Question about LG Televison & Video
LG-BP125 no hdmi sound
No sound when using HDMI plugged into SamsungLED Tv (UA46ES7500)
sandrew
  • 2961 Answers
SOURCE: ps3- hdmi to av
unless there is a switch on the ps3 itself to change to normal tv, you may have to reconnect the ps3 via HDMI and change the screen resolution back to 480p or change the settings in the setup from hdmi to av.
Posted on Aug 24, 2007
SOURCE: HDMI sound?
I had the same problem with my PS3. I have a HD cable box with HDMI out, a Sony DVD player with HDMI out. The Sony receiver STR-DG800 only has the HDMI inputs (sat/tv and dvd) and the HDMI is only a pass through port and will not decode audio.
I purchase a HDMI 4 port switch from Newegg (HS-41A0 http://www.newegg.com/Product/Product.aspx?Item=N82E16812168003&Tpk=HS-41A0) to hook up the DVD and PS3 to the DVD HDMI and switch between the DVD player and the PS3. It took me several days to figure out how to make this work with the settings on the reciver.
1 the DVD player must use the coaxial in jack for sound on the receiver.
2. the PS3 must use the optical connection on video1
3. the sound settings in the PS3 must be set to PCM
4. set the sound setting on the receiver to the following
a. on the remote press AMP button then the MENU button, next press the down arrow to you see 5- AUDIO SET - then press enter.
b.set sound decode priorty to PCM
c. next scroll down to you see digital assign - press enter
assign VID1 OPTICAL to DVD ( this allows the pcm output from the PS3 to play through the receiver), next assign DVD to COAXIAL setting DVD to DVD (this allows the digital sound to play from your DVD player).
So when you use your remote and select DVD, you can use your PS3 or DVD through the 1 DVD HDMI port.
Posted on Feb 24, 2008
SOURCE: new home theater setup- no signal at tv using onkyo tx=sr605
This might somewhat help. Today I went back .. I went HDMI out of the Cable box and DVD player into 2 of the TVs HDMI ins. The digital audio out from each, straight to the receiver and things are working ok. All speakers are working OK. Sound isnt as loud or crisp but unfortunately I found no other solution.
Posted on Jan 06, 2009
  • 43 Answers
SOURCE: HDMI not working Sony BDP-S350
With sony products sometimes you have to use sony parts to get it to work. I would suggest to buy a sony HDMI cable and see what happens if that doesn't work then take the player back to the store because you got a faulty player.
Posted on Jan 08, 2009
SOURCE: Compatibility with Samsung LCD Display
It sounds like the HDMI port on the back of your Marantz is damaged. if you know for sure that the HDMI port works on another tv still you might just use component connection because the visible difference between component and HDMI is not very recognizable.
Posted on Jan 13, 2009
My lg plasma Tv hdmi ports will not work?
Have you tried different HDMI cables?
Have you tried switching the ends around?
Are you sure you changed your TV inputs to the correct one?
Not all LG TV's will sense an HDMI connection and offer to switch to the new input.
I know it sounds ridiculous but I had an HDMI Cable break just sitting there. Also they now have HDMI Cable that are Unidirectional, you can plug them in backwards.
Dec 23, 2016 | LG Televison & Video
How do I hook-up Netflix through a Sony Blu-Ray player and a LG television
If your Sony Blu-Ray player and LG TV are recent models, each should have an HDMI cable connection. HDMI is an method to connect your digital video and audio devices with just a single combined cable. In the case of your LG TV, using an HDMI cable will allow you to send the HD video signal to your TV's screen, and allow you to hear the sound through the TV's speakers.
Your LG TV may have multiple HDMI connectors, to allow other devices to send signals to your TV, such as a cable box or satellite box or digital video recorder (DVR). Your Sony Blu-Ray player will usually have just a single HDMI connector.
Purchase an HDMI cable from your local electronics store. There are different versions of the HDMI specification, and you should get a cable that you can verify is certified for the HDMI version 1.4 specification.
Plug one end of the HDMI cable into the Blu-Ray player, and the other end into one of the HDMI connectors on the TV, noting which one you selected.
When you turn on your Sony Blu-Ray and your LG TV, you should use the remote for the LG TV to select the input source. Your LG remote should allow you to select the HDMI input connector you used, at which point you should see the display of a DVD playing on the Blu-Ray player. If you cannot hear the sound, use the LG remote to increase the TV volume.
