Question about Brother Office Equipment & Supplies
Brother MFC-8880DN Printer toner reset - Brother Office Equipment & Supplies
SOURCE: Brother MFC-7820N Toner Problem
Open the cover, press Options and then *00.
Posted on May 22, 2009
SOURCE: reset drum - brother mfc-8860dn
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Posted on Mar 16, 2008
SOURCE: HELP! Brother MFC-8460 "Toner Life End" won't clear
The problem with a new toner cartridge that will not signal the printer that it has been changed has to do with a gear positioned wrong on the new or rebuilt cartridge... we had 3 factory brand new toners that would not clear the replace the toner message... I finally found the following link that came from a toner company that sells refills that tells how to reposition the gear to let the machine know a new cartridge has been installed. I did the proceedure on pages 5 & 6 having to reposition the gear and all cartidges then worked flawless... it works.
http://www.castleink.com/265/cartridge/TN580.pdf
Posted on Sep 23, 2008
SOURCE: Brother 5240 laser printer changed toner still wont work.
This works on several different Brother Printers to get rid of toner/drum empty errors:
1. Open the front cover and leave open while completing the following steps.
2. Turn the printer off.
3. Hold the 'go' button while turning the printer on. All panel lights should be on.
4. Release the 'go' button.
5. Press the 'go' button 2 times.
6. Pause.
7. Press the 'go' button 5 times.
8. The toner light should be off.
9. The paper light should be on or flashing [doesn't happen on all].
10. Close cover. The ready light should be the only light on.
Posted on Feb 05, 2010
  • 48 Answers
SOURCE: Need service manuals
You can access all of Brother's printer manuals online at their website in .pdf for free. Just go to http://www.brother-usa.com/manuals/default.aspx?PGID=5&R3ModelID=DCP165c and find your printers; you don't even have to download them.
Posted on Aug 17, 2010
Print unable 71
Print Unable 71 means Polygon Mirror Failure on the Brother HL-4040, MFC-9840 and MFC-9440.
Pretty safe to say it means the same thing on the MFC-8880.
The Polygon Mirror is part of the Laser Unit, and its rpm isn't within specs.
The Laser Unit must be replaced.
Jan 08, 2015 | Brother MFC-8880DN Mono Multifunction...
How do you reset counter on Toner for TN-360
No, If you use a refill in your recent toner cartridge you need to reset the toner, if you use a new toner cartridge, no need to reset.
Aug 28, 2014 | Brother MFC 7840W Printer
What does the drum do on my brother printer
The drum is the component that actually transfers the image onto the page.
Laser Printing 101. When a page is printed to a laser printer it is transferred to the laser printer via the network or usb cable using the driver installed on the PC. This information is then converted back into a format the printer can print through the Format board and the internal firmware of the Printer. This information is then transferred to the drum via a laser beam to a photo-sensitive film on the surface of the drum which is charged and allows the toner from the toner cartridge to stick to the drum which is then transferred to the page and the page is then fed through a Fuser (A heated roller which operates somewhere around the 300-500 degree cetigrade point) to fuse/melt the toner onto the paper which is then fed out to the paper cachment area you collect your printout from.
I hope that helps with your understanding.
Aug 13, 2014 | Brother MFC-8880DN Mono Multifunction...
How to reset toner sensor for Brother MFC-8880DN Printer
The TN3130 & TN3170 actually have a physical reset and it is pretty easy to do. The second part of this video shows you how.
Feb 05, 2013 | Brother MFC-8860DN Printer
Brother MFC-9440CN Laser Printer is saying toner life end and I just put a new cartridge in.
If you want to reset your Brother MFC 9440N machine so you no longer have the error message: Toner End of Life, do the following:
1. Open the front cover of the 7820N, that is, the cover that allows you to pull out the toner and drum, but don't pull out the drum/toner.
2. Push the button: Options (located on the left of the control pad).
3. Type: *00 on the keypad.
The Brother MFC 9440N should be reset and the Toner End of Life message should disappear. Warning, this may void your warranty and ultimately damage your machine if you are reusing or refilling your cartridges, but you should already know that. Hope this helps.
Nov 11, 2010 | Brother MFC-9440CN Laser Printer
Jul 13, 2010 | Brother MFC 210C All-In-One InkJet Printer
Hi my brother MFC 7420 will not recognize the new toner i just added...........i hve done this multiple times before........not sure now why not working.........are the printer gods against me today??
all brother printers and mfc products. if you are using generic tonere or refills, brother products will not recognize the toner cartridge as the refillers do not know how to reset the toner cart. this is priority info. therefor u must use brother oem toner.brother service rep
Dec 22, 2008 | Brother MFC 7420 All-In-One Laser Printer
1,121 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
