red/blue/green video only) cables.
Change to HDMI and let us know if it works for you.
Posted on Jan 07, 2010
New sony tv doesn't recognize cable channels
Normally the TV has to be connected to a set top box supplied by the cable company. The TV set usually needs to be tuned to channel three (or four) and kept at this setting. If an HTMI connection cable is used look for a button labled "input" on the TV remote and using the remote change the input selection to tch the HTMI input station you plugged it into .
Oct 06, 2014 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
Our replacement samsung dlp tv lamp doesn't give us a full screen picture on any stations other than the High Definition stations, how do we fix this?
The high def stations are full screen as they are transmitted in a 16:9 ratio which is full screen. However the non HD channels are transmitted in a 4:3 ratio which is square and not full screen. Usually this can be rectifyed by putting your tv in 16:9 mode through it's menu's. You can also adjust this setting through your cable box if you are using one.
Hope this helps
Jun 27, 2008 | Samsung Televison & Video
Top and bottom of the screen are cut off
That set has an aspect ratio of 4:3. The problem is that what you are sending to it is 16:9 So you are sending an hd signal to a non HD television. The tuner is NTSC which is not HD. Theres not much that you can do about this.
Jan 17, 2014 | RCA F27650 27" TV
Having problems gettin sky channels through archos i get to setting infrared settings and can not get code.dont know wether to connect dvr t the tv or the sky box
Remove the DVR station from the box, and attach the DVR adapter plate (found in the
DEVICE box); it is correctly attached when it clicks on.
-Take the Black Audio/video Marked "output" cable, and insert the connections into the corresponding coloured sockets, yellow>yellow, green> green etc. Make sure they are
inserted into the TOP row on the back of the DVR Station "Marked Out". The remaining
black connector should be plugged into the SW socket, which can be found underneath
the orange socket on the back of the DVR station. (If after setting up your ARCHOS the
picture is very green remove the black cable from the SW socket)
-Plug the SCART connector into the SCART socket on your TV set. These are usually
marked AV1, AV2, or Ext 1, Ext 2, L1, L2, Line in 1, Line in 2, Aux 1, Aux 2, make sure you
select the corresponding channel above (ie AV1 AV2 etc) on your TV set when you turn on
the TV.
-Attach the UK plug adapter to the Mains charger, and plug the charger into the DC-In
socket on the back right of the DVR station. Turn the mains on at the socket.
-Insert the powered off ARCHOS unit onto the DVR station, the unit will now power on,
and ask if you want to 'Switch to TV out', select 'Okay'. The 'TV output configuration' set
up will load up. Select 'Okay'.
-TV connection: When your DEVICE is connected to the optional DVR Station you need to
select the type of video output (Composite, S-video, component, RGB, HDMI etc), based
on how you have connected the DVR Station to your TV and what possibilities your TV will
allow. For the cables supplied and the instructions aboce you will need to select either
RGB or Composite. Use the arrows to go through the options and select either RGB or
Composite.
-TV Standard: this should be set to PAL (Europe). Select 'Next'.
-Now you need to test the settings, select 'Okay', the ARCHOS home screen should now
be visible on your TV set. If you have nothing showing on your TV, scroll through the
AV/Ext channels, the channel will correspond to the AV/Ext socket you connected the
cable to on your TV set. Use the ARCHOS remote to select 'Okay'; you have now set up
the output connection settings for your DVR station.
-You may need to adjust your output from the ARCHOS to match your TV, from the "TV
Format" options. Use the arrows on the ARCHOS remote to select the format of your TV
screen, so the ARCHOS unit outputs the correct picture size (ie 4:3 / 16:9 etc). Use the
arrows on the remote to select 'Next'.
Dec 24, 2010 | Archos 605 WiFi Digital Media Player
TRYING TO INSTALL DIGITAL SET-TOP BOX WITH DVD AND TV
Hi ccraigo
To answer your question;
Your motorola will connect directly(not through the dvd) to the tv set into one of the input ,(preferably using hdmi or component cables for hd) and the dvd will use a different input,
All you have to do then is switch between which one you want to watch.
Hope this help Cheers
Apr 20, 2010 | Pioneer Televison & Video
Olevia 242 and Motorola DVR Cable Box switching
Have you tried using component cables instead. One of my Time Warner cable boxes did the same thing using HDMI.
Dec 01, 2009 | Televison & Video
Archos DVR Station & 605 wifi PMP
Not sure if this will help you or not, but I have a 404 and was having issues with the scheduler changing the channels for me also. Then I realized that it is a infrared transmitter - the same frequency as a remote I realized what I was doing wrong - Your archos station must be facing the cable box that it is turning on. I had my archos on top of the cable box and it was not working - but when I turned the cable box and the archos station to face each other - so the signal can transfer - it worked just fine. Hope that helps!
Oct 22, 2008 | Archos 605 WiFi Digital Media Player
Normal Picture Mode Not Available With Cox HD-DVR (Motorola DCH3416) and HDMI Cable
With an HDMI cable connected, the cable box determines the picture size. The settings on the cable box must be changed in order for you to get the correct picture size. I have some experience with Motorola cable boxes; usually to access the settings you turn the box OFF and then press the menu or settings button on the box to bring up the display menu. Hope this helps!
Mar 05, 2008 | Sony KDL-32M3000 32 in. LCD Television
Sharp LC-37D4U 1080i picture problem
have the cable company set the box to 720p whic is the native resolution of the set.this will help with quick signal adjustment
Dec 29, 2006 | Sharp LC-37D4U 37 in. LCD Television
Samsung UN55ES8000 55 LED-LCD 3D 1080p HDTV Logo
307 people viewed this question
Jerry Greenberg
Jerry Greenberg
