Question about Panasonic (CF-50GB7UUKM) PC Notebook
Panasonic cf-50 no audio controller
No audio controller. where do i get one
4 Suggested Answers
SOURCE: panasonic cf-50
go to panasonic.com and download a bios update to a floopy then turn on your comp hit f2 to bring up your configs select boot then boot from floppy then restart your comp
Posted on Jan 03, 2009
leecom72
  • 4806 Answers
SOURCE: panasonic toughbook model number
Hi there
Download drivers for both if you are unsure, one way to tell if its a MK1, look underneath the laptop at the model number, if is says neither MK's its MK1 as it will say if its a MK2.
Saying that the drivers should work on both machine models
Good luck and kind regards
Posted on Jan 19, 2009
1alexh
  • 484 Answers
SOURCE: upgrade hard drive in panasonic toughbook cf-50
1 - Using a stack of DVD RW blank disks, or a large capacity USB Flash/Jump Drive, back up your Laptop computer completely. If necessary, Use WinZIP to ensue that everything has been compressed into the smallest capacity possible.
2 - When you are certain that you have backed up the drive completely, remove the older drive
3 - Line up the new drive and the old drive and ensure the jumpers are set to the same settings as they were set on the older HDD.
4 - Once you are sure, you then restore everything from the back-up drive for the old hdd to the new disk drive.
5 - Test to ensure that everything from the old drive has been backed up from the old drive to the new drive.
6 - If you are comfortable that your backup has been completly restored from the backup meda to the new, larger hard drive, then be certain that you have restored from the older drive to the new drive, tighten all screws and cables, then close all ports and ensure that everything has been done properly by and for you.
7 - Be certain that you have created the same user accounts in the new drive as you had on the older drive.
8 - Now, power off the new drive while in the laptop. Wait about 30 seconds to one minute, then restart the new hard disk drive.
9 Test everything, to be sure that everything works properly. Go through everything from the top of the menu to the bottom of the menu. Try all accessories, try all applications. Ensure that all works right and that the applications work as they used to work, when it was on the old drive.
10 - Remember, you have a warranty on the new HDD, so be sure that you have tested everything to ensure that it all works properly, before you sign off on this new drive.
11 - Once you are certain that it all works correctly, you can then be sure that it is working properly and competely, because only you know if things are working correctly as they should be.
12 - Then you can sign off and you can be sure that things work properly.
13 - As carpenters say ... measure twice; cut once. You can only do this one time, so if you measure it more than one tim, you can be certain that you will get it done correctly and be happy that you did it right. from beginning to end.
Have fun. Don't be too serious about it, but do be careful, and get it right. Remember, get it right the first time, and you will be pleased with the results at the end.
Posted on Jun 22, 2009
  • 44 Answers
SOURCE: Panasonic tough book cf-50 video problem
Your video chip IS going bad. Send it to Panasonics service center. They can fix it for you at a reasonable price.
Posted on Feb 07, 2010
Panasonic cf-53 no sound
me also having the same problem.. no audio from my toughbook cf-53. it was working fine and dont know all of a sudden how it stopped working. how to fix it???? all Fn + F4 and other things from control did. but nothing seems to be working. please help me to fix it.
Aug 16, 2013 | Panasonic Cf53 Panason
Multimedia audio controller driver
The audio driver for the Panasonic Toughbook CF73
can be found at this website:
http://pc-dl.panasonic.co.jp/itn/drivers/d_menu_en.html
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Jul 25, 2013 | Panasonic Toughbook CF-73 Notebook
Panasonic cf-37 audio driver
The only drivers for the CF37 I can find
are on the Panasonic Canada Website:
http://help.panasonic.ca/english/support/sandd/softwarequery.asp
Enter CF37 (not CF-37) and you should
find the right drivers.
Good Luck!
Regards
May 18, 2012 | Panasonic Toughbook CF-30 Notebook
I installed windows xp pro and i have no sound cf-50 toughbook CF-50BB2NUDM I`ve tried Realtek and the panasonic sound driver download site nothing has worked so far.
Have you check Device Manager and under sound, video and game controllers to see if you have any yellow ? marks next to anything. You would go to start-control panel-system-hardware-device manager.
If you have any yellow marks missing then you will need to find the driver for those.
It may be a codec that you need too.
Also Start/ control panel/ Sounds check that MUTE is not selected and that volume is UP.
Could be these drivers that you need Audio Output: Sound card Audio Codec: STAC9751 Compliant Standards: AC '97.
Check this site and make sure you have the complete model number, There are several different ones for your Cf51 that should look like this CF-51xxxxA/H/Qxx (mk1) . Some model numbers require that you have Sevice Pack 2 or SP2 for windows installed for the sound driver to work.
http://pc-dl.panasonic.co.jp/cgi-bin/itn/toughbook/dl01.cgi
Mar 14, 2010 | Panasonic Toughbook CF-51 Notebook
Dec 02, 2009 | Panasonic Toughbook CF-51 Notebook
Drivers need cf-50 panasonic tougbook
Go to panasonic.com and search for the drivers.
Jun 05, 2009 | Panasonic Toughbook CF-51 Notebook
Panasonic cf-50 problems to connect wireless wpa personal
If the wireless card is an old model it possibly won't support WAP encryption. The wireless router most likely supports both WEP and WAP encryption.
WEP is not as secure as WAP so use the highest bit encryption that is available to you.
May 07, 2009 | Panasonic Toughbook 50 Notebook
Panasonic toughbook model number
Hi there
Jan 19, 2009 | Panasonic Toughbook 28 Notebook
Panasonic cf-50
Dec 09, 2008 | Panasonic Toughbook 50 Notebook
Panasonic (CF-50GB7UUKM) PC Notebook Logo
149 people viewed this question
Top Panasonic Computers & Internet Experts
Brian Sullivan
Brian Sullivan
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