Mar 02, 2015 | Netflix
How do I hook up lg tv to lg dvd to sound bar then to dish
LG TV - LG Blu-Ray = HDMI (any except 1 if using below)
LG TV - Sound bar = Digital Optical Audio or HDMI 1 or Headphone (depending on your TV Audio out ports.)
LG TV - Dish STB = HDMI
Dec 27, 2014 | LG Televison & Video
Hi, I have bought LG LCD ld310 . Can I connect my computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable Thanks Jatinder Kumar
Hi Jatinder Kumar ,
Yes you can connect your computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable.
1. Connect to HDMI (DVI) : just plug in HDMI (DVI) out of PC or laptop to HDMI or DVI TV. Than select source from HDMI.
2. Connect to PC : Plug D sub to TV, select PC in.
I hope that will help you.
thanks.
Mar 21, 2011 | LG Televison & Video
I have a sky+ hd box connected to an lg 42LH300 tv through hdmi and an LG HT805SH home cinema through optical cable. Whenever i turn sky over i lose sound and have to turn cinema on/off to sound returns ...
One of the way to connect the whole system is using only HDMI cable version 1.3a. There is audio return channel built into the cable.So you do not have to connect the optic cable.
Sky box to TV using HDMI
LG HT805 to TV using HDMI. Even the Sky box audio will come back to the LG-HT through the audio return path.
Mar 08, 2011 | LG Televison & Video
I have a LG LHB335 Blu-Ray home theater system, & a LG TV I can get Full surround sound when the blu-ray is play a DVD but not when just watching Reg TV. I use a HDMI, should I hook up sonething else ?...
LG documentation states:
When you use SIMPLINK function, you have to
connect to the OPTICAL IN 1 jack to enjoy TV
sound to your speaker system.
Basically you need to have the Audio go from TV to receiver and setup receiver to that Input to output surround sound to all speakers.
If you have a cable box or satellite receiver, hook that output into the receivers input and that should work.
My setup is DirectTv HDMI output goes into the LG Home Theater HDMI Input 1, and LG goes HDMI output into the TV HDMI input 1.
so to watch DirectTV, I switch LG Home theater to HDMI Input 1. and TV is on HDMI input 1 (to view LG HDMI output from DriectTV, Blu-Ray, Vudu, etc.)
Jan 11, 2011 | LG LHB335 Theater System
I HAVECONNECTED ALL MY SPEAKER WIRES,HDMI CABLEAND CONNECTED THE YELLOW AUDIO CABLE.POWERED UP THE DVD BOX BUT I ONLY GET SOUND FROM TV.the tv is a new 47'' LG.
If you are using HDMI cable you will not be using the YELLOW RCA plug sine the Yellow pug is for composite video. Analog audio uses RED (RIGHT) and WHITE (LEFT) for sound.
How exactly youhave the whole thing setup? through the receiver or just between the TV HDMI port and the HDMI port on the DVD player?
You will also need to setup the HDMI sound set up to send the sound through the HDMI cable or through the audio analog RCA ports.
More info needed. Hook up per DVD and TV user manuals
Jan 01, 2011 | Televison & Video
Audio on HDMI(2) output with external audiocord?
The audio from the hdmi out on your computer is turned off. Try connecting another device such as a dvd player to the hdmi input on your tv . If audio works on tv then you know no audio is not available from the hdmi output on you computer.
Nov 21, 2009 | LG 42PC1R 42 in. Plasma HDTV
How can i get the surround sound to work.
You need to get an HDMI cable going from your Cable Box to the Surround Sound system. If you are low on HDMI ports, you can RGB cables for Video.
Your quote: " I have a HDMI cable plugged into the TV and the Cable box." move that cable to Surround Sound and Cable Box, and use RGB cable or HDMI to go from Cable box to TV!
If your Surround Sound has no HDMI, use a Fibre Optic to go Cable to Surround. It will work Great!
Good Luck!
Apr 08, 2009 | Audiovox Audio Players & Recorders
LG 42PX4DV - HDMI Audio / PC Audio IN problem
I found the fix. Had the same problem.
I right clicked on the sound speaker icon in the bottom right of Windows 7.
Chose Playback Devices.
Once this window opens, then make sure you are on the Playback tab.
Scroll down until you see the HDMI Device. (Mine was hidden at the bottom of the list.)
Then choose "set as default".
The sound will begin playing on the TV with only the HDMI connected......no need for an extra audio cable.
Sep 26, 2007 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
Televison & Video Logo
246 people viewed this question
